查看: 1724|回复: 0
[曲线] (XD::Curve:Trim)直线边界裁剪曲线选择集
已领礼包: 51个
发表于 2016-10-28 13:24:03 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Curve:Trim
调用格式: (XD::Curve:Trim ss bound pt)
参数说明: ss ----- 曲线实体表、选择集
bound -------- 裁剪边界可以是直线实体,直线两点表,几何实体(kXLine,kLingSeg2d/3d)
pt -------------- 裁剪方向任意点
返回值: T
函数简介: 直线边界裁剪曲线选择集,裁剪边界可以是直线实体,直线两点表,几何实体(kXLine,kLingSeg2d/3d)
函数来源: 原创
函数作者: Lispboy
适用版本: XDRX API
最后更新时间: 2016-10-28
备注: 裁剪边界可以是直线实体,直线两点表,几何实体(kXLine,kLingSeg2d/3d)
演示图片: -
(defun XD::Curve:Trim (ss bound pt / #direction #pointOnLine dis1 p1 p2 tf x xline)
  (if (= (type ss) 'PICKSET)
    (setq ss (xdrx_pickset->ents ss))
  (cond
    ((= (type bound) 'LIST))
    ((= (type bound) 'ENAME)
      (if (setq tf (xdge::type bound))
        (progn
          (if (xdrx_string_regexps "kLine[2|3]d" tf)
            (progn
              (xdge::getpropertyvalue bound "pointOnLine" "direction")
              (setq bound (list #pointOnLine (mapcar
                                               #pointOnLine
                                               #direction
            (setq bound (xdge::getpropertyvalue bound "hasstartpoint"
                                                "hasendpoint"
        (setq bound (xdrx_getpropertyvalue bound "vertices"))
  (setq p1 (car bound)
        p2 (cadr bound)
        xline (xdge::constructor "kLine3d" p1 p2)
  (xdrx_setmark)
  (mapcar
    '(lambda (x)
       (apply
         'xdrx_curve_getsplitcurves
         (cons x (xdrx_entity_intersectwith x xline))
    ss
  (setq ss (append
             ss
             (xdrx_pickset->ents (xdrx_getss))
        dis1 (xdrx_point_dist2Line pt p1 p2)
  (mapcar
    '(lambda (x)
       (if (> (* dis1 (xdrx_point_dist2line (xdrx_getpropertyvalue x "midpoint")
                                            p1 p2
              ) 0
         (xdrx_entity_delete x)
    ss
  (xdge::free xline)
  t
测试代码:
(defun c:tt()
   (if (and (setq ss (ssget '((0 . "*line,arc,circle,ellipse"))))
            (setq e (xdrx_entsel "\n拾取裁剪边界<退出>:" '((0 . "line"))))
            (setq pt (getpoint (xdrx_getpropertyvalue (car e) "midpoint") "\n裁剪方向<退出>:"))
      (xd::curve:trim ss (car e) pt)
   (princ)
GMT+8, 2026-11-1 10:53 , Processed in 0.447237 second(s), 31 queries , Gzip On.
