查看: 8189|回复: 15
[原创] VL开头的函数到底有哪些? 看看就知道了
发表于 2016-11-26 00:56:39 | 显示全部楼层 |阅读模式
所有的VL开头的函数都在这了,2323个函数
(defun c:get-vl-func ()
  (setq a (atoms-family 1))
  (setq        b (mapcar '(lambda (x)
                     (if (xdrx_string_regexps "^vl(.*)-" x)
                       (strcase x t)
                  a
  (setq c (vl-remove nil b))
  (setq d (vl-sort c '(lambda (x y) (< x y))))
  (xd::list:tofile "c:\\vl-func.txt" d)  ;;保存到C盘vl-func.txt
vl-acad-defun
vl-acad-undefun
vl-arx-import
vl-bb-ref
vl-bb-set
vl-bt
vl-bt-off
vl-bt-on
vl-catch-all-apply
vl-catch-all-error-message
vl-catch-all-error-p
vl-cmdf
vl-consp
vl-directory-files
vl-doc-export
vl-doc-import
vl-doc-ref
vl-doc-set
vl-every
vl-exit-with-error
vl-exit-with-value
vl-file-copy
vl-file-delete
vl-file-directory-p
vl-file-rename
vl-file-size
vl-file-systime
vl-filename-base
vl-filename-directory
vl-filename-extension
vl-filename-mktemp
vl-get-resource
vl-infp
vl-init
vl-list*
vl-list->string
vl-list-exported-functions
vl-list-length
vl-list-loaded-vlx
vl-load-all
vl-load-com
vl-load-reactors
vl-member-if
vl-member-if-not
vl-mkdir
vl-nanp
vl-position
vl-prin1-to-string
vl-princ-to-string
vl-propagate
vl-registry-delete
vl-registry-descendents
vl-registry-read
vl-registry-write
vl-remove
vl-remove-if
vl-remove-if-not
vl-some
vl-sort
vl-sort-i
vl-string->list
vl-string-elt
vl-string-left-trim
vl-string-mismatch
vl-string-position
vl-string-right-trim
vl-string-search
vl-string-subst
vl-string-translate
vl-string-trim
vl-symbol-name
vl-symbol-value
vl-symbolp
vl-unload-vlx
vl-vbaload
vl-vbarun
vl-vlx-loaded-p
vla-activate
vla-add
vla-add3dface
vla-add3dmesh
vla-add3dpoly
vla-addarc
vla-addattribute
vla-addbox
vla-addcircle
vla-addcone
vla-addcustominfo
vla-addcustomobject
vla-addcylinder
vla-adddim3pointangular
vla-adddimaligned
vla-adddimangular
vla-adddimarc
vla-adddimdiametric
vla-adddimordinate
vla-adddimradial
vla-adddimradiallarge
vla-adddimrotated
vla-addellipse
vla-addellipticalcone
vla-addellipticalcylinder
vla-addextrudedsolid
vla-addextrudedsolidalongpath
vla-addfitpoint
vla-addhatch
vla-additems
vla-addleader
vla-addleaderline
vla-addleaderlineex
vla-addlightweightpolyline
vla-addline
vla-addmenuitem
vla-addminsertblock
vla-addmleader
vla-addmline
vla-addmtext
vla-addobject
vla-addpoint
vla-addpolyfacemesh
vla-addpolyline
vla-addpviewport
vla-addraster
vla-addray
vla-addregion
vla-addrevolvedsolid
vla-addsection
vla-addseparator
vla-addshape
vla-addsolid
vla-addsphere
vla-addspline
vla-addsubmenu
vla-addtable
vla-addtext
vla-addtolerance
vla-addtoolbarbutton
vla-addtorus
vla-addtrace
vla-addvertex
vla-addwedge
vla-addxline
vla-addxrecord
vla-anglefromxaxis
vla-angletoreal
vla-angletostring
vla-appendinnerloop
vla-appenditems
vla-appendouterloop
vla-appendvertex
vla-arraypolar
vla-arrayrectangular
vla-attachexternalreference
vla-attachtoolbartoflyout
vla-auditinfo
vla-bind
vla-block
vla-boolean
vla-checkinterference
vla-clear
vla-clearsubselection
vla-cleartablestyleoverrides
vla-clipboundary
vla-close
vla-converttoanonymousblock
vla-converttostaticblock
vla-copy
vla-copyfrom
vla-copyobjects
vla-copyprofile
vla-createcellstyle
vla-createcellstylefromstyle
vla-createcontent
vla-createentry
vla-createjog
vla-createtypedarray
vla-delete
vla-deletecellcontent
vla-deletecellstyle
vla-deletecolumns
vla-deleteconfiguration
vla-deletecontent
vla-deletefitpoint
vla-deleteprofile
vla-deleterows
vla-detach
vla-display
vla-displayplotpreview
vla-distancetoreal
vla-dock
vla-elevateorder
vla-enablemergeall
vla-endundomark
vla-erase
vla-eval
vla-evaluate
vla-explode
vla-export
vla-exportprofile
vla-fieldcode
vla-float
vla-formatvalue
vla-generatelayout
vla-generatesectiongeometry
vla-generateusagedata
vla-get-action
vla-get-active
vla-get-activedimstyle
vla-get-activedocument
vla-get-activeinvproject
vla-get-activelayer
vla-get-activelayout
vla-get-activelinetype
vla-get-activematerial
vla-get-activeprofile
vla-get-activepviewport
vla-get-activeselectionset
vla-get-activespace
vla-get-activetextstyle
vla-get-activeucs
vla-get-activeviewport
vla-get-adcinsertunitsdefaultsource
vla-get-adcinsertunitsdefaulttarget
vla-get-adjustforbackground
vla-get-affectsgraphics
vla-get-algorithm
vla-get-alignment
vla-get-alignmentpointacquisition
vla-get-alignspace
vla-get-allowedvalues
vla-get-allowlongsymbolnames
vla-get-allowmanualheights
vla-get-allowmanualpositions
vla-get-altfontfile
vla-get-altitude
vla-get-altrounddistance
vla-get-altsubunitsfactor
vla-get-altsubunitssuffix
vla-get-altsuppressleadingzeros
vla-get-altsuppresstrailingzeros
vla-get-altsuppresszerofeet
vla-get-altsuppresszeroinches
vla-get-alttabletmenufile
vla-get-alttextprefix
vla-get-alttextsuffix
vla-get-alttoleranceprecision
vla-get-alttolerancesuppressleadingzeros
vla-get-alttolerancesuppresstrailingzeros
vla-get-alttolerancesuppresszerofeet
vla-get-alttolerancesuppresszeroinches
vla-get-altunits
vla-get-altunitsformat
vla-get-altunitsprecision
vla-get-altunitsscale
vla-get-angle
vla-get-angleformat
vla-get-anglevertex
vla-get-annotation
vla-get-annotative
vla-get-application
vla-get-arcendparam
vla-get-arclength
vla-get-arcpoint
vla-get-arcsmoothness
vla-get-arcstartparam
vla-get-area
vla-get-arrowhead1block
vla-get-arrowhead1type
vla-get-arrowhead2block
vla-get-arrowhead2type
vla-get-arrowheadblock
vla-get-arrowheadsize
vla-get-arrowheadtype
vla-get-arrowsize
vla-get-arrowsymbol
vla-get-associativehatch
vla-get-attachmentpoint
vla-get-author
vla-get-autoaudit
vla-get-automaticplotlog
vla-get-autosaveinterval
vla-get-autosavepath
vla-get-autosnapaperture
vla-get-autosnapaperturesize
vla-get-autosnapmagnet
vla-get-autosnapmarker
vla-get-autosnapmarkercolor
vla-get-autosnapmarkersize
vla-get-autosnaptooltip
vla-get-autotrackingveccolor
vla-get-autotracktooltip
vla-get-axisdirection
vla-get-axisposition
vla-get-backgroundcolor
vla-get-backgroundfill
vla-get-backgroundlinescolor
vla-get-backgroundlineshiddenline
vla-get-backgroundlineslayer
vla-get-backgroundlineslinetype
vla-get-backgroundlineslinetypescale
vla-get-backgroundlineslineweight
vla-get-backgroundlinesplotstylename
vla-get-backgroundlinesvisible
vla-get-backward
vla-get-bank
vla-get-basepoint
vla-get-baseradius
vla-get-batchplotprogress
vla-get-beeponerror
vla-get-bigfontfile
vla-get-bitflags
vla-get-block
vla-get-blockcolor
vla-get-blockconnectiontype
vla-get-blockrotation
vla-get-blocks
vla-get-blockscale
vla-get-blockscaling
vla-get-blue
vla-get-bookname
vla-get-bottomheight
vla-get-breaksenabled
vla-get-breaksize
vla-get-breakspacing
vla-get-brightness
vla-get-canonicalmedianame
vla-get-caption
vla-get-categoryname
vla-get-center
vla-get-centermarksize
vla-get-centerplot
vla-get-centerpoint
vla-get-centertype
vla-get-centroid
vla-get-check
vla-get-chordpoint
vla-get-circumference
vla-get-clipped
vla-get-clippingenabled
vla-get-closed
vla-get-closed2
vla-get-color
vla-get-colorbookpath
vla-get-colorindex
vla-get-colormethod
vla-get-colorname
vla-get-colorscheme
vla-get-columns
vla-get-columnspacing
vla-get-commanddisplayname
vla-get-comment
vla-get-comments
