查看: 1703|回复: 5
[每日一码] ObjectARX 5个常用代码
发表于 2016-10-31 14:05:00 | 显示全部楼层 |阅读模式
//加载一个实体到数据库,返回实体ID
static AcDbObjectId LoadEntity(AcDbEntity* entity)
        AcDbBlockTable* pBlockTable;
        acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord* pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
        AcDbObjectId Id;
        pBlockTableRecord->appendAcDbEntity(Id,entity);
        pBlockTable->close();
        pBlockTableRecord->close();
        entity->close();
        return Id;
static int SelColor()
        ////先获得当前层的ID
        AcDbObjectId layerId = acdbHostApplicationServices()->workingDatabase()->clayer();
        ////然后获得当前层指针
        AcDbLayerTableRecordPointer ptLayer(layerId,AcDb::OpenMode::kForRead);
        ////获得当前层的颜色
        AcCmColor oldColor = ptLayer->color();
        int nCurColor = oldColor.colorIndex();//当前层的颜色
        int nNewColor = oldColor.colorIndex();//用户选择的颜色
        if (acedSetColorDialog(nNewColor,Adesk::kFalse,nCurColor))
                return nNewColor;
        else
                return nCurColor;
//第一题:定义一个全局命令,功能:使用全局函数创建一个简单实体-直线,顶点由用户输入;
static void TESTlineCmd()
        ads_point inputStart;
        ads_point inputEnd;
        AcGePoint3d ptStart;
        AcGePoint3d ptEnd;
        ////用户输入要画的坐标
        if (acedGetPoint(NULL,_T("\nstart point"),inputStart) != RTNORM)
                return;
        ptStart[X] = inputStart[X];
        ptStart[Y] = inputStart[Y];
        ptStart[Z] = inputStart[Z];
        if (acedGetPoint(NULL,_T("\nend point"),inputEnd) != RTNORM)
                return;
        ptEnd[X] = inputEnd[X];
        ptEnd[Y] = inputEnd[Y];
        ptEnd[Z] = inputEnd[Z];
        AcDbLine* pLine = new AcDbLine(ptStart,ptEnd);
        int colorIndex = SelColor();
        AcCmColor color;
        color.setColorIndex(colorIndex);
        pLine->setColor(color);
        LoadEntity(pLine);
/第二题:定义一个LISP函数,功能:使用全局函数创建一个简单实体-圆,返回圆的实体数据链表,圆心和半径由用户输入;
static int ads_circle()
        ads_point pt;
        if(acedGetPoint(NULL,_T("\n选择圆心"),pt) != RTNORM)
                return 0;
        ads_real realNum;
        if(acedGetReal(_T("\n输入半径"),&realNum)!= RTNORM)
                return 0;
        ////垂直平面法向量
        AcGeVector3d vec(0,0,1);
        ////圆心
        AcGePoint3d ptCenter(pt[X],pt[Y],pt[Z]);
        AcDbCircle* pCircle = new AcDbCircle(ptCenter,vec,realNum);
        LoadEntity(pCircle);
        ////打印出类型为字符串的接收参数
        resbuf* pInput = acedGetArgs();
        CString str;
        while (pInput != NULL)
                if (pInput->resval.rstring != NULL)
                        acutPrintf(pInput->resval.rstring);
                        acutPrintf(_T("\n"));
                pInput = pInput->rbnext;
        ////构造圆形实体
        struct resbuf* rb ;
        rb = acutBuildList(
                RTDXF0,_T("CIRCLE"),
                62,1,//1 == RED
                10,ptCenter,
                40,realNum,//radius
                0);
        acedRetList(rb);
        return RTNORM;
//第三题;输入三点,以中间点为顶点,把旁边两条线做圆角,半径用户输入
static void TESTcomplexentcmd()
        ads_point pt1;
        ads_point pt2;
        ads_point pt3;
        ads_real r;
        if (acedGetPoint(NULL,_T("\n输入第一点"),pt1) != RTNORM)
                return;
        if (acedGetPoint(NULL,_T("\n输入第二点"),pt2) != RTNORM)
