查看: 1667|回复: 3
[每日一码] 输入修正角和绝对角旋转对象
发表于 2016-9-9 18:56:56 | 显示全部楼层 |阅读模式
  1. (defun c:rtt (/ ss oan nan p1 rot osn)
  2.   (princ "\n Rotate, Select objects: ")
  3.   (setq ss (ssget))
  4.   (setq oan (getangle "\n Angle to be corrected: "))
  5.   (setq nan (getangle "\n New absolute angle: "))
  6.   (setq p1 (getpoint "\n Base point of rotation: "))
  7.   (setq rot (/ (* (- nan oan) 180) pi))
  8.   (setq osn (getvar "osmode"))
  9.   (setvar "osmode" 0)
  10.   (command "rotate" ss "" p1 rot)
  11.   (setvar "osmode" osn)
  12.   (princ)
  13. )
已领礼包: 2476个
发表于 2016-9-10 15:46:15 | 显示全部楼层
command rotate r
已领礼包: 1304个
发表于 2016-9-10 16:26:52 | 显示全部楼层
command ro
已领礼包: 1094个
发表于 2021-9-30 06:55:20 | 显示全部楼层
感谢输入修正角和绝对角旋转对象
GMT+8, 2026-11-3 07:24 , Processed in 0.419099 second(s), 35 queries , Gzip On.
