查看: 1218|回复: 2
[每日一码] Creating a linetype using ARX
发表于 2016-9-9 09:15:00 | 显示全部楼层 |阅读模式
Question
How can I create a linetype using ARX?
Answer
The sample code below creates a linetype using ARX:
[it618postdisplay>0]
  1. #include "dbmain.h"
  2. #include "dbsymtb.h"
  3. void utilsarxtest ()     {
  4.     AcDbLinetypeTable *pLtypeTable =NULL ;
  5.     // get the linetype table from the drawing
  6.     if ( acdbHostApplicationServices()->workingDatabase()->getLinetypeTable (pLtypeTable, AcDb::kForWrite) ==
  7. Acad::eOk ) {
  8.         AcDbLinetypeTableRecord *pLtypeTableRecord =new
  9. AcDbLinetypeTableRecord ;
  10.         // set all of the properties of the linetype table record.
  11.         pLtypeTableRecord->setAsciiDescription ("T E S T -") ;
  12.         pLtypeTableRecord->setPatternLength (0.75) ;
  13.         pLtypeTableRecord->setNumDashes (2) ;
  14.         pLtypeTableRecord->setDashLengthAt (0, 0.5) ;
  15.         pLtypeTableRecord->setDashLengthAt (1,-0.25) ;
  16.         pLtypeTableRecord->setName ("ASTESTER") ;
  17.         AcDbObjectId tmpId ;
  18.         // add the pLtypeTableRecord to the linetype table
  19.         if (pLtypeTable->add (tmpId, pLtypeTableRecord)==Acad::eOk){
  20.             pLtypeTableRecord->close () ;
  21.         } else {
  22.             delete pLtypeTableRecord ;
  23.         }
  24.         // close everything up
  25.         pLtypeTable->close () ;
  26.     }
  27. }
[/it618postdisplay]
发表于 2017-8-7 15:56:26 | 显示全部楼层
发表于 2017-8-9 23:04:02 | 显示全部楼层
我也来学习学习是怎么一回事呢
GMT+8, 2026-11-22 10:26 , Processed in 0.220777 second(s), 12 queries , Gzip On, File On.
