查看: 1177|回复: 0
[求助] 请教如何改变视口中的视图中心点,显示不同的内容
发表于 2016-11-18 13:08:27 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
Dim textObj As AcadText
Dim textString As String
Dim insertionPoint(0 To 2) As Double
Dim pp(0 To 2) As Double
ThisDrawing.Application.Documents.Add
For i = 0 To 5          '写文字
    insertionPoint(0) = i * 200: insertionPoint(1) = 0: insertionPoint(2) = 0:  '文字插入点
    textString = Str(i + 1)
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, 50)
Next i
ZoomAll
Dim mylayout As AcadLayout          '定义布局
Dim myVport As AcadPViewport        '定义视口
For i = 0 To 5          '新建5个布局
     Set mylayout = ThisDrawing.Layouts.Add("P" + LTrim(Str(i + 1))) '新建布局
     ThisDrawing.ActiveLayout = mylayout        '激活布局
     ThisDrawing.MSpace = True
    '获取当前布局中的视口
    Set myVport = ThisDrawing.ActivePViewport
    myVport.Display True
    myVport.Width = 200             '视口宽
    myVport.height = 150         '视口高
    myVport.CustomScale = 1
    pp(0) = 125: pp(1) = 100: pp(2) = 0         '视口中心
    myVport.Center = pp
    ThisDrawing.MSpace = False
    ZoomAll
Next i
'让 p1,p2,p3,p4,p5 视口分别显示 对应的1,2,3,4,5数字
'如何改变视口中视图的中心点
End Sub
GMT+8, 2026-11-3 07:34 , Processed in 0.387497 second(s), 28 queries , Gzip On.
