查看: 1671|回复: 1
[每日一码] 创建命令反应器的代码
发表于 2016-9-22 14:37:52 | 显示全部楼层 |阅读模式
(defun Reactors:Command ( / reactor )
  (if
    (setq reactor
      (vl-some
        (function
          (lambda ( _reactor )
            (if (eq "Reactor-Command" (vlr-data _reactor)) _reactor)
        (cdar (vlr-reactors :vlr-command-reactor))
    (if (not (vlr-added-p reactor))
      (vlr-add reactor)
    (vlr-command-reactor "Reactor-Command"
      (list
        (cons :vlr-commandcancelled 'callback:commandended)
        (cons :vlr-commandended     'callback:commandended)
        (cons :vlr-commandfailed    'callback:commandended)
        (cons :vlr-commandwillstart 'callback:commandstarted)
  (princ "\n--> Command Reactors Loaded.")
  (princ)
已领礼包: 9个
发表于 2019-1-19 18:28:26 | 显示全部楼层
感谢分享 特来学习
GMT+8, 2026-11-4 23:40 , Processed in 0.441573 second(s), 31 queries , Gzip On.
