查看: 2364|回复: 1
[每日一码] ARX 沿着多段线指定距离画线(递归执行)
发表于 2016-10-26 14:15:00 | 显示全部楼层 |阅读模式
//from:起点,to:终点(这两点要相邻)
//paramDis:沿着多段线画多长
//pl:多段线
//pPoly:新的多段线
static void DrawByLen(const bool& gotoNext ,const AcGePoint2d& from,const AcGePoint2d& to,const double& paramDis,const AcDbPolyline* pl,AcDbPolyline* pPoly,int& polyIndex)
        if(paramDis <= 0)
                return;
        int len = pl->numVerts();
        AcGeCircArc2d arc2d;
        AcGeLineSeg2d line2d;
        AcGePoint2d ptS;
        AcGePoint2d ptE;
        bool isFind = false;
        int plIndex = 0;
        AcGeCurve2d* pCurve = NULL;
        for(int i = 0;i < len;i++)
                AcDbPolyline::SegType st = pl->segType(i);
                if(st == AcDbPolyline::SegType::kArc)
                        pl->getArcSegAt(i,arc2d);
                        pCurve = &arc2d;
                else if(st == AcDbPolyline::SegType::kLine)
                        pl->getLineSegAt(i,line2d);
                        pCurve = &line2d;
                if(!pCurve->hasStartPoint(ptS) || !pCurve->hasEndPoint(ptE))
                        continue;
                if(ptS == from && ptE == to || ptS == to && ptE == from)
                        plIndex = i;
                        isFind = true;
                        break;
        double sumDis = 0.0;
        if(isFind)
                DrawIt(gotoNext,pl,paramDis,from,polyIndex,plIndex,sumDis,pPoly);
        else
                acutPrintf(_T("\nnot found"));
//summary////
//指定一个起点和一条多段线,沿着多段线画出指定距离,递归执行,每次往后(前)移动一个点,直到画完指定的距离,
//pl:多段线
//paramDis:画多长
//ptStart:起始点
//polyIndex:添加到第几个了
//plIndex,遍历到多段线第几条线
//isSToE,遍历的顺序1:从前向后  0:从后向前
//sumDis,目前画的总长度
//pPoly:画出来的多段线
static void DrawIt(const bool& gotoNext,const AcDbPolyline* pl,const double& paramDis,const AcGePoint2d& ptStart,int& polyIndex,int& plIndex,double& sumDis,AcDbPolyline* pPoly)
        AcDbPolyline::SegType st = pl->segType(plIndex);
        AcGePoint2d ptS;
        AcGePoint2d ptE;
        double leftDis = 0.0;
        double curveDis = 0.0;
        double bulge = 0.0;
        if(polyIndex == 2*(len - 2))
                acutPrintf(_T("\nend poly is %d"),polyIndex);
                return;
                pl->getArcSegAt(plIndex,arc2d);
                pCurve = &arc2d;////!!!注意:指针的生命周期一定要大于等于指向的变量的生命周期,否则变量release掉指针就空了,再次使用指针程序直接崩溃!!
                pl->getLineSegAt(plIndex,line2d);
                pCurve = &line2d;
                return;
        curveDis = pCurve->length(pCurve->paramOf(ptS),pCurve->paramOf(ptE));
        leftDis = paramDis - sumDis;
        pl->getBulgeAt(plIndex,bulge);
        if(curveDis > leftDis)
                double paramEnding = 0.0;
                if(gotoNext)
                        AcGePoint2d ptEnding;
                        AcGePoint2d ptS;
                        pCurve->hasStartPoint(ptS);
                        GetPtAtDistOnCurve(pCurve,ptS,leftDis,ptEnding,Adesk::kTrue);
                        bulge = tan(atan(bulge) * leftDis/curveDis);
                        pPoly->addVertexAt(polyIndex,ptS,bulge);
                        polyIndex ++;
                        pPoly->addVertexAt(polyIndex,ptEnding);
                else
                        AcGePoint2d ptE;
                        pCurve->hasEndPoint(ptE);
                        GetPtAtDistOnCurve(pCurve,ptE,leftDis,ptEnding,Adesk::kFalse);
                        pPoly->addVertexAt(polyIndex,ptE,-bulge);
                        polyIndex ++;
                return;
        else
                if(gotoNext)
                        polyIndex ++;
                        pPoly->addVertexAt(polyIndex,ptE);
                        polyIndex ++;
                        //acutPrintf(_T("\nplIndex is %d,poly is %d。is goto next,bulge is %.2f"),plIndex,polyIndex,bulge);
                else
                        polyIndex ++;
                        pPoly->addVertexAt(polyIndex,ptS);
                        polyIndex ++;
                /*acutPrintf(_T("\nptS[X] :%.2f,ptS[Y]:%.2f,ptE[X]:%.2f,ptE[Y]:%.2f"),ptS[X],ptS[Y],ptE[X],ptE[Y]);*/
                sumDis += curveDis;
        if(gotoNext)
                plIndex = plIndex < len - 1  ? ++plIndex : 0;
        else
                plIndex = plIndex > 0 ? --plIndex : len - 1;
        DrawIt(gotoNext,pl,paramDis,ptStart,polyIndex,plIndex,sumDis,pPoly);
////反回曲线上一定距离的点(默认从起点开始计算)
////pCurve:曲线指针,dist:距离,point:要返回的点
////Adesk::Boolean isGotoNext  true:沿着正向寻找,false:沿着反方向寻找
static void GetPtAtDistOnCurve(const AcGeCurve2d* pCurve,const AcGePoint2d& ptInput,double dist,AcGePoint2d& point,Adesk::Boolean isGotoNext)
        if(pCurve == NULL)
                return;
        AcGePoint2d ptS;
        ptS = ptInput;
        double pa = 0.0;
        double datumParam = 0.0;
        //Adesk::Boolean posParamDir = Adesk::kTrue;
        datumParam = pCurve->paramOf(ptS);
        pa = pCurve->paramAtLength(datumParam,dist,isGotoNext);
        point = pCurve->evalPoint(pa);
发表于 2016-10-27 09:40:18 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2026-11-22 11:06 , Processed in 0.177799 second(s), 10 queries , Gzip On, File On.