vla-get-configfile
vla-get-configname
vla-get-constant
vla-get-constantwidth
vla-get-constrain
vla-get-contentblockname
vla-get-contentblocktype
vla-get-contenttype
vla-get-continuousplotlog
vla-get-contourlinespersurface
vla-get-contrast
vla-get-controlpoints
vla-get-coordinate
vla-get-coordinates
vla-get-count
vla-get-creaselevel
vla-get-creasetype
vla-get-createbackup
vla-get-currentsectiontype
vla-get-cursorsize
vla-get-curvetangencylinescolor
vla-get-curvetangencylineslayer
vla-get-curvetangencylineslinetype
vla-get-curvetangencylineslinetypescale
vla-get-curvetangencylineslineweight
vla-get-curvetangencylinesplotstylename
vla-get-curvetangencylinesvisible
vla-get-customdictionary
vla-get-customiconpath
vla-get-customscale
vla-get-cvhulldisplay
vla-get-database
vla-get-decimalseparator
vla-get-defaultinterneturl
vla-get-defaultoutputdevice
vla-get-defaultplotstyleforlayer
vla-get-defaultplotstyleforobjects
vla-get-defaultplotstyletable
vla-get-defaultplottofilepath
vla-get-degree
vla-get-degree2
vla-get-delta
vla-get-demandloadarxapp
vla-get-description
vla-get-destinationblock
vla-get-destinationfile
vla-get-diameter
vla-get-dictionaries
vla-get-dimconstrdesc
vla-get-dimconstrexpression
vla-get-dimconstrform
vla-get-dimconstrname
vla-get-dimconstrreference
vla-get-dimconstrvalue
vla-get-dimensionlinecolor
vla-get-dimensionlineextend
vla-get-dimensionlinetype
vla-get-dimensionlineweight
vla-get-dimline1suppress
vla-get-dimline2suppress
vla-get-dimlineinside
vla-get-dimlinesuppress
vla-get-dimstyles
vla-get-dimtxtdirection
vla-get-direction
vla-get-directionvector
vla-get-display
vla-get-displaygrips
vla-get-displaygripswithinblocks
vla-get-displaylayouttabs
vla-get-displaylocked
vla-get-displayolescale
vla-get-displayscreenmenu
vla-get-displayscrollbars
vla-get-displaysilhouette
vla-get-dockedvisiblelines
vla-get-dockstatus
vla-get-document
vla-get-documents
vla-get-doglegged
vla-get-dogleglength
vla-get-drafting
vla-get-drawingdirection
vla-get-drawleaderordertype
vla-get-drawmleaderordertype
vla-get-driverspath
vla-get-dwfformat
vla-get-edgeextensiondistances
vla-get-effectivename
vla-get-elevation
vla-get-elevationmodelspace
vla-get-elevationpaperspace
vla-get-enable
vla-get-enableblockrotation
vla-get-enableblockscale
vla-get-enabledogleg
vla-get-enableframetext
vla-get-enablelanding
vla-get-enablestartupdialog
vla-get-endangle
vla-get-enddraftangle
vla-get-enddraftmagnitude
vla-get-endparameter
vla-get-endpoint
vla-get-endsmoothcontinuity
vla-get-endsmoothmagnitude
vla-get-endsubmenulevel
vla-get-endtangent
vla-get-enterprisemenufile
vla-get-entitycolor
vla-get-entitytransparency
vla-get-explodable
vla-get-extensionlinecolor
vla-get-extensionlineextend
vla-get-extensionlineoffset
vla-get-extensionlineweight
vla-get-extline1endpoint
vla-get-extline1linetype
vla-get-extline1point
vla-get-extline1startpoint
vla-get-extline1suppress
vla-get-extline2endpoint
vla-get-extline2linetype
vla-get-extline2point
vla-get-extline2startpoint
vla-get-extline2suppress
vla-get-extlinefixedlen
vla-get-extlinefixedlensuppress
vla-get-facecount
vla-get-fade
vla-get-feature
vla-get-fieldlength
vla-get-file
vla-get-filedependencies
vla-get-filename
vla-get-files
vla-get-filesize
vla-get-fingerprintguid
vla-get-firstsegmentangleconstraint
vla-get-fit
vla-get-fitpoints
vla-get-fittolerance
vla-get-floatingrows
vla-get-flowdirection
vla-get-flyout
vla-get-fontfile
vla-get-fontfilemap
vla-get-forcelineinside
vla-get-foregroundlinescolor
vla-get-foregroundlinesedgetransparency
vla-get-foregroundlinesfacetransparency
vla-get-foregroundlineshiddenline
vla-get-foregroundlineslayer
vla-get-foregroundlineslinetype
vla-get-foregroundlineslinetypescale
vla-get-foregroundlineslineweight
vla-get-foregroundlinesplotstylename
vla-get-foregroundlinesvisible
vla-get-foundpath
vla-get-fractionformat
vla-get-freeze
vla-get-fullcrcvalidation
vla-get-fullfilename
vla-get-fullname
vla-get-fullscreentrackingvector
vla-get-generationoptions
vla-get-geoimagebrightness
vla-get-geoimagecontrast
vla-get-geoimagefade
vla-get-geoimageheight
vla-get-geoimageposition
vla-get-geoimagewidth
vla-get-geolocate
vla-get-gradientangle
vla-get-gradientcentered
vla-get-gradientcolor1
vla-get-gradientcolor2
vla-get-gradientname
vla-get-graphicswinlayoutbackgrndcolor
vla-get-graphicswinmodelbackgrndcolor
vla-get-green
vla-get-gridon
vla-get-gripcolorselected
vla-get-gripcolorunselected
vla-get-gripsize
vla-get-groups
vla-get-handle
vla-get-hasattributes
vla-get-ha**tensiondictionary
vla-get-hasleader
vla-get-hassheetview
vla-get-hassubselection
vla-get-hasvpassociation
vla-get-hatchobjecttype
vla-get-hatchstyle
vla-get-headersuppressed
vla-get-height
vla-get-helpfilepath
vla-get-helpstring
vla-get-history
vla-get-historylines
vla-get-horizontaltextposition
vla-get-horzcellmargin
vla-get-hwnd
vla-get-hyperlinkbase
vla-get-hyperlinkdisplaycursor
vla-get-hyperlinks
vla-get-imagefile
vla-get-imageframehighlight
vla-get-imageheight
vla-get-imagevisibility
vla-get-imagewidth
vla-get-incrementalsavepercent
vla-get-index
vla-get-indicatorfillcolor
vla-get-indicatortransparency
vla-get-insertionpoint
vla-get-insunits
vla-get-insunitsfactor
vla-get-intensitycolorscheme
vla-get-intersectionboundarycolor
vla-get-intersectionboundarydivisionlines
vla-get-intersectionboundarylayer
vla-get-intersectionboundarylinetype
vla-get-intersectionboundarylinetypescale
vla-get-intersectionboundarylineweight
vla-get-intersectionboundaryplotstylename
vla-get-intersectionboundaryvisible
vla-get-intersectionfillcolor
vla-get-intersectionfillfacetransparency
vla-get-intersectionfillhatchangle
vla-get-intersectionfillhatchpatternname
vla-get-intersectionfillhatchpatterntype
vla-get-intersectionfillhatchscale
vla-get-intersectionfillhatchspacing
vla-get-intersectionfilllayer
vla-get-intersectionfilllinetype
vla-get-intersectionfilllinetypescale
vla-get-intersectionfilllineweight
vla-get-intersectionfillplotstylename
vla-get-intersectionfillvisible
vla-get-invisible
vla-get-iscloned
vla-get-isdynamicblock
vla-get-islayout
vla-get-ismodified
vla-get-isopenwidth
vla-get-isownerxlated
vla-get-ispartial
vla-get-isperiodic
vla-get-isplanar
vla-get-isprimary
vla-get-isquiescent
vla-get-isrational
vla-get-issuer
vla-get-isxref
vla-get-itemname
vla-get-jogangle
vla-get-joglocation
vla-get-justification
vla-get-key
vla-get-keyboardaccelerator
vla-get-keyboardpriority
vla-get-keylength
vla-get-keywords
vla-get-knotparameterization
vla-get-knots
vla-get-label
vla-get-labelblockid
vla-get-landinggap
vla-get-largebuttons
vla-get-lastheight
vla-get-lastsavedby
vla-get-latitude
vla-get-layer
vla-get-layeron
vla-get-layerpropertyoverrides
vla-get-layers
vla-get-layerstate
vla-get-layout
vla-get-layoutcreateviewport
vla-get-layoutcrosshaircolor
vla-get-layoutdisplaymargins
vla-get-layoutdisplaypaper
vla-get-layoutdisplaypapershadow
vla-get-layoutid
vla-get-layouts
vla-get-layoutshowplotsetup
vla-get-leader1point
vla-get-leader2point
vla-get-leadercount
vla-get-leaderlinecolor
vla-get-leaderlinetype
vla-get-leaderlinetypeid
vla-get-leaderlineweight
