查看: 1665|回复: 4
[研讨] 判断闭合多线段方向
发表于 2016-10-14 21:07:40 | 显示全部楼层 |阅读模式
;;;多线段为闭合非自交
(defun c:tt()
    ;;;向量叉乘
   (defun sfun (pt1 pt2 pt3)
        (setq va                 (-
                       (* (- (car pt2) (car pt1)) (- (cadr pt3) (cadr pt2)) )
                       (* (- (car pt3) (car pt2)) (- (cadr pt2) (cadr pt1)) )
    ;;;获取多线段顶点坐标(有序)
   (setq pts (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel))))))
    ;;;获取横坐标最小的点在顶点集中的位置
   (setq n0 (car (vl-sort-i pts
                              (function (lambda (e1 e2)
                                                  (< (car e1) (car e2))
    (setq xmin (car (nth n0 pts)))
    (setq xmins (vl-remove nil (mapcar '(lambda (x) (if (= xmin (car x)) x ))  pts)))
    ;;;判断闭合多线段方向
    (if (= (length xmins) 1)
        (setq flag               (cond
                   ((= n0 0) (sfun (last pts) (car pts) (cadr pts )))
                   ((= n0 (- (length pts) 1)) (sfun (car (cdr (reverse pts))) (last pts)  (car pts )) )
                   (t (sfun (nth (- n0 1) pts) (nth  n0 pts) (nth (+ n0 1) pts)))
        (if (< (cadr (car xmins)) (cadr (cadr xmins)))  (setq flag -1) (setq flag 1))
    (if (< flag 0) (print "闭合多线段方向为顺时针")(print "闭合多线段方向为逆时针"))
评分
参与人数 1D豆 +5 收起 理由
Lisphk + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2016-10-15 08:14:21 | 显示全部楼层
谢谢楼主分享经典程序!
发表于 2016-10-15 10:32:19 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2016-10-15 10:45:59 | 显示全部楼层
找到3个点,然后根据三角形的面积也能求出方向吧?
发表于 2016-10-15 15:35:25 | 显示全部楼层
回的人少,我来小顶一下
GMT+8, 2026-11-22 09:00 , Processed in 0.336661 second(s), 17 queries , Gzip On, File On.