                return;
        if (acedGetPoint(NULL,_T("\n输入第三点"),pt3) != RTNORM)
                return;
        if (acedGetReal(_T("\n输入内切圆半径"),&r) != RTNORM)
                return;
        ////坐标维度转化
        AcGePoint3d pt3d1 = asPnt3d(pt1);
        AcGePoint3d pt3d2 = asPnt3d(pt2);
        AcGePoint3d pt3d3 = asPnt3d(pt3);
        ////构造两条直线计算顶点到切点的距离
        AcDbLine line1(pt3d2,pt3d1);
        AcDbLine line2(pt3d2,pt3d3);
        ////得到以PT2为顶点的两个向量
        AcGeVector3d v1(pt1[X]-pt2[X],pt1[Y]-pt2[Y],pt1[Z] - pt2[Z]);
        AcGeVector3d v2(pt3[X]-pt2[X],pt3[Y] - pt2[Y],pt3[Z] - pt2[Z]);
        AcGeVector3d v3(0,0,1);
        double PI = 3.1415926536;
        ////计算两个向量的夹角
        double angle = v1.angleTo(v2,v3);
        double angle1 = angle > PI ? 2 * PI - angle : angle;
        ////计算切点到顶点距离
        double dist = r / tan(angle1 / 2);
        ////切点1
        AcGePoint3d ptQ1;
        ////切点2
        AcGePoint3d ptQ2;
        ////找到切点
        line1.getPointAtDist(dist,ptQ1);
        line2.getPointAtDist(dist,ptQ2);
        ////求出bulge值(是圆心角1/4的正切值 - - ,之前当成正切值的四分之一了 - -!!!)
        double bulge;
        bulge = tan((PI - angle1) / 4);
        if(angle > 0 && angle <= PI)
                bulge = - bulge;
        AcDbPolyline* pl = new AcDbPolyline();
        AcGePoint2d pt2d1(pt3d1[X],pt3d1[Y]);
        AcGePoint2d pt2dq1(ptQ1[X],ptQ1[Y]);
        AcGePoint2d pt2dq2(ptQ2[X],ptQ2[Y]);
        AcGePoint2d pt2d3(pt3d3[X],pt3d3[Y]);
        pl->addVertexAt(0,pt2d1,0);
        pl->addVertexAt(1,pt2dq1,bulge);
        pl->addVertexAt(2,pt2dq2,0);
        pl->addVertexAt(3,pt2d3,0);
        LoadEntity(pl);
        CString out;
        out.Format(_T("\nangle:%.2f,bulge:%.2f,\ndist:%.2f\n,pt[z]:%.2f,%.2f,%.2f"),angle,bulge,dist,pt1[Z],pt2[Z],pt3[Z]);
        acutPrintf(out);
//第四题:定义一个全局命令,功能:使用类库创建一个块表记录,并插入块;
[it618postdisplay>0]
static void TESTaddblkcmd()
        ////根据用户的输入设置块表记录的名称
        CString blkName;
        if (acedGetString(Adesk::kFalse,_T("\n输入块名称"),blkName.GetBuffer(20)) != RTNORM)
                return;
        ////用完getBuffer要及时release
        blkName.ReleaseBuffer();
        AcDbBlockTable* pBlkTbl;
        acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlkTbl,AcDb::kForWrite);
        AcDbObjectId rcdId ;
        ////如果没有,添加新的
        if (!pBlkTbl->has(blkName))
                ////创建新块
                AcDbBlockTableRecord* pBlkTblRcd;
                pBlkTblRcd = new AcDbBlockTableRecord();
                pBlkTblRcd->setName(blkName);
                ////将块表记录添加到块表中,设置ID
                pBlkTbl->add(rcdId,pBlkTblRcd);
                ////向块表记录中添加实体
                AcGePoint3d ptStart(-10,0,0),ptEnd(10,0,0);
                AcDbLine* pLine1 = new AcDbLine(ptStart,ptEnd);
                ptStart.set(0,-10,0);
                ptEnd.set(0,10,0);
                AcDbLine *pLine2 = new AcDbLine(ptStart,ptEnd);
                AcGeVector3d vecNormal(0,0,1);
                AcDbCircle *pCircle = new AcDbCircle(AcGePoint3d::kOrigin,vecNormal,6);
                AcDbObjectId entId;
                pBlkTblRcd->appendAcDbEntity(entId,pLine1);
                pBlkTblRcd->appendAcDbEntity(entId,pLine2);
                pBlkTblRcd->appendAcDbEntity(entId,pCircle);
                ////关闭实体块表记录