vla-get-leadertype
vla-get-left
vla-get-length
vla-get-lenslength
vla-get-limits
vla-get-linearscalefactor
vla-get-linespacingdistance
vla-get-linespacingfactor
vla-get-linespacingstyle
vla-get-linetype
vla-get-linetypegeneration
vla-get-linetypes
vla-get-linetypescale
vla-get-lineweight
vla-get-lineweightdisplay
vla-get-livesectionenabled
vla-get-loadacadlspinalldocuments
vla-get-localeid
vla-get-lock
vla-get-lockaspectratio
vla-get-locked
vla-get-lockposition
vla-get-logfileon
vla-get-logfilepath
vla-get-longitude
vla-get-lowerleftcorner
vla-get-macro
vla-get-maindictionary
vla-get-maintainassociativity
vla-get-majoraxis
vla-get-majorradius
vla-get-mask
vla-get-material
vla-get-materials
vla-get-maxactiveviewports
vla-get-maxautocadwindow
vla-get-maxleadersegmentspoints
vla-get-mclose
vla-get-mdensity
vla-get-measurement
vla-get-menubar
vla-get-menufile
vla-get-menufilename
vla-get-menugroups
vla-get-menus
vla-get-minimumtableheight
vla-get-minimumtablewidth
vla-get-minoraxis
vla-get-minorradius
vla-get-mlinescale
vla-get-mode
vla-get-modelcrosshaircolor
vla-get-modelspace
vla-get-modeltype
vla-get-modelview
vla-get-momentofinertia
vla-get-monochrome
vla-get-mrunumber
vla-get-mspace
vla-get-mtextattribute
vla-get-mtextattributecontent
vla-get-mtextboundarywidth
vla-get-mtextdrawingdirection
vla-get-mvertexcount
vla-get-name
vla-get-namenomnemonic
vla-get-nclose
vla-get-ndensity
vla-get-normal
vla-get-notes
vla-get-numberofcontrolpoints
vla-get-numberofcopies
vla-get-numberoffaces
vla-get-numberoffitpoints
vla-get-numberofloops
vla-get-numberofvertices
vla-get-numcellstyles
vla-get-numcrosssections
vla-get-numguidepaths
vla-get-numvertices
vla-get-nvertexcount
vla-get-objectid
vla-get-objectname
vla-get-objectsnapmode
vla-get-objectsortbyplotting
vla-get-objectsortbypsoutput
vla-get-objectsortbyredraws
vla-get-objectsortbyregens
vla-get-objectsortbyselection
vla-get-objectsortbysnap
vla-get-obliqueangle
vla-get-oleitemtype
vla-get-olelaunch
vla-get-oleplotquality
vla-get-olequality
vla-get-olesourceapp
vla-get-onmenubar
vla-get-opensave
vla-get-origin
vla-get-orthoon
vla-get-output
vla-get-overridecenter
vla-get-overwritepropchanged
vla-get-ownerid
vla-get-pagesetupoverridestemplatefile
vla-get-paperspace
vla-get-paperunits
vla-get-parent
vla-get-password
vla-get-path
vla-get-patternangle
vla-get-patterndouble
vla-get-patternname
vla-get-patternscale
vla-get-patternspace
vla-get-patterntype
vla-get-perimeter
vla-get-periodic
vla-get-pickadd
vla-get-pickauto
vla-get-pickboxsize
vla-get-pickdrag
vla-get-pickfirst
vla-get-pickfirstselectionset
vla-get-pickgroup
vla-get-plot
vla-get-plotconfigurations
vla-get-plothidden
vla-get-plotlegacy
vla-get-plotlogfilepath
vla-get-plotorigin
vla-get-plotpolicy
vla-get-plotrotation
vla-get-plotstylename
vla-get-plottable
vla-get-plottype
vla-get-plotviewportborders
vla-get-plotviewportsfirst
vla-get-plotwithlineweights
vla-get-plotwithplotstyles
vla-get-polartrackingvector
vla-get-position
vla-get-postscriptprologfile
vla-get-preferences
vla-get-preset
vla-get-primaryunitsprecision
vla-get-principaldirections
vla-get-principalmoments
vla-get-printerconfigpath
vla-get-printerdescpath
vla-get-printerpapersizealert
vla-get-printerspoolalert
vla-get-printerstylesheetpath
vla-get-printfile
vla-get-printspoolerpath
vla-get-printspoolexecutable
vla-get-productofinertia
vla-get-profilerotation
vla-get-profiles
vla-get-promptstring
vla-get-propertyname
vla-get-providername
vla-get-providertype
vla-get-proxyimage
vla-get-qnewtemplatefile
vla-get-quieterrormode
vla-get-radiiofgyration
vla-get-radius
vla-get-radiusratio
vla-get-readonly
vla-get-red
vla-get-referencecount
vla-get-regeneratetablesuppressed
vla-get-registeredapplications
vla-get-rendersmoothness
vla-get-repeatbottomlabels
vla-get-repeattoplabels
vla-get-revisionnumber
vla-get-revolutionangle
vla-get-rotation
vla-get-rounddistance
vla-get-rows
vla-get-rowspacing
vla-get-saveastype
vla-get-saved
vla-get-savepreviewthumbnail
vla-get-scale
vla-get-scalefactor
vla-get-scaleheight
vla-get-scalelineweights
vla-get-scalewidth
vla-get-scmcommandmode
vla-get-scmdefaultmode
vla-get-scmeditmode
vla-get-scmtimemode
vla-get-scmtimevalue
vla-get-secondpoint
vla-get-secondsegmentangleconstraint
vla-get-sectionmanager
vla-get-sectionplaneoffset
vla-get-segmentation
vla-get-segmentperpolyline
vla-get-selection
vla-get-selectionsets
vla-get-serialnumber
vla-get-settings
vla-get-shadeplot
vla-get-sheetview
vla-get-shortcutmenu
vla-get-shortcutmenudisplay
vla-get-show
vla-get-showassociativity
vla-get-showclipped
vla-get-showcropped
vla-get-showhistory
vla-get-showintensity
vla-get-showplotstyles
vla-get-showproxydialogbox
vla-get-showrasterimage
vla-get-showrotation
vla-get-showwarningmessages
vla-get-singledocumentmode
vla-get-slicedepth
vla-get-smoothness
vla-get-snapbasepoint
vla-get-snapon
vla-get-snaprotationangle
vla-get-solidfill
vla-get-solidtype
vla-get-sourceobjects
vla-get-splineframe
vla-get-splinemethod
vla-get-standardscale
vla-get-standardscale2
vla-get-startangle
vla-get-startdraftangle
vla-get-startdraftmagnitude
vla-get-startparameter
vla-get-startpoint
vla-get-startsmoothcontinuity
vla-get-startsmoothmagnitude
vla-get-starttangent
vla-get-state
vla-get-state2
vla-get-statusid
vla-get-storesqlindex
vla-get-stylename
vla-get-stylesheet
vla-get-stylization
vla-get-subject
vla-get-submenu
vla-get-subunitsfactor
vla-get-subunitssuffix
vla-get-summaryinfo
vla-get-supportpath
vla-get-suppressleadingzeros
vla-get-suppresstrailingzeros
vla-get-suppresszerofeet
vla-get-suppresszeroinches
vla-get-surfacenormals
vla-get-surfacetype
vla-get-surftrimassociativity
vla-get-symbolposition
vla-get-system
vla-get-tablebreakflowdirection
vla-get-tablebreakheight
vla-get-tablesreadonly
vla-get-tablestyleoverrides
vla-get-taborder
vla-get-tagstring
vla-get-taperangle
vla-get-target
vla-get-tempfileextension
vla-get-tempfilepath
vla-get-templatedwgpath
vla-get-templateid
vla-get-tempxrefpath
vla-get-textalignmentpoint
vla-get-textalignmenttype
vla-get-textangletype
vla-get-textattachmentdirection
vla-get-textbackgroundfill
vla-get-textbottomattachmenttype
vla-get-textcolor
vla-get-textdirection
vla-get-texteditor
vla-get-textfill
vla-get-textfillcolor
vla-get-textfont
vla-get-textfontsize
vla-get-textfontstyle
vla-get-textframedisplay
vla-get-textgap
vla-get-textgenerationflag
vla-get-textheight
vla-get-textinside
vla-get-textinsidealign
vla-get-textjustify
vla-get-textleftattachmenttype
vla-get-textlinespacingdistance
vla-get-textlinespacingfactor
vla-get-textlinespacingstyle
vla-get-textmovement
vla-get-textoutsidealign
vla-get-textoverride
vla-get-textposition
vla-get-textprecision
vla-get-textprefix
vla-get-textrightattachmenttype
vla-get-textrotation
vla-get-textstring
vla-get-textstyle
vla-get-textstylename
vla-get-textstyles
vla-get-textsuffix
vla-get-texttopattachmenttype
vla-get-texturemappath
vla-get-textwidth
vla-get-textwinbackgrndcolor
vla-get-textwintextcolor
vla-get-thickness
vla-get-timeserver
vla-get-timestamp
vla-get-title
vla-get-titlesuppressed
