查看: 2559|回复: 5
[每日一码] 任意曲线动态“分地”的分析应用
发表于 2016-10-10 15:12:37 | 显示全部楼层 |阅读模式
应朋友要求,研究了下曲线分割图形,下面是一个演示的代码,完善完善就可以用到“分地”的应用上。代码用了API ARX的 几何库,算这些图形分析很强。
(defun c:tt ()  (defun _callback (dynpt)
    (redraw)
    (xdge::setpropertyvalue xline "set" dynpt (mapcar
                                                dynpt
                                                ydir
    (xdge::setpropertyvalue crvInt "set" gsrc xline)
    (if (>= (length (setq ints (xdge::getpropertyvalue crvInt "intPoints")))
            2
      (progn
        (xdge::setpropertyvalue tmpLine "set" (car ints) (last ints))
        (xdge::setpropertyvalue tmpRay "set" (setq midpnt
                                                   (xdge::getpropertyvalue tmpLine "midpoint")
                                (mapcar
                                  midpnt
                                  xdir
        (xdge::setpropertyvalue crvInt "set" gsrc tmpRay)
        (setq tmpPnt (xdge::getpropertyvalue crvInt "intPoints"))
        (if (= 'LIST (type (car tmppnt)))
          (setq tmpPnt (last tmppnt))
        (setq gsub (xd::curve:getsub e (trans (car ints) 0 1)
                                     (trans (cadr ints) 0 1) (trans tmppnt 0
        1
              #tarea1 (abs (xdge::getpropertyvalue gsub "area"))
        (xdrx_setpropertyvalue eTxtL "textstring" (rtos #tarea1 2 1))
        (xdrx_setpropertyvalue eTxtR "textstring" (rtos (- #tarea #tarea1) 2
                                                        1
        (xdrx_setpropertyvalue eTxtM "textstring" (strcat "总面积:"
                                                          (rtos #tarea 2 1)
        (xdge::free gsub)
        (xdrx_grdraw 1 0 tmpLine)
      (progn
        (xdrx_setpropertyvalue eTxtL "textstring" "0.0")
        (xdrx_setpropertyvalue eTxtR "textstring" "0.0")
                                                          (rtos #tarea 2 1)
  (defun _writeText ()
    (xdrx_setpropertyvalue (entlast) "color" 253)
    (setq h (/ (distance (car box) (last box)) 13.0)
          an (angle (car box) (cadr box))
    (xdrx_text_make (last box) "0.0" h an)
    (setq etxtL (entlast))
    (xdrx_setpropertyvalue etxtL "color" 1)
    (xdrx_text_make (caddr box) "0.0" h an)
    (setq etxtR (entlast))
    (xdrx_setpropertyvalue etxtR "color" 1 "horizontalMode" 2
                           "alignmentPoint" (caddr box)
    (setq midp (xdrx_midp (last box) (caddr box))
          midp (mapcar
                 midp
                 (xdrx_vector_product ydir (* 2 h))
    (xdrx_text_make midp "0.0" h an)
    (setq etxtM (entlast))
    (xdrx_setpropertyvalue etxtM "color" 2 "horizontalMode" 4 "verticalmode"
                           0 "AlignmentPoint" midp
  (if (and
        (setq e (car (xdrx_entsel "\n拾取封闭的曲线<退出>" '((0 . "*POLYLINE,SPLINE,ELLIPSE,CIRCLE")))))
        (xdrx_getpropertyvalue e "isclosed")
    (progn
      (xdrx_begin)
      (xdrx_sysvar_push '("cursorsize" 3) '("osmode" 32) '("dimzin" 0))
      (setq xdir (getvar "ucsxdir")
            ydir (getvar "ucsydir")
            box (xdrx_entity_box e)
            gsrc (xdge::constructor e)
            crvInt (xdge::constructor "kCurveCurveInt3d")
            tmpLine (xdge::constructor "kLineSeg3d")
            tmpRay (xdge::constructor "kRay3d" '(0 0 0)
                                      (xdrx_vector_negate xdir)
            #tarea (abs (xdrx_getpropertyvalue e "area"))
      (xdrx_polyline_make box t)
      (_writeText)
      (setq xline (xdge::constructor "kLine3d" '(0 0 0) ydir))
      (xdrx_pointmonitor "_callback")
      (if (getpoint "\n移动十字光标<退出>")
        (xdge::entity:make tmpline)
        (redraw)
      (xdrx_pointmonitor)
      (xdrx_sysvar_pop)
      (xdrx_end)
  (princ)
发表于 2016-10-10 15:30:31 | 显示全部楼层
赞一个 虽然没我写的好
发表于 2016-10-10 15:45:58 | 显示全部楼层
把你写的代码贴上来和大家分享啊
发表于 2016-10-11 06:13:10 | 显示全部楼层
感谢 Lispboy 分享程序 挺特别的!
发表于 2016-10-12 09:48:23 | 显示全部楼层
赞一个 虽然没我写的好
上面二楼说的
这是不是有点吹啊
发表于 2016-12-12 13:57:25 | 显示全部楼层
我用c++写的,自动分
GMT+8, 2026-11-22 08:07 , Processed in 0.455316 second(s), 22 queries , Gzip On, File On.
