查看: 1871|回复: 0
[每日一码] 把选择的实体写到外部DWG文件
发表于 2016-11-23 18:03:11 | 显示全部楼层 |阅读模式
static void WblockIds() {
        resbuf *rb = acutNewRb(RTSTR);
        if (acedGetFileD(L"Export file", nullptr, L"dwg", 32, rb) != RTNORM)
                return;
        AcString filename = rb->resval.rstring;   acutRelRb(rb);
        ads_name ss;
        if (acedSSGet(nullptr, nullptr, nullptr, nullptr, ss) != RTNORM)
                return;
        Adesk::Int32 nSel = 0;
        acedSSLength(ss, &nSel);
        if (nSel == 0) {  acedSSFree(ss); return; }
        AcDbObjectIdArray ids; ids.setPhysicalLength(nSel);
        for (int i = 0; i < nSel; i++) {
                ads_name en; acedSSName(ss, i, en);
                AcDbObjectId id;
                if (acdbGetObjectId(id, en) == Acad::eOk) ids.append(id);
        acedSSFree(ss);
        Acad::ErrorStatus es;
        AcDbDatabase *pOutputDb = new AcDbDatabase(false);
        es = pOutputDb->readDwgFile(filename, AcDbDatabase::OpenMode::kTryForReadShare);
        AcDbObjectId idModelSpace =
                AcDbSymbolUtilities::servicesPtr()->blockModelSpaceId(pOutputDb);
        AcDbIdMapping idMap;
        es = acdbCurDwg()->wblockCloneObjects(ids, idModelSpace, idMap, AcDb::DuplicateRecordCloning::kDrcReplace);
        pOutputDb->closeInput(true);
        es = pOutputDb->saveAs(filename);
        delete pOutputDb;
GMT+8, 2026-11-22 11:15 , Processed in 0.294115 second(s), 8 queries , Gzip On, File On.