vla-get-tolerancedisplay
vla-get-toleranceheightscale
vla-get-tolerancejustification
vla-get-tolerancelowerlimit
vla-get-toleranceprecision
vla-get-tolerancesuppressleadingzeros
vla-get-tolerancesuppresstrailingzeros
vla-get-tolerancesuppresszerofeet
vla-get-tolerancesuppresszeroinches
vla-get-toleranceupperlimit
vla-get-toolbars
vla-get-toolpalettepath
vla-get-top
vla-get-topheight
vla-get-topradius
vla-get-totalangle
vla-get-totallength
vla-get-translateids
vla-get-transparency
vla-get-truecolor
vla-get-truecolorimages
vla-get-turnheight
vla-get-turns
vla-get-turnslope
vla-get-twist
vla-get-twistangle
vla-get-type
vla-get-ucsiconatorigin
vla-get-ucsiconon
vla-get-ucsperviewport
vla-get-uisolinedensity
vla-get-underlaylayeroverrideapplied
vla-get-underlayname
vla-get-underlayvisibility
vla-get-unit
vla-get-unitfactor
vla-get-units
vla-get-unitsformat
vla-get-unitstype
vla-get-upperrightcorner
vla-get-upsidedown
vla-get-url
vla-get-urldescription
vla-get-urlnamedlocation
vla-get-used
vla-get-useentitycolor
vla-get-uselastplotsettings
vla-get-user
vla-get-usercoordinatesystems
vla-get-usestandardscale
vla-get-utility
vla-get-value
vla-get-vbe
vla-get-verify
vla-get-version
vla-get-versionguid
vla-get-vertcellmargin
vla-get-vertexcount
vla-get-verticaldirection
vla-get-verticaltextposition
vla-get-vertices
vla-get-viewingdirection
vla-get-viewportdefault
vla-get-viewporton
vla-get-viewports
vla-get-views
vla-get-viewtoplot
vla-get-visibilityedge1
vla-get-visibilityedge2
vla-get-visibilityedge3
vla-get-visibilityedge4
vla-get-visible
vla-get-visolinedensity
vla-get-visualstyle
vla-get-volume
vla-get-weights
vla-get-width
vla-get-windowleft
vla-get-windowstate
vla-get-windowtitle
vla-get-windowtop
vla-get-wireframetype
vla-get-workspacepath
vla-get-xeffectivescalefactor
vla-get-xrefdatabase
vla-get-xrefdemandload
vla-get-xrefedit
vla-get-xreffadeintensity
vla-get-xreflayervisibility
vla-get-xscalefactor
vla-get-xvector
vla-get-yeffectivescalefactor
vla-get-yscalefactor
vla-get-yvector
vla-get-zeffectivescalefactor
vla-get-zscalefactor
vla-getacadstate
vla-getalignment
vla-getalignment2
vla-getallprofilenames
vla-getangle
vla-getattachmentpoint
vla-getattributes
vla-getautoscale
vla-getautoscale2
vla-getbackgroundcolor
vla-getbackgroundcolor2
vla-getbackgroundcolornone
vla-getbitmaps
vla-getblockattributevalue
vla-getblockattributevalue2
vla-getblockrotation
vla-getblockscale
vla-getblocktablerecordid
vla-getblocktablerecordid2
vla-getboundingbox
vla-getbreakheight
vla-getbulge
vla-getcanonicalmedianames
vla-getcellalignment
vla-getcellbackgroundcolor
vla-getcellbackgroundcolornone
vla-getcellclass
vla-getcellcontentcolor
vla-getcelldatatype
vla-getcellextents
vla-getcellformat
vla-getcellgridcolor
vla-getcellgridlineweight
vla-getcellgridvisibility
vla-getcellstate
vla-getcellstyle
vla-getcellstyleoverrides
vla-getcellstyles
vla-getcelltextheight
vla-getcelltextstyle
vla-getcelltype
vla-getcellvalue
vla-getcolor
vla-getcolor2
vla-getcolumnname
vla-getcolumnwidth
vla-getconstantattributes
vla-getcontentcolor
vla-getcontentcolor2
vla-getcontentlayout
vla-getcontenttype
vla-getcontrolpoint
vla-getcorner
vla-getcustombyindex
vla-getcustombykey
vla-getcustomdata
vla-getcustomscale
vla-getdataformat
vla-getdatatype
vla-getdatatype2
vla-getdistance
vla-getdoglegdirection
vla-getdynamicblockproperties
vla-getentity
vla-getextensiondictionary
vla-getfieldid
vla-getfieldid2
vla-getfitpoint
vla-getfont
vla-getformat
vla-getformat2
vla-getformula
vla-getfulldraworder
vla-getgridcolor
vla-getgridcolor2
vla-getgriddoublelinespacing
vla-getgridlinestyle
vla-getgridlinetype
vla-getgridlineweight
vla-getgridlineweight2
vla-getgridspacing
vla-getgridvisibility
vla-getgridvisibility2
vla-gethasformula
vla-getinput
vla-getinteger
vla-getinterfaceobject
vla-getinvisibleedge
vla-getiscellstyleinuse
vla-getismergeallenabled
vla-getkeyword
vla-getleaderindex
vla-getleaderlineindexes
vla-getleaderlinevertices
vla-getlivesection
vla-getlocalemedianame
vla-getloopat
vla-getmargin
vla-getminimumcolumnwidth
vla-getminimumrowheight
vla-getname
vla-getobject
vla-getobjectidstring
vla-getorientation
vla-getoverride
vla-getpapermargins
vla-getpapersize
vla-getplotdevicenames
vla-getplotstyletablenames
vla-getpoint
vla-getprojectfilepath
vla-getreal
vla-getrelativedraworder
vla-getremotefile
vla-getrotation
vla-getrowheight
vla-getrowtype
vla-getscale
vla-getsectiontypesettings
vla-getsnapspacing
vla-getstring
vla-getsubentity
vla-getsubselection
vla-gettext
vla-gettextheight
vla-gettextheight2
vla-gettextrotation
vla-gettextstring
vla-gettextstyle
vla-gettextstyle2
vla-gettextstyleid
vla-getucsmatrix
vla-getuniquecellstylename
vla-getuniquesectionname
vla-getvalue
vla-getvariable
vla-getvertexcount
vla-getweight
vla-getwidth
vla-getwindowtoplot
vla-getxdata
vla-getxrecorddata
vla-handletoobject
vla-highlight
vla-hittest
vla-import
vla-importprofile
vla-indexof
vla-initializeuserinput
vla-insertblock
vla-insertcolumns
vla-insertcolumnsandinherit
vla-insertinmenubar
vla-insertloopat
vla-insertmenuinmenubar
vla-insertrows
vla-insertrowsandinherit
vla-intersectwith
vla-iscontenteditable
vla-isempty
vla-isformateditable
vla-ismergeallenabled
vla-ismergedcell
vla-isremotefile
vla-isurl
vla-item
vla-launchbrowserdialog
vla-listarx
vla-load
vla-loadarx
vla-loaddvb
vla-loadshapefile
vla-mergecells
vla-mirror
vla-mirror3d
vla-modified
vla-move
vla-moveabove
vla-movebelow
vla-movecontent
vla-movetobottom
vla-movetotop
vla-new
vla-numcustominfo
vla-objectidtoobject
vla-offset
vla-onmodified
vla-open
vla-plottodevice
vla-plottofile
vla-polarpoint
vla-postcommand
vla-prompt
vla-purgeall
vla-purgefitdata
vla-put-action
vla-put-activedimstyle
vla-put-activedocument
vla-put-activeinvproject
vla-put-activelayer
vla-put-activelayout
vla-put-activelinetype
vla-put-activematerial
vla-put-activeprofile
vla-put-activepviewport
vla-put-activespace
vla-put-activetextstyle
vla-put-activeucs
vla-put-activeviewport
vla-put-adcinsertunitsdefaultsource
vla-put-adcinsertunitsdefaulttarget
vla-put-adjustforbackground
vla-put-algorithm
vla-put-alignment
vla-put-alignmentpointacquisition
vla-put-alignspace
vla-put-allowlongsymbolnames
vla-put-allowmanualheights
vla-put-allowmanualpositions
vla-put-altfontfile
vla-put-altitude
vla-put-altrounddistance
vla-put-altsubunitsfactor
vla-put-altsubunitssuffix
vla-put-altsuppressleadingzeros
vla-put-altsuppresstrailingzeros
vla-put-altsuppresszerofeet
vla-put-altsuppresszeroinches
vla-put-alttabletmenufile
vla-put-alttextprefix
vla-put-alttextsuffix
vla-put-alttoleranceprecision
vla-put-alttolerancesuppressleadingzeros
vla-put-alttolerancesuppresstrailingzeros
vla-put-alttolerancesuppresszerofeet
vla-put-alttolerancesuppresszeroinches
vla-put-altunits
vla-put-altunitsformat
vla-put-altunitsprecision
vla-put-altunitsscale
vla-put-angleformat
vla-put-anglevertex
vla-put-annotation
vla-put-annotative
vla-put-arcendparam
vla-put-arcpoint
vla-put-arcsmoothness
vla-put-arcstartparam
vla-put-area
vla-put-arrowhead1block
vla-put-arrowhead1type
vla-put-arrowhead2block
