查看: 1729|回复: 2
[每日一码] 文字旋转到当前PLAN VIEW
已领礼包: 20个
发表于 2016-10-3 23:17:44 | 显示全部楼层 |阅读模式
  1. (defun c:txt2plan ( / e i s )
  2.     (if (setq s (ssget "_:L" '((0 . "TEXT"))))
  3.         (repeat (setq i (sslength s))
  4.             (setq e (entget (ssname s (setq i (1- i))))
  5.                   e (subst '(210 0.0 0.0 1.0) (assoc 210 e) e)
  6.                   e (subst  (cons 10 (trans (cdr (assoc 10 e)) (cdr (assoc -1 e)) 0)) (assoc 10 e) e)
  7.                   e (subst  (cons 11 (trans (cdr (assoc 11 e)) (cdr (assoc -1 e)) 0)) (assoc 11 e) e)
  8.             )
  9.             (entmod e)
  10.         )
  11.     )
  12.     (princ)
  13. )
评分
参与人数 1D豆 +2 收起 理由
WhoCanSay + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2016-10-8 08:29:47 | 显示全部楼层
这个还不错,支持!
已领礼包: 1094个
发表于 2021-10-17 00:02:50 | 显示全部楼层
感谢分享文字旋转到当前PLAN VIEW
GMT+8, 2026-11-3 01:41 , Processed in 0.417982 second(s), 40 queries , Gzip On.
