查看: 2563|回复: 5
[每日一码] ARX 选择集过滤使用例子
发表于 2016-10-27 13:25:00 | 显示全部楼层 |阅读模式
static AcDbObjectId LoadEntity(AcDbEntity* entity)
        AcDbBlockTable* pBlockTable;
        acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord* pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
        AcDbObjectId Id;
        pBlockTableRecord->appendAcDbEntity(Id,entity);
        pBlockTable->close();
        pBlockTableRecord->close();
        entity->close();
        return Id;
////是否是自由模式,返回样本实体所在的层(非自由选择模式)
static bool IsFreeMode(CString& strLayer)
        ////样本
        ads_name sName;
        ads_point sPt;
        acedInitGet(RSG_NONULL,_T("F"));
        int ret = acedEntSel(_T("\n选择样本曲线[自由选择(F)]<回车自由选择>:"),sName,sPt);
        bool isFree = false;////是否自由选择
        acutPrintf(_T("ret is %d\n"),ret);
        ////只要没选实体,都是自由模式
        if(ret == RTKWORD || ret == RTERROR)
                /*CString kword ;
                acedGetInput(kword.GetBuffer(1));
                kword.ReleaseBuffer();
                if(kword.CompareNoCase(_T("F")) == 0)
                isFree = true;
                isFree = true;
        else if(ret == RTNORM)
                isFree = false;
                AcDbObjectId entId;
                if(Acad::eOk != acdbGetObjectId(entId,sName))
                        acutPrintf(_T("\n获取样本实体ID失败"));
                        return isFree;
                AcDbEntity* pEnt;
                if(Acad::eOk != acdbOpenObject(pEnt,entId,AcDb::OpenMode::kForRead))
                        acutPrintf(_T("\n打开样本实体失败"));
                        return isFree;
                ////获取层名称
                strLayer = pEnt->layer();
                pEnt->close();
        return isFree;
static void GetAreaLen(double& sumLen,double& sumArea,long& lineNum,const int& mode)
        CString strMode ;
        CString strLayer;
        isFree = IsFreeMode(strLayer);
        ads_name ssName;
        resbuf* strFilter = NULL;
        ////根据选择的模式构造过滤器字符串
        if(isFree)
                acutPrintf(_T("\n您选择了自由模式\n"));
                strFilter = acutBuildList(-4,_T("<or"),
                        RTDXF0,_T("LINE"),//直线
                        RTDXF0,_T("ARC"),//圆弧
                        RTDXF0,_T("LWPOLYLINE"),//轻量多段线
                        RTDXF0,_T("POLYLINE"),//二维多段线
                        RTDXF0,_T("SPLINE"),//样条曲线
                        RTDXF0,_T("CIRCLE"),////圆
                        RTDXF0,_T("ELLIPSE"),////圆
                        -4,_T("or>"),RTNONE);
        ////加上样本曲线所在的层进行过滤
        else
                acutPrintf(_T("\n您选择了样本模式"));
                acutPrintf(_T("\n根据图层%s进行过滤。"),strLayer);
                strFilter = acutBuildList(-4,_T("<and"),
                        -4,_T("<or"),
                        -4,_T("or>"),
                        8,strLayer,////样本所在的层名称
                        -4,_T("and>"),
                        RTNONE);
        if(mode == 1)////计算长度
                acutPrintf(_T("\n选择要计算长度的曲线:"));
        else
                acutPrintf(_T("\n选择要计算面积的曲线:"));
        ////根据过滤条件选择实体
        if(acedSSGet(NULL,NULL,NULL,strFilter,ssName) != RTNORM)
                acutPrintf(_T("\n未找到符合条件的实体"));
                return;
        long len;
        acedSSLength(ssName,&len);
        lineNum = len;////赋值实体数量
        AcDbEntity* pEnt = NULL;
        AcDbCurve*  pCur = NULL;
        ads_name en;////每个实体名称
        double param = 0.0;
        double dist = 0.0;//长度
        double area = 0.0;//面积
        for(int i = 0;i < len; i++)
                if(acedSSName(ssName,i,en) != RTNORM)
                        acutPrintf(_T("\n获取第%d个实体名称出错"),i);
                        acutRelRb(strFilter);
                        acedSSFree(ssName);
                        return;
                AcDbObjectId enId;
                if(Acad::eOk != acdbGetObjectId(enId,en))
                        acutPrintf(_T("\n获取第%d个实体ID出错"),i);
                        acedSSFree(ssName);
                        return;
                if(Acad::eOk != acdbOpenObject(pEnt,enId,AcDb::OpenMode::kForRead))
                        acedSSFree(ssName);
                        return;
                if(!pEnt->isKindOf(AcDbCurve::desc()))
                        acutPrintf(_T("\n发现了不是曲线类型的实体,程序退出"));
                        pEnt->close();
                        acedSSFree(ssName);
                        return;
                pCur = (AcDbCurve*)pEnt;
                pCur->getEndParam(param);
                pCur->getDistAtParam(param,dist);
                pCur->getArea(area);
                sumLen += dist;
                sumArea += area;
                acutPrintf(_T("\n第%d个曲线的长度是%.2f,面积是%.2f"),i,dist,area);
                pCur->close();
        acedSSFree(ssName);
static void TESTsumarea()
        double len = 0.0;
        double area = 0.0;
        long lineN = 0;
        GetAreaLen(len,area,lineN,0);
        acutPrintf(_T("\n共选择:%ld个曲线,总面积:%.2f。"),lineN,area);
static void TESTsumlen()
        double len = 0.0;
        double area = 0.0;
        long lineN = 0;
        acutPrintf(_T("\n共选择:%ld个曲线,总长度:%.2f。"),lineN,len);
发表于 2016-11-3 22:56:43 | 显示全部楼层
还是写成lisp的过滤表比较方便,传给arx,
关键是怎么传递好这个表
发表于 2016-11-3 22:59:51 | 显示全部楼层
LISP传给ARX表,有什么问题吗? 读RESBUF链表就行了。
发表于 2016-11-5 22:24:48 | 显示全部楼层
按道理没必要读。
一旦要读,就有我说的怎么传递的问题了
发表于 2016-11-5 22:34:37 | 显示全部楼层
都有哪些传递方法呢?其中哪个效率最高?悉听
发表于 2016-11-6 13:36:45 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2026-11-22 11:04 , Processed in 0.324682 second(s), 18 queries , Gzip On, File On.