vla-put-arrowhead2type
vla-put-arrowheadblock
vla-put-arrowheadsize
vla-put-arrowheadtype
vla-put-arrowsize
vla-put-arrowsymbol
vla-put-associativehatch
vla-put-attachmentpoint
vla-put-author
vla-put-autoaudit
vla-put-automaticplotlog
vla-put-autosaveinterval
vla-put-autosavepath
vla-put-autosnapaperture
vla-put-autosnapaperturesize
vla-put-autosnapmagnet
vla-put-autosnapmarker
vla-put-autosnapmarkercolor
vla-put-autosnapmarkersize
vla-put-autosnaptooltip
vla-put-autotrackingveccolor
vla-put-autotracktooltip
vla-put-axisposition
vla-put-backgroundcolor
vla-put-backgroundfill
vla-put-backgroundlinescolor
vla-put-backgroundlineshiddenline
vla-put-backgroundlineslayer
vla-put-backgroundlineslinetype
vla-put-backgroundlineslinetypescale
vla-put-backgroundlineslineweight
vla-put-backgroundlinesplotstylename
vla-put-backgroundlinesvisible
vla-put-backward
vla-put-bank
vla-put-basepoint
vla-put-baseradius
vla-put-batchplotprogress
vla-put-beeponerror
vla-put-bigfontfile
vla-put-bitflags
vla-put-block
vla-put-blockcolor
vla-put-blockconnectiontype
vla-put-blockrotation
vla-put-blockscale
vla-put-blockscaling
vla-put-bottomheight
vla-put-breaksenabled
vla-put-breaksize
vla-put-breakspacing
vla-put-brightness
vla-put-canonicalmedianame
vla-put-categoryname
vla-put-center
vla-put-centermarksize
vla-put-centerplot
vla-put-centerpoint
vla-put-centertype
vla-put-check
vla-put-chordpoint
vla-put-circumference
vla-put-clippingenabled
vla-put-closed
vla-put-closed2
vla-put-color
vla-put-colorbookpath
vla-put-colorindex
vla-put-colormethod
vla-put-colorscheme
vla-put-columns
vla-put-columnspacing
vla-put-columnwidth
vla-put-commanddisplayname
vla-put-comment
vla-put-comments
vla-put-configname
vla-put-constant
vla-put-constantwidth
vla-put-constrain
vla-put-contentblockname
vla-put-contentblocktype
vla-put-contenttype
vla-put-continuousplotlog
vla-put-contourlinespersurface
vla-put-contrast
vla-put-controlpoints
vla-put-coordinate
vla-put-coordinates
vla-put-creaselevel
vla-put-creasetype
vla-put-createbackup
vla-put-currentsectiontype
vla-put-cursorsize
vla-put-curvetangencylinescolor
vla-put-curvetangencylineslayer
vla-put-curvetangencylineslinetype
vla-put-curvetangencylineslinetypescale
vla-put-curvetangencylineslineweight
vla-put-curvetangencylinesplotstylename
vla-put-curvetangencylinesvisible
vla-put-customdictionary
vla-put-customiconpath
vla-put-customscale
vla-put-cvhulldisplay
vla-put-decimalseparator
vla-put-defaultinterneturl
vla-put-defaultoutputdevice
vla-put-defaultplotstyleforlayer
vla-put-defaultplotstyleforobjects
vla-put-defaultplotstyletable
vla-put-defaultplottofilepath
vla-put-degree2
vla-put-demandloadarxapp
vla-put-description
vla-put-destinationblock
vla-put-destinationfile
vla-put-diameter
vla-put-dimconstrdesc
vla-put-dimconstrexpression
vla-put-dimconstrform
vla-put-dimconstrname
vla-put-dimconstrreference
vla-put-dimconstrvalue
vla-put-dimensionlinecolor
vla-put-dimensionlineextend
vla-put-dimensionlinetype
vla-put-dimensionlineweight
vla-put-dimline1suppress
vla-put-dimline2suppress
vla-put-dimlineinside
vla-put-dimlinesuppress
vla-put-dimtxtdirection
vla-put-direction
vla-put-directionvector
vla-put-displaygrips
vla-put-displaygripswithinblocks
vla-put-displaylayouttabs
vla-put-displaylocked
vla-put-displayolescale
vla-put-displayscreenmenu
vla-put-displayscrollbars
vla-put-displaysilhouette
vla-put-dockedvisiblelines
vla-put-doglegged
vla-put-dogleglength
vla-put-drawingdirection
vla-put-drawleaderordertype
vla-put-drawmleaderordertype
vla-put-driverspath
vla-put-dwfformat
vla-put-edgeextensiondistances
vla-put-elevation
vla-put-elevationmodelspace
vla-put-elevationpaperspace
vla-put-enable
vla-put-enableblockrotation
vla-put-enableblockscale
vla-put-enablebreak
vla-put-enabledogleg
vla-put-enableframetext
vla-put-enablelanding
vla-put-enablestartupdialog
vla-put-endangle
vla-put-enddraftangle
vla-put-enddraftmagnitude
vla-put-endparameter
vla-put-endpoint
vla-put-endsmoothcontinuity
vla-put-endsmoothmagnitude
vla-put-endsubmenulevel
vla-put-endtangent
vla-put-enterprisemenufile
vla-put-entitycolor
vla-put-entitytransparency
vla-put-explodable
vla-put-extensionlinecolor
vla-put-extensionlineextend
vla-put-extensionlineoffset
vla-put-extensionlineweight
vla-put-extline1endpoint
vla-put-extline1linetype
vla-put-extline1point
vla-put-extline1startpoint
vla-put-extline1suppress
vla-put-extline2endpoint
vla-put-extline2linetype
vla-put-extline2point
vla-put-extline2startpoint
vla-put-extline2suppress
vla-put-extlinefixedlen
vla-put-extlinefixedlensuppress
vla-put-fade
vla-put-fieldlength
vla-put-file
vla-put-firstsegmentangleconstraint
vla-put-fit
vla-put-fitpoints
vla-put-fittolerance
vla-put-floatingrows
vla-put-flowdirection
vla-put-fontfile
vla-put-fontfilemap
vla-put-forcelineinside
vla-put-foregroundlinescolor
vla-put-foregroundlinesedgetransparency
vla-put-foregroundlinesfacetransparency
vla-put-foregroundlineshiddenline
vla-put-foregroundlineslayer
vla-put-foregroundlineslinetype
vla-put-foregroundlineslinetypescale
vla-put-foregroundlineslineweight
vla-put-foregroundlinesplotstylename
vla-put-foregroundlinesvisible
vla-put-fractionformat
vla-put-freeze
vla-put-fullcrcvalidation
vla-put-fullscreentrackingvector
vla-put-generationoptions
vla-put-geoimagebrightness
vla-put-geoimagecontrast
vla-put-geoimagefade
vla-put-geolocate
vla-put-gradientangle
vla-put-gradientcentered
vla-put-gradientcolor1
vla-put-gradientcolor2
vla-put-gradientname
vla-put-graphicswinlayoutbackgrndcolor
vla-put-graphicswinmodelbackgrndcolor
vla-put-gridon
vla-put-gripcolorselected
vla-put-gripcolorunselected
vla-put-gripsize
vla-put-hasleader
vla-put-hasvpassociation
vla-put-hatchobjecttype
vla-put-hatchstyle
vla-put-headersuppressed
vla-put-height
vla-put-helpfilepath
vla-put-helpstring
vla-put-history
vla-put-historylines
vla-put-horizontaltextposition
vla-put-horzcellmargin
vla-put-hyperlinkbase
vla-put-hyperlinkdisplaycursor
vla-put-imagefile
vla-put-imageframehighlight
vla-put-imageheight
vla-put-imagevisibility
vla-put-imagewidth
vla-put-incrementalsavepercent
vla-put-indicatorfillcolor
vla-put-indicatortransparency
vla-put-insertionpoint
vla-put-intensitycolorscheme
vla-put-intersectionboundarycolor
vla-put-intersectionboundarydivisionlines
vla-put-intersectionboundarylayer
vla-put-intersectionboundarylinetype
vla-put-intersectionboundarylinetypescale
vla-put-intersectionboundarylineweight
vla-put-intersectionboundaryplotstylename
vla-put-intersectionboundaryvisible
vla-put-intersectionfillcolor
vla-put-intersectionfillfacetransparency
vla-put-intersectionfillhatchangle
vla-put-intersectionfillhatchpatternname
vla-put-intersectionfillhatchpatterntype
vla-put-intersectionfillhatchscale
vla-put-intersectionfillhatchspacing
vla-put-intersectionfilllayer
vla-put-intersectionfilllinetype
vla-put-intersectionfilllinetypescale
vla-put-intersectionfilllineweight
vla-put-intersectionfillplotstylename
vla-put-intersectionfillvisible
vla-put-invisible
vla-put-isopenwidth
vla-put-ispartial
vla-put-issuer
vla-put-itemname
vla-put-jogangle
vla-put-joglocation
