查看: 1029|回复: 0
[分享] 数组 集合 互转
发表于 2016-11-18 10:59:19 | 显示全部楼层 |阅读模式
  1. ' http://www.cnhup.com
  2. '================================
  3. 'VBA数组转换到集合CollectionToArray
  4. Public Function ArrayToCollection( _
  5.   arr As Variant, ByRef Coll As Collection) _
  6.   As Boolean
  7. Dim Ndx As Long
  8. Dim KeyVal As String
  9. If IsArray(arr) = False Then
  10.     ArrayToCollection = False
  11.     Exit Function
  12. End If
  13. On Error GoTo ErrH:
  14. Select Case NumberOfArrayDimensions(arr:=arr)
  15.     Case 0
  16.         ArrayToCollection = False
  17.         Exit Function
  18.
  19.     Case 1
  20.         For Ndx = LBound(arr) To UBound(arr)
  21.             Coll.Add Item:=arr(Ndx)
  22.         Next Ndx
  23.
  24.     Case 2
  25.         For Ndx = LBound(arr, 1) To UBound(arr, 1)
  26.             KeyVal = arr(Ndx, 1)
  27.             If Trim(KeyVal) = vbNullString Then
  28.                 Coll.Add Item:=arr(Ndx, 1)
  29.             Else
  30.                 Coll.Add Item:=arr(Ndx, 0), Key:=KeyVal
  31.             End If
  32.         Next Ndx
  33.
  34.     Case Else
  35.         ArrayToCollection = False
  36.         Exit Function
  37. End Select
  38. ArrayToCollection = True
  39. Exit Function
  40. ErrH:
  41.     ArrayToCollection = False
  42. End Function
  43. '================================
  44. ' VBA集合转换到数组CollectionToArray
  45. '
  46. ' http://www.cnhup.com
  47. '================================
  48. Public Function CollectionToArray( _
  49.   Coll As Collection, arr As Variant) _
  50.   As Boolean
  51. Dim V As Variant
  52. Dim Ndx As Long
  53. If Coll Is Nothing Then
  54.     CollectionToArray = False
  55.     Exit Function
  56. End If
  57. If IsArray(arr) = False Then
  58.     CollectionToArray = False
  59.     Exit Function
  60. End If
  61. If IsArrayDynamic(arr:=arr) = False Then
  62.     CollectionToArray = False
  63.     Exit Function
  64. End If
  65. If Coll.Count < 1 Then
  66.     CollectionToArray = False
  67.     Exit Function
  68. End If
  69.
  70. ReDim arr(1 To Coll.Count)
  71. For Ndx = 1 To Coll.Count
  72.     If IsObject(Coll(Ndx)) = True Then
  73.         Set arr(Ndx) = Coll(Ndx)
  74.     Else
  75.         arr(Ndx) = Coll(Ndx)
  76.     End If
  77. Next Ndx
  78. CollectionToArray = True
  79. End Function
GMT+8, 2026-11-22 09:57 , Processed in 0.258423 second(s), 8 queries , Gzip On, File On.
