查看: 2174|回复: 1
[每日一码] ARX射线法判断点是否在多边形内
发表于 2016-10-5 09:15:01 | 显示全部楼层 |阅读模式
  1. //*************************************************************
  2. //利用射线法判断一点是否在窗口内,如果在内部返回1,否则返回0
  3. //其中输入参数pt是被判断点,boundarypt是辅助边界点,用于作射线用
  4. //*********************1-14-2001 by Meishuli
  5. int inwindow(ads_point pt,ads_point boundarypt,ads_name windowent)
  6. {
  7.   ads_name ent0;
  8.   int rt;
  9.   AcDbEntity *pent,*pwindowent;
  10.     AcDbObjectId pentId,pwindowentId;
  11.   AcGePoint3dArray points;
  12.   int CrossPtsNum;
  13.   AcGePoint3d Pts,BoundaryPts;
  14.   AcDbObjectId auxlineId;
  15.     Acad::ErrorStatus es;
  16.   Pts.set(pt[X],pt[Y],0);
  17.   BoundaryPts.set(boundarypt[X],boundarypt[Y],0);
  18.   auxlineId=createLine(Pts,BoundaryPts);
  19.   acdbEntLast(ent0);
  20.   pwindowent=selectEntity(pwindowentId,windowent,AcDb::kForRead);
  21.   pent=selectEntity(pentId,ent0,AcDb::kForRead);
  22.   es=pwindowent->intersectWith(pent,AcDb::kOnBothOperands,points,0,0);
  23.     if (es == Acad::eOk) {
  24.       CrossPtsNum=points.length(); //计算交点的数量CrossPtsNum
  25.         points.setLogicalLength(0);
  26.   }
  27.   else {
  28.         acutPrintf("\nerror!--inwindow()\n");
  29.       pent->close();
  30.     acdbEntDel(ent0);
  31.       pwindowent->close();
  32.     return -1;
  33.   }
  34.   pent->close();
  35.   acdbEntDel(ent0);
  36.   pwindowent->close();
  37.   if(CrossPtsNum % 2 == 0)
  38.      rt = 0;
  39.   else rt = 1;
  40.   return rt;
  41. }
发表于 2018-7-18 14:08:56 来自手机 | 显示全部楼层
https://blog.csdn.net/keng_s/article/details/52231046你这个好像不是很完善,根据它这篇博客所说,还要考虑如果得到的交点是多边形的端点的情况
GMT+8, 2026-11-22 09:48 , Processed in 0.227434 second(s), 10 queries , Gzip On, File On.