vla-put-justification
vla-put-keyboardaccelerator
vla-put-keyboardpriority
vla-put-keylength
vla-put-keywords
vla-put-knotparameterization
vla-put-knots
vla-put-label
vla-put-labelblockid
vla-put-landinggap
vla-put-largebuttons
vla-put-lastheight
vla-put-lastsavedby
vla-put-latitude
vla-put-layer
vla-put-layeron
vla-put-layerstate
vla-put-layoutcreateviewport
vla-put-layoutcrosshaircolor
vla-put-layoutdisplaymargins
vla-put-layoutdisplaypaper
vla-put-layoutdisplaypapershadow
vla-put-layoutid
vla-put-layoutshowplotsetup
vla-put-leader1point
vla-put-leader2point
vla-put-leaderlength
vla-put-leaderlinecolor
vla-put-leaderlinetype
vla-put-leaderlinetypeid
vla-put-leaderlineweight
vla-put-leadertype
vla-put-left
vla-put-length
vla-put-lenslength
vla-put-limits
vla-put-linearscalefactor
vla-put-linespacingdistance
vla-put-linespacingfactor
vla-put-linespacingstyle
vla-put-linetype
vla-put-linetypegeneration
vla-put-linetypescale
vla-put-lineweight
vla-put-lineweightdisplay
vla-put-livesectionenabled
vla-put-loadacadlspinalldocuments
vla-put-lock
vla-put-lockaspectratio
vla-put-locked
vla-put-lockposition
vla-put-logfileon
vla-put-logfilepath
vla-put-longitude
vla-put-macro
vla-put-maindictionary
vla-put-maintainassociativity
vla-put-majoraxis
vla-put-majorradius
vla-put-mask
vla-put-material
vla-put-maxactiveviewports
vla-put-maxautocadwindow
vla-put-maxleadersegmentspoints
vla-put-mclose
vla-put-mdensity
vla-put-menufile
vla-put-minorradius
vla-put-mlinescale
vla-put-mode
vla-put-modelcrosshaircolor
vla-put-modelview
vla-put-monochrome
vla-put-mspace
vla-put-mtextattribute
vla-put-mtextattributecontent
vla-put-mtextboundarywidth
vla-put-mtextdrawingdirection
vla-put-name
vla-put-nclose
vla-put-ndensity
vla-put-normal
vla-put-notes
vla-put-numberofcopies
vla-put-objectsnapmode
vla-put-objectsortbyplotting
vla-put-objectsortbypsoutput
vla-put-objectsortbyredraws
vla-put-objectsortbyregens
vla-put-objectsortbyselection
vla-put-objectsortbysnap
vla-put-obliqueangle
vla-put-oleitemtype
vla-put-olelaunch
vla-put-oleplotquality
vla-put-olequality
vla-put-olesourceapp
vla-put-origin
vla-put-orthoon
vla-put-overridecenter
vla-put-pagesetupoverridestemplatefile
vla-put-paperunits
vla-put-password
vla-put-path
vla-put-patternangle
vla-put-patterndouble
vla-put-patternscale
vla-put-patternspace
vla-put-periodic
vla-put-pickadd
vla-put-pickauto
vla-put-pickboxsize
vla-put-pickdrag
vla-put-pickfirst
vla-put-pickgroup
vla-put-plothidden
vla-put-plotlegacy
vla-put-plotlogfilepath
vla-put-plotorigin
vla-put-plotpolicy
vla-put-plotrotation
vla-put-plotstylename
vla-put-plottable
vla-put-plottype
vla-put-plotviewportborders
vla-put-plotviewportsfirst
vla-put-plotwithlineweights
vla-put-plotwithplotstyles
vla-put-polartrackingvector
vla-put-position
vla-put-postscriptprologfile
vla-put-preset
vla-put-primaryunitsprecision
vla-put-printerconfigpath
vla-put-printerdescpath
vla-put-printerpapersizealert
vla-put-printerspoolalert
vla-put-printerstylesheetpath
vla-put-printfile
vla-put-printspoolerpath
vla-put-printspoolexecutable
vla-put-profilerotation
vla-put-promptstring
vla-put-providername
vla-put-providertype
vla-put-proxyimage
vla-put-qnewtemplatefile
vla-put-quieterrormode
vla-put-radius
vla-put-radiusratio
vla-put-regeneratetablesuppressed
vla-put-rendersmoothness
vla-put-repeatbottomlabels
vla-put-repeattoplabels
vla-put-revisionnumber
vla-put-revolutionangle
vla-put-rotation
vla-put-rounddistance
vla-put-rowheight
vla-put-rows
vla-put-rowspacing
vla-put-saveastype
vla-put-savepreviewthumbnail
vla-put-scale
vla-put-scalefactor
vla-put-scaleheight
vla-put-scalelineweights
vla-put-scalewidth
vla-put-scmcommandmode
vla-put-scmdefaultmode
vla-put-scmeditmode
vla-put-scmtimemode
vla-put-scmtimevalue
vla-put-secondpoint
vla-put-secondsegmentangleconstraint
vla-put-sectionplaneoffset
vla-put-segmentperpolyline
vla-put-serialnumber
vla-put-shadeplot
vla-put-sheetview
vla-put-shortcutmenudisplay
vla-put-showassociativity
vla-put-showclipped
vla-put-showcropped
vla-put-showhistory
vla-put-showintensity
vla-put-showplotstyles
vla-put-showproxydialogbox
vla-put-showrasterimage
vla-put-showrotation
vla-put-showwarningmessages
vla-put-singledocumentmode
vla-put-slicedepth
vla-put-smoothness
vla-put-snapbasepoint
vla-put-snapon
vla-put-snaprotationangle
vla-put-solidfill
vla-put-sourceobjects
vla-put-splineframe
vla-put-splinemethod
vla-put-standardscale
vla-put-standardscale2
vla-put-startangle
vla-put-startdraftangle
vla-put-startdraftmagnitude
vla-put-startparameter
vla-put-startpoint
vla-put-startsmoothcontinuity
vla-put-startsmoothmagnitude
vla-put-starttangent
vla-put-state
vla-put-state2
vla-put-storesqlindex
vla-put-stylename
vla-put-stylesheet
vla-put-stylization
vla-put-subject
vla-put-subunitsfactor
vla-put-subunitssuffix
vla-put-supportpath
vla-put-suppressleadingzeros
vla-put-suppresstrailingzeros
vla-put-suppresszerofeet
vla-put-suppresszeroinches
vla-put-surfacenormals
vla-put-surftrimassociativity
vla-put-symbolposition
vla-put-tablebreakflowdirection
vla-put-tablebreakheight
vla-put-tablesreadonly
vla-put-taborder
vla-put-tagstring
vla-put-taperangle
vla-put-target
vla-put-tempfileextension
vla-put-tempfilepath
vla-put-templatedwgpath
vla-put-templateid
vla-put-tempxrefpath
vla-put-textalignmentpoint
vla-put-textalignmenttype
vla-put-textangletype
vla-put-textattachmentdirection
vla-put-textbackgroundfill
vla-put-textbottomattachmenttype
vla-put-textcolor
vla-put-textdirection
vla-put-texteditor
vla-put-textfill
vla-put-textfillcolor
vla-put-textfont
vla-put-textfontsize
vla-put-textfontstyle
vla-put-textframedisplay
vla-put-textgap
vla-put-textgenerationflag
vla-put-textheight
vla-put-textinside
vla-put-textinsidealign
vla-put-textjustify
vla-put-textleftattachmenttype
vla-put-textlinespacingdistance
vla-put-textlinespacingfactor
vla-put-textlinespacingstyle
vla-put-textmovement
vla-put-textoutsidealign
vla-put-textoverride
vla-put-textposition
vla-put-textprecision
vla-put-textprefix
vla-put-textrightattachmenttype
vla-put-textrotation
vla-put-textstring
vla-put-textstyle
vla-put-textstylename
vla-put-textsuffix
vla-put-texttopattachmenttype
vla-put-texturemappath
vla-put-textwidth
vla-put-textwinbackgrndcolor
vla-put-textwintextcolor
vla-put-thickness
vla-put-timeserver
vla-put-title
vla-put-titlesuppressed
vla-put-tolerancedisplay
vla-put-toleranceheightscale
vla-put-tolerancejustification
vla-put-tolerancelowerlimit
vla-put-toleranceprecision
vla-put-tolerancesuppressleadingzeros
vla-put-tolerancesuppresstrailingzeros
vla-put-tolerancesuppresszerofeet
vla-put-tolerancesuppresszeroinches
vla-put-toleranceupperlimit
vla-put-toolpalettepath
vla-put-top
vla-put-topheight
vla-put-topradius
vla-put-translateids
vla-put-transparency
vla-put-truecolor
vla-put-truecolorimages
vla-put-turnheight
vla-put-turns
vla-put-twist
vla-put-twistangle
vla-put-type
vla-put-ucsiconatorigin
vla-put-ucsiconon
vla-put-ucsperviewport
vla-put-uisolinedensity
vla-put-underlaylayeroverrideapplied
vla-put-underlayname
vla-put-underlayvisibility
vla-put-units
vla-put-unitsformat
