查看: 1689|回复: 3
[求助] c#如何将2条首尾相连的样条曲线合并成一条样条曲线?
发表于 2016-11-23 22:45:46 | 显示全部楼层 |阅读模式
c#如何将2条首尾相连的样条曲线合并成一条样条曲线?就是类似Join命令
发表于 2016-11-23 23:15:36 | 显示全部楼层
AcDbJoinEntityPE::joinEntity(...)
几何库:
AcGeNurbCurve3d::joinWith Function
AcGeNurbCurve3d &
joinWith(
const AcGeNurbCurve3d& curve);
curveInput spline to be joined with this spline
Recomputes spline by joining input spline to this spline. Neither spline may be closed and the start point of the input spline must be equal to the endpoint of this spline.
 楼主| 发表于 2016-11-23 23:34:28 | 显示全部楼层
谢谢提醒,不是jionwith,是JoinEntity
发表于 2016-11-23 23:48:47 | 显示全部楼层
joinWith是ARX 几何库的方法。
GMT+8, 2026-11-3 08:30 , Processed in 0.433549 second(s), 34 queries , Gzip On.