                pLine1->close();
                pLine2->close();
                pCircle->close();
                pBlkTblRcd->close();
        }////如果已经有了,那就根据名字读出RECORDID,插入块参照时会用到
        else
                pBlkTbl->getAt(blkName,rcdId,false);////以读的方式获取
        ////在和用户交互之前,需要关闭块表,否则容易出错
        pBlkTbl->close();
        ////插入块
        ////获得用户输入的块参照的插入点
        ads_point pt;
        if(acedGetPoint(NULL,_T("\n输入块参照的插入点"),pt) != RTNORM)
                pBlkTbl->close();
                return;
        AcGePoint3d ptInsert = asPnt3d(pt);
        ////创建块参照
        AcDbBlockReference* pBlkRef = new AcDbBlockReference(ptInsert,rcdId);
        ////将块参照添加到模型空间
        AcDbBlockTableRecord* pBlkTblRcd2;
        pBlkTbl->getAt(ACDB_MODEL_SPACE,pBlkTblRcd2,AcDb::kForWrite);
        pBlkTblRcd2->appendAcDbEntity(pBlkRef);
        ////关闭数据库对象
        pBlkRef->close();
        pBlkTblRcd2->close();
        pBlkTbl->close();
[/it618postdisplay]
//第五题:定义一个命令,功能:让用户选择界面上的直线实体,然后修改所有选中实体的颜色;
static void TESTchangecolorcmd()
        ads_name ssname;
        resbuf strFilter;
        ////只能选择直线对象,构造选择集过滤器,只能选直线
        strFilter.resval.rstring = _T("LINE");
        strFilter.rbnext = NULL;
        strFilter.restype = 0;
        ////选择多个实体,传递NULL,让用户自己来选
        if(acedSSGet(NULL,NULL,NULL,&strFilter,ssname) != RTNORM)
                return;
        long len;
        acedSSLength(ssname,&len);
        CString ss;
        ss.Format(_T("已选中%d个实体"),len);
        acutPrintf(ss);
        ads_name entname;
        AcDbObjectId id;
        AcDbEntity* ent = NULL;
        CString strName;
        ////弹出颜色选择对话框,选中一个颜色,默认是当前层的颜色
        int nNewColor = SelColor();
        for (int i=0;i<len;i++)
                if (acedSSName(ssname, i, entname) == RTNORM)
                        ////根据名称得到ID
                        acdbGetObjectId(id,entname);
                        ////以写模式,根据ID索引到对象,并打开ENTITY
                        acdbOpenObject(ent,id,AcDb::OpenMode::kForWrite);
                        strName.Format(_T("%d"),ent->colorIndex());
                        acutPrintf(strName);
                        ent->setColorIndex(nNewColor);
                        ent->close();
        acedSSFree(ssname);
IMPLEMENT_ARX_ENTRYPOINT(CArxProject2App)
        ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject2App, TEST, lineCmd, lineCmd, ACRX_CMD_MODAL, NULL)
        //ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject2App, TEST, circlecmd, circlecmd, ACRX_CMD_MODAL, NULL)
        ACED_ADSSYMBOL_ENTRY_AUTO(CArxProject2App, circle, false)
        ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject2App, TEST, changecolorcmd, changecolorcmd, ACRX_CMD_MODAL, NULL)
        ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject2App, TEST, addblkcmd, addblkcmd, ACRX_CMD_MODAL, NULL)
        ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject2App, TEST, complexentcmd, complexentcmd, ACRX_CMD_MODAL, NULL)
发表于 2016-11-1 08:56:37 | 显示全部楼层
谢谢分享,慢慢学习
发表于 2016-11-4 15:41:19 | 显示全部楼层
学习!!!!!!!!!!!!!
发表于 2016-11-5 07:25:40 | 显示全部楼层
小手一抖 代码顺走 3Q3Q
发表于 2017-9-2 22:42:59 | 显示全部楼层
好代码,学习学习!!!
发表于 2017-9-6 08:58:07 | 显示全部楼层
感谢分享,学习中
GMT+8, 2026-11-22 10:36 , Processed in 0.397596 second(s), 18 queries , Gzip On, File On.