vla-put-upsidedown
vla-put-url
vla-put-urldescription
vla-put-urlnamedlocation
vla-put-useentitycolor
vla-put-uselastplotsettings
vla-put-usestandardscale
vla-put-value
vla-put-verify
vla-put-vertcellmargin
vla-put-verticaldirection
vla-put-verticaltextposition
vla-put-vertices
vla-put-viewingdirection
vla-put-viewportdefault
vla-put-viewporton
vla-put-viewtoplot
vla-put-visibilityedge1
vla-put-visibilityedge2
vla-put-visibilityedge3
vla-put-visibilityedge4
vla-put-visible
vla-put-visolinedensity
vla-put-visualstyle
vla-put-weights
vla-put-width
vla-put-windowleft
vla-put-windowstate
vla-put-windowtop
vla-put-wireframetype
vla-put-workspacepath
vla-put-xeffectivescalefactor
vla-put-xrefdemandload
vla-put-xrefedit
vla-put-xreffadeintensity
vla-put-xreflayervisibility
vla-put-xscalefactor
vla-put-xvector
vla-put-yeffectivescalefactor
vla-put-yscalefactor
vla-put-yvector
vla-put-zeffectivescalefactor
vla-put-zscalefactor
vla-putremotefile
vla-quit
vla-realtostring
vla-recomputetableblock
vla-refreshplotdeviceinfo
vla-regen
vla-reload
vla-remove
vla-removealloverrides
vla-removecustombyindex
vla-removecustombykey
vla-removeentry
vla-removefrommenubar
vla-removeitems
vla-removeleader
vla-removeleaderline
vla-removemenufrommenubar
vla-removevertex
vla-rename
vla-renamecellstyle
vla-renameprofile
vla-replace
vla-reselectsubregion
vla-resetblock
vla-resetcellvalue
vla-resetprofile
vla-restore
vla-reverse
vla-rotate
vla-rotate3d
vla-runmacro
vla-save
vla-saveas
vla-scaleentity
vla-sectionsolid
vla-select
vla-selectatpoint
vla-selectbypolygon
vla-selectonscreen
vla-selectsubregion
vla-sendcommand
vla-sendmodelessoperationended
vla-sendmodelessoperationstart
vla-setalignment
vla-setalignment2
vla-setautoscale
vla-setautoscale2
vla-setbackgroundcolor
vla-setbackgroundcolor2
vla-setbackgroundcolornone
vla-setbitmaps
vla-setblockattributevalue
vla-setblockattributevalue2
vla-setblockrotation
vla-setblockscale
vla-setblocktablerecordid
vla-setblocktablerecordid2
vla-setbreakheight
vla-setbulge
vla-setcellalignment
vla-setcellbackgroundcolor
vla-setcellbackgroundcolornone
vla-setcellclass
vla-setcellcontentcolor
vla-setcelldatatype
vla-setcellformat
vla-setcellgridcolor
vla-setcellgridlineweight
vla-setcellgridvisibility
vla-setcellstate
vla-setcellstyle
vla-setcelltextheight
vla-setcelltextstyle
vla-setcelltype
vla-setcellvalue
vla-setcellvaluefromtext
vla-setcolor
vla-setcolor2
vla-setcolorbookcolor
vla-setcolumnname
vla-setcolumnwidth
vla-setcontentcolor
vla-setcontentcolor2
vla-setcontentlayout
vla-setcontrolpoint
vla-setcustombyindex
vla-setcustombykey
vla-setcustomdata
vla-setcustomscale
vla-setdatabase
vla-setdataformat
vla-setdatatype
vla-setdatatype2
vla-setdoglegdirection
vla-setfieldid
vla-setfieldid2
vla-setfitpoint
vla-setfont
vla-setformat
vla-setformat2
vla-setformula
vla-setgridcolor
vla-setgridcolor2
vla-setgriddoublelinespacing
vla-setgridlinestyle
vla-setgridlinetype
vla-setgridlineweight
vla-setgridlineweight2
vla-setgridspacing
vla-setgridvisibility
vla-setgridvisibility2
vla-setinvisibleedge
vla-setlayoutstoplot
vla-setleaderlinevertices
vla-setmargin
vla-setnames
vla-setoverride
vla-setpattern
vla-setprojectfilepath
vla-setrelativedraworder
vla-setrgb
vla-setrotation
vla-setrowheight
vla-setscale
vla-setsnapspacing
vla-setsubselection
vla-settemplateid
vla-settext
vla-settextheight
vla-settextheight2
vla-settextrotation
vla-settextstring
vla-settextstyle
vla-settextstyle2
vla-settextstyleid
vla-settooltip
vla-setvalue
vla-setvaluefromtext
vla-setvariable
vla-setview
vla-setweight
vla-setwidth
vla-setwindowtoplot
vla-setxdata
vla-setxrecorddata
vla-slicesolid
vla-split
vla-startbatchmode
vla-startundomark
vla-swaporder
vla-syncmodelview
vla-transformby
vla-translatecoordinates
vla-unload
vla-unloadarx
vla-unloaddvb
vla-unmergecells
vla-update
vla-updateentry
vla-updatemtextattribute
vla-wblock
vla-zoomall
vla-zoomcenter
vla-zoomextents
vla-zoompickwindow
vla-zoomprevious
vla-zoomscaled
vla-zoomwindow
vlarts-init
vlax-3d-point
vlax-add-cmd
vlax-create-object
vlax-curve-getarea
vlax-curve-getclosestpointto
vlax-curve-getclosestpointtoprojection
vlax-curve-getdistatparam
vlax-curve-getdistatpoint
vlax-curve-getendparam
vlax-curve-getendpoint
vlax-curve-getfirstderiv
vlax-curve-getparamatdist
vlax-curve-getparamatpoint
vlax-curve-getpointatdist
vlax-curve-getpointatparam
vlax-curve-getsecondderiv
vlax-curve-getstartparam
vlax-curve-getstartpoint
vlax-curve-isclosed
vlax-curve-isperiodic
vlax-curve-isplanar
vlax-dump-object
vlax-ename->vla-object
vlax-erased-p
vlax-for
vlax-get
vlax-get-acad-object
vlax-get-object
vlax-get-or-create-object
vlax-get-property
vlax-import-type-library
vlax-invoke
vlax-invoke-method
vlax-ldata-delete
vlax-ldata-get
vlax-ldata-list
vlax-ldata-put
vlax-ldata-test
vlax-machine-product-key
vlax-make-safearray
vlax-make-variant
vlax-map-collection
vlax-method-applicable-p
vlax-object-released-p
vlax-product-key
vlax-property-available-p
vlax-put
vlax-put-property
vlax-queueexpr
vlax-read-enabled-p
vlax-reg-app
vlax-release-object
vlax-remove-cmd
vlax-safearray->list
vlax-safearray-fill
vlax-safearray-get-dim
vlax-safearray-get-element
vlax-safearray-get-l-bound
vlax-safearray-get-u-bound
vlax-safearray-put-element
vlax-safearray-type
vlax-tmatrix
vlax-typeinfo-available-p
vlax-user-product-key
vlax-variant-change-type
vlax-variant-type
vlax-variant-value
vlax-vbabort
vlax-vbabortretryignore
vlax-vbapplicationmodal
vlax-vbarchive
vlax-vbarray
vlax-vbboolean
vlax-vbcancel
vlax-vbcritical
vlax-vbcurrency
vlax-vbdataobject
vlax-vbdate
vlax-vbdefaultbutton1
vlax-vbdefaultbutton2
vlax-vbdefaultbutton3
vlax-vbdirectory
vlax-vbdouble
vlax-vbempty
vlax-vberror
vlax-vbexclamation
vlax-vbhidden
vlax-vbhiragana
vlax-vbignore
vlax-vbinformation
vlax-vbinteger
vlax-vbkatakana
vlax-vblong
vlax-vblowercase
vlax-vbnarrow
vlax-vbno
vlax-vbnormal
vlax-vbnull
vlax-vbobject
vlax-vbok
vlax-vbokcancel
vlax-vbokonly
vlax-vbpropercase
vlax-vbquestion
vlax-vbreadonly
vlax-vbretry
vlax-vbretrycancel
vlax-vbsingle
vlax-vbstring
vlax-vbsystem
vlax-vbsystemmodal
vlax-vbuppercase
vlax-vbvariant
vlax-vbvolume
vlax-vbwide
vlax-vbyes
vlax-vbyesno
vlax-vbyesnocancel
vlax-vla-object->ename
vlax-write-enabled-p
vlisp-compile
vlisp-compile-list
vlisp-dclres-list
vlisp-dclres-load-dialog
vlisp-drop-project
vlisp-export-symbol
vlisp-fasres-list
vlisp-fasres-load
vlisp-find-project
vlisp-import-exsubrs
vlisp-import-symbol
vlisp-inires-list
vlisp-list-loaded-projects
vlisp-load-project
vlisp-make-file-fas
vlisp-make-project-fas
vlisp-make-project-load-file
vlisp-project-fas-list
vlisp-read-file-xdv-list
vlisp-read-project-xdv-list
vlr-acdb-reactor
vlr-add
vlr-added-p
vlr-beep-reaction
vlr-command-reactor
vlr-current-reaction-name
vlr-data
vlr-data-set
vlr-deepclone-reactor
vlr-docmanager-reactor
vlr-document
vlr-dwg-reactor
vlr-dxf-reactor
vlr-editor-reactor
vlr-insert-reactor
vlr-linker-reactor
vlr-lisp-reactor
vlr-miscellaneous-reactor
vlr-mouse-reactor
vlr-notification
vlr-object-reactor
vlr-owner-add
vlr-owner-remove
vlr-owners
vlr-pers
vlr-pers-activate
