查看: 1713|回复: 1
[每日一码] 对一个图形AUDIT,PURGE,SAVE,CLOSE操作
发表于 2016-11-23 10:11:32 | 显示全部楼层 |阅读模式
;;; APQC.LSP, Audit-->Purge-->Qsave-->Close
;;; Mehre Taban Co., Mehrdad Ahankhah, www.irancad.com, ahankhah@irancad.com
(vl-load-com)
(defun C:APQC ()
    (MT:Do:Audit)
    (MT:Do:PurgeAllNested)
    (if (MT:Do:Qsave)
        (MT:Do:CloseDwg)
(defun MT:Do:Audit () (command "_.Audit" "y" ""))
(defun MT:Do:PurgeAllNested (/ Cont)
    (princ "\nPurging unused objects...\n")
    (setq Cont T)
    (while Cont
        (MT:Do:PurgeALL)
        (if (zerop (boole 1 1 (getvar 'Dbmod)))
            (progn (acad-pop-dbmod) (setq Cont nil))
                   (if (not (zerop (getvar 'Dbmod)))
                       (progn (MT:Do:Qsave) (acad-pop-dbmod))
                   (princ "\n\tPurging unused nested objects...")
            )                                     ; if false
        )                                         ; if
    )                                             ; while
    (princ "\nPurging unused objects done.\n")
(defun MT:Do:PurgeALL ()
    (vla-PurgeAll
        (vla-get-ActiveDocument
            (vlax-get-acad-object)
    ); Visual Lisp version
    ;;(command "_.PURGE" "_All" "*" "_No"); AutoLISP version
(defun MT:Do:Qsave (/ ret)
    (if (zerop (getvar "Dwgtitled"))
        (progn (alert "Drawing has no name, QSAVEing is not probable.")
               (setq ret nil)
        (progn (command "_.QSAVE") (setq ret T))
    ret
(defun MT:Do:CloseDwg ()
    (command "_.CLOSE")
    (and (= 1 (getvar 'cmdactive)) (command "_Yes"))
(C:APQC)
评分
参与人数 1D豆 +5 收起 理由
/db_自贡黄明儒_ + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 1094个
发表于 2021-11-2 01:18:15 | 显示全部楼层
感谢分享对一个图形AUDIT,PURGE,SAVE,CLOSE操作
GMT+8, 2026-11-3 00:58 , Processed in 0.574392 second(s), 32 queries , Gzip On.
