查看: 2637|回复: 3
[分享] 【已解决】ObjectARX如何亮显一个实体?就像选中那样亮显
已领礼包: 112个
发表于 2016-11-14 17:09:33 | 显示全部楼层 |阅读模式
如上图所示,点击对象时可实现亮显效果,请问arx如何实现亮显一个实体?
已领礼包: 13个
发表于 2016-11-14 17:21:34 | 显示全部楼层
显示夹点? LISP怎么做,ARX一样
acedSSSetFirst Global Function int
acedSSSetFirst(
const ads_name pset,
const ads_name unused);
pset Set of entities to be added to the pickfirst selection set and on which grips will be displayed
unused Ignored
This function sets which objects are selected and gripped.
The parameters have the following data type definition:
typedef long ads_name[2];
The selection set of objects specified by the gset argument are gripped, and the selection set of objects specified by pset are both gripped and selected. If any objects are common to both selection sets, acedSSSetFirst() grips and selects the selection set specified by pset only (it does not grip the gset set).
If gset is NULL and pset is specified, acedSSSetFirst() grips and selects pset. If gset and pset are NULL, acedSSSetFirst() turns off any existing grips and selections.
You are responsible for creating a valid selection set. For example, you may need to verify that a background paper space viewport (DXF group code 69) is not included in the selection set. You may also need to ensure that selected objects belong to the current layout.
Note The addCommand() optional flags ACRX_CMD_USEPICKSET and ACRX_CMD_REDRAW must be used in order for acedSSSetFirst() to work.
Do not call acedSSSetFirst() when AutoCAD is in the middle of executing a command.
Include File
acedads.h
已领礼包: 112个
 楼主| 发表于 2016-11-14 17:37:03 | 显示全部楼层
谢谢指导!
下面代码可实现将选择的标注亮显
        static void YTMsupportF1(void)
                // Add your code for command YTMsupport.F1 here
                ads_name sset;////选择集名称
                //建议缓冲区链表
                struct resbuf *rb;//结果缓冲表
                rb=acutBuildList(RTDXF0,_T("DIMENSION"),RTNONE);
                if(acedSSGet(NULL,NULL,NULL,rb,sset)==RTNORM)//if(acedSSGet(_T("X"),NULL,NULL,rb,sset)==RTNORM)
                        long length=0;
                        acedSSLength(sset,&length);
                        acutPrintf(TEXT("\n实体数:%d"),length);
                        acedSSSetFirst(sset,NULL);
                else
                        acutPrintf(_T("\n您退出了程序!"));
                //关闭链表
                acutRelRb(rb);
                //关闭选择集
                acedSSFree(sset);
评分
参与人数 1D豆 +6 收起 理由
LoveArx + 6 有始有终奖!
查看全部评分
已领礼包: 780个
发表于 2016-11-14 19:23:49 | 显示全部楼层
很帅!很帅!很帅!
GMT+8, 2026-11-2 22:13 , Processed in 0.473860 second(s), 45 queries , Gzip On.
