查看: 1671|回复: 6
[每日一码] Creating a hatch object and setting its scale
发表于 2016-9-8 15:05:01 | 显示全部楼层 |阅读模式
Question
How do I create a hatch object and set its scale? I had a function in my ARX
application that was used to create HATCH pattern. However, I found that it was
useless to set scale in my application because I had to set the scale manually
once again in AutoCAD. Why did this happen?
Answer
This might be caused by the wrong placement of setPatternScale() function. Note
that you have to set hatch pattern properties, such as, pattern angle, pattern
scale, associativity, and pattern name just after AcDbHatch has been created.
After appending loops to the hatch object, you can set its other properties,
such as layer name, color index, hatch style and so on. Then evaluateHatch()
method must be used to evaluate if it can be properly displayed on the screen.
And lastly it should be appended to AutoCAD database and closed. The following
code shows how to do this exactly. For detailed information, refer to AcDbHatch
class explanation in ObjectARX documentation.
[it618postdisplay>0]
[sell=3]
  1. #define AOK(es) if(es != Acad::eOk) throw es;
  2. void createHatch(void)
  3. {
  4.             AcDbObjectId objId;
  5.             AcDbEntity* pEnt;
  6.             ads_name ent;
  7.             ads_point point;
  8.             if (RTNORM != acedEntSel("SELECT AN ENTITY TO BE HATCHED: ", ent,
  9. point))
  10.                         return;
  11.             assert(objId.setFromOldId(ent[0]));
  12.             AOK( acdbOpenObject(pEnt,objId,AcDb::kForRead) );
  13.             AcDbHatch *pHatch = new AcDbHatch;
  14.             assert(pHatch);
  15.             try
  16.             {
  17.                         AcDbBlockTableRecordPointer pBtr(ACDB_MODEL_SPACE,
  18. curDoc()->database(), AcDb::kForWrite);
  19.                         AOK(pBtr.openStatus());
  20.                         AOK(pHatch->setPatternAngle(0));
  21.                         AOK(pHatch->setPatternScale(10));
  22.                         AOK(pHatch->setAssociative(Adesk::kFalse));
  23.                         AOK(pHatch->setPattern(AcDbHatch::kPreDefined, "ANSI32"));
  24.                         // append loop to hatch
  25.                         AcDbObjectIdArray dbObjIds;
  26.                         int objNum = dbObjIds.append(pEnt->objectId());
  27.                         acutPrintf("\nOBJ number is %d.", objNum);
  28.                         AOK(pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds));
  29.                         AOK(pHatch->setLayer(pEnt->layer()));
  30.                         AOK(pHatch->setColorIndex(256));     //bylayer
  31.                         AOK(pHatch->setHatchStyle(AcDbHatch::kNormal));
  32.                         AOK(pHatch->evaluateHatch());
  33.                         AOK(pBtr->appendAcDbEntity(pHatch));
  34.                         AOK(pHatch->close());
  35.             }
  36.             catch (const Acad::ErrorStatus es)
  37.             {
  38.                         acutPrintf("Error: %s", acadErrorStatusText(es));
  39.                         delete pHatch;
  40.             }
  41. }
[/sell]
[/it618postdisplay]
发表于 2016-9-18 21:08:46 | 显示全部楼层
谢谢楼主分享
发表于 2016-9-21 17:35:41 | 显示全部楼层
我来学习学习,提高水平
发表于 2017-8-5 00:37:45 | 显示全部楼层
谢谢楼主分享,
发表于 2017-8-5 10:44:16 | 显示全部楼层
谢谢楼主..
发表于 2017-8-9 23:05:41 | 显示全部楼层
我也来学习学习是怎么一回事呢
发表于 2018-5-22 20:40:05 | 显示全部楼层
看看scale如何设置。代码中没有处理scale比例不合适的情况……
GMT+8, 2026-11-22 09:45 , Processed in 0.355948 second(s), 20 queries , Gzip On, File On.
