查看: 1347|回复: 1
[求助] 定义了个线型,可是不起作用,求助!!
发表于 2016-9-30 17:38:49 | 显示全部楼层 |阅读模式
求助, 我写的代码,想添加一个DASHED的线型,如果没加载,就自己定义下添加到线型表里面,可是显示出来的就是实线,高手帮我看下问题出在哪? 谢谢!
        AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
        AcDbLinetypeTable *pLinetypeTbl;
        AcDbObjectId ltId;
                ->getSymbolTable(pLinetypeTbl, AcDb::kForRead);
        if ((pLinetypeTbl->getAt(_T("DASHED"), ltId))!= Acad::eOk)
        { acutPrintf(_T("\nNO DASHED Linetype "));
        pLinetypeTbl->upgradeOpen();
        AcDbLinetypeTableRecord* pLineTypeRec = NULL;
        pLinetypeTbl->getAt(_T("DASHED"),pLineTypeRec,AcDb::kForWrite);
        pLineTypeRec = new AcDbLinetypeTableRecord();
        pLineTypeRec->setName(_T("DASHED"));
        pLineTypeRec->setAsciiDescription(_T("__ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __"));
        pLineTypeRec->setNumDashes(2);
        float linelength[2]={0.25,-0.1};
        for (int i=0;i<2;i++)
                pLineTypeRec->setDashLengthAt(i,linelength);
        pLinetypeTbl->add(pLineTypeRec);
        pLineTypeRec->close();
        else
                acutPrintf(_T("\n线型已经存在."));
        pLinetypeTbl->close();
发表于 2016-9-30 19:45:06 | 显示全部楼层
应该是没有设置线型的总长,setPatternLength(),下面的红色的代码加进去试试。
        AcDbObjectId ltId;
        if ((pLinetypeTbl->getAt(_T("DASHED"), ltId)) != Acad::eOk)
                pLinetypeTbl->getAt(_T("DASHED"), pLineTypeRec, AcDb::kForWrite);
                float linelength[2] = { 0.25,-0.1 };
                double dPatternLength = 0;
                for (int i = 0;i<2;i++)
                        dPatternLength += fabs(linelength);
                        pLineTypeRec->setDashLengthAt(i, linelength);
                pLineTypeRec->setPatternLength(dPatternLength);
        else
GMT+8, 2026-11-22 11:49 , Processed in 0.264255 second(s), 10 queries , Gzip On, File On.