vlr-pers-dictname
vlr-pers-list
vlr-pers-p
vlr-pers-release
vlr-reaction-names
vlr-reaction-set
vlr-reactions
vlr-reactor.getdictkey
vlr-reactors
vlr-remove
vlr-remove-all
vlr-set-notification
vlr-sysvar-reactor
vlr-toolbar-reactor
vlr-trace-reaction
vlr-type
vlr-types
vlr-undo-reactor
vlr-wblock-reactor
vlr-window-reactor
vlr-xref-reactor
 楼主| 发表于 2016-11-26 01:15:46 | 显示全部楼层
晓东开源通用LISP函数库 617 个函数
不知不觉,3年写了这么多了。
(defun c:tt ()
                     (if (xdrx_string_regexps "^xd::.*)" x)
                       (strcase x t)
                  a
  (xd::list:tofile "o:\\3.txt" d)
xd::3dmesh-appendvertex
xd::3dmesh-border
xd::3dmesh-data
xd::3dmesh-elevatpnt
xd::3dmesh-getmeshatpnt
xd::3dmesh-grids
xd::3dmesh-vertexs
xd::arc:centerangle
xd::arc:length
xd::assoclist:addsubitem
xd::assoclist:findsubitem
xd::assoclist:findsubkey
xd::assoclist:getdatabykeywithnums
xd::assoclist:k1->kn
xd::assoclist:mergebynumkey
xd::assoclist:removedupbynumkey
xd::assoclist:removesubitem
xd::assoclist:removesubkey
xd::assoclist:replace
xd::attrib:align
xd::attrib:modifyheight
xd::attrib:modifystyle
xd::attrib:setcolor
xd::attrib:totext
xd::autostartup
xd::begin
xd::block::getlayers
xd::block:appendentity
xd::block:getallblks
xd::block:getspatialfilter
xd::block:getxclipinfo
xd::block:makeanglescale
xd::block:resetorigin
xd::block:select
xd::block:setunitscale
xd::block:wipeout
xd::container:moveback
xd::container:movetop
xd::curve:ctrlpntslieofspline
xd::curve:firstlayer
xd::curve:getlineatarea
xd::curve:getmidpoint
xd::curve:getpointatchord
xd::curve:getpointsatchord
xd::curve:getpointsatdistgroup
xd::curve:getsamplepoints
xd::curve:getsub
xd::curve:igroup
xd::curve:iscircarc
xd::curve:isclosed
xd::curve:numdiv
xd::curve:relation
xd::curve:selfintersbreak
xd::curve:textposition
xd::curve:topopoly
xd::curve:trim
xd::curve:vertices
xd::datastru:btree
xd::dcl:accept
xd::dcl:addlist
xd::dcl:buttonaction
xd::dcl:checkin
xd::dcl:ctrldisable
xd::dcl:ctrlenable
xd::dcl:editboxaction
xd::dcl:gettile
xd::dcl:imagecrldisable
xd::dcl:imagefillcolor
xd::dcl:listaction
xd::dcl:load
xd::dcl:make
xd::dcl:numeditboxaction
xd::dcl:radioaction
xd::dcl:radioinit
xd::dcl:rserror
xd::dcl:seterror
xd::dcl:settile
xd::dcl:show
xd::dcl:slideimage
xd::dcl:start
xd::dcl:toggleaction
xd::dcl:toggleinit
xd::dcl:unload
xd::dim:aligneddiments
xd::dim:angle
xd::dim:assdiments
xd::dim:basepoints
xd::dim:getnearinx
xd::dim:getvecatoutpnt
xd::dim:group
xd::dim:groupbyent
xd::dim:init
xd::dim:makerotwithpnts
xd::dim:textavoid
xd::dim:xline
xd::dimleaderindex:make
xd::doc:apipath
xd::doc:appver
xd::doc:autoloadopendcl
xd::doc:autoloadxdrx-api
xd::doc:checkversion
xd::doc:command
xd::doc:createdimstylefrom
xd::doc:createsubdimstyle
xd::doc:disableosmode
xd::doc:drawcrosshair
xd::doc:drawxaxis
xd::doc:dstop
xd::doc:dstop1
xd::doc:dstop2
xd::doc:enableosmode
xd::doc:expandenvstr
xd::doc:getcliptext
xd::doc:getcorner
xd::doc:getdist
xd::doc:getfence
xd::doc:getpatname
xd::doc:getpickboxheight
xd::doc:getpoint
xd::doc:getpolygon
xd::doc:getrectang
xd::doc:getview4pnt
xd::doc:grdraw
xd::doc:ispntinscr
xd::doc:ispntoutview
xd::doc:ispntsoutview
xd::doc:relativepath
xd::doc:safezoom
xd::doc:setcliptext
xd::doc:setwscurrent
xd::drag:arc1
xd::drag:arc2
xd::drag:array
xd::drag:arrayfit
xd::drag:callbacksetmouseleftclick
xd::drag:callbacksetmousemove
xd::drag:circle
xd::drag:dline
xd::drag:fivestar
xd::drag:forcingrestriction
xd::drag:getcolor
xd::drag:gmove
xd::drag:mirrorbyquadrant
xd::drag:mirroripm
xd::drag:mirrorl<->r
xd::drag:mleader
xd::drag:move
xd::drag:nedge
xd::drag:pline
xd::drag:rectang
xd::drag:setcolor
xd::drag:simplemove
xd::end
xd::ent:groupname
xd::ent:transform
xd::ent:transformedcopy
xd::entity->pickset
xd::entity:3dmesh-border
xd::entity:3dmesh-data
xd::entity:3dmesh-elevatpoint
xd::entity:3dmesh-getmeshatpoint
xd::entity:3dmesh-getvertexat
xd::entity:3dmesh-mncount
xd::entity:assintersectents
xd::entity:assintersectentsinit
xd::entity:box
xd::entity:boxatecs
xd::entity:clound
xd::entity:elevation
xd::entity:getecscoordsystem
xd::entity:getmaxgroup
xd::entity:groupname
xd::entity:groupsmaxboxatucs
xd::entity:intersectwith
xd::entity:listbyproperty
xd::entity:nearbypnt
xd::entity:setoverride
xd::entity:sortents
xd::entity:sortoncurve
xd::entity:textonlineedit
xd::entity:xdir
xd::evalvbexpression
xd::excel:activefilename
xd::excel:activesheet
xd::excel:activeworkbook
xd::excel:addr2rc
xd::excel:close
xd::excel:colno2int
xd::excel:columnwidth
xd::excel:createtofile
xd::excel:getactiverange
xd::excel:getactivesheet
xd::excel:getfromfile
xd::excel:getlistrc
xd::excel:getmergecelladdress
xd::excel:getselrange
xd::excel:getusedrangerc
xd::excel:i2colno
xd::excel:initlize
xd::excel:kill
xd::excel:list->array
xd::excel:multiwriterange
xd::excel:quit
xd::excel:readrange
xd::excel:readselection
xd::excel:rowheight
xd::excel:save
xd::excel:saveas
xd::excel:setactivesheet
xd::excel:usedrange
xd::excel:usedrangevalues
xd::geom:2pntrec
xd::geom:9pt
xd::geom:angleformat
xd::geom:box->9pt
xd::geom:centralangle
xd::geom:d2r
xd::geom:get9pt
xd::geom:getperpplane
xd::geom:getperpplanewithline
xd::geom:getpolybox
xd::geom:line2box
xd::geom:numdiv
xd::geom:numdiv2
xd::geom:p2l-dist
xd::geom:pathisland
xd::geom:pntonwhere
xd::geom:queryelev
xd::geom:trianglecentroid
xd::geom:trianglecircumcenter
xd::geom:triangleheart
xd::geom:trianglenheart
xd::geom:triangleorthocenter
xd::geom:vectorangle
xd::group:boxatucs
xd::hatch:getgapbyscl
xd::hatch:getpatternname
xd::hatch:getsclbygap
xd::hatch:matchfrom
xd::hatch:merge
xd::layer:get
xd::layer:getall
xd::layer:getby70
xd::layer:getfrozen
xd::layer:getlock
xd::layer:getoff
xd::layer:geton
xd::layer:getunfrozen
xd::layer:getunlock
xd::linetype:maxlength
xd::list:<n>
xd::list:addcolumn
xd::list:append
xd::list:assoc
xd::list:booleanvalueinvert
xd::list:combinesublist
xd::list:createbyproperty
xd::list:dotpair
xd::list:elementstrlen
xd::list:elementtostring
xd::list:even
xd::list:evenpair
xd::list:fillgap
xd::list:fromfile
xd::list:group
xd::list:groupbyindex
xd::list:groupbynum
xd::list:hasdupelement
xd::list:insert
xd::list:interval
xd::list:istable
xd::list:itemallposition
xd::list:measure
xd::list:memberall
xd::list:mergeassocbynumkey
xd::list:mergeitembynumkey
xd::list:n+
xd::list:n-
xd::list:n-m
xd::list:odd
xd::list:position
xd::list:removebyinterval
xd::list:removedup
xd::list:removee
xd::list:removee1
xd::list:removehead
xd::list:removen
xd::list:removetail
xd::list:snakepair
xd::list:sort
xd::list:swap
xd::list:tablebynum
xd::list:tablecolmaxnums
xd::list:tablecolmaxstrlen
xd::list:tablefillgap
xd::list:tablesort
xd::list:tablestrformat
xd::list:tofile
xd::list:totablevalue
xd::load
xd::loadcom
xd::math:fix
xd::math:midnum
xd::math:midodd
xd::math:round
xd::math:round1
xd::math:zerosmallnum
xd::matrix:align
xd::matrix:align1
xd::matrix:ecs2wcs
xd::matrix:getcoordsystem
xd::matrix:product
xd::matrix:setscale
xd::menu:addpopupmenu
xd::mleader:makeblock
xd::mleader:setleaderlength
xd::mtext:box
xd::mtext:unformat
xd::obj:dxf
xd::obj:entmod
xd::object:get
xd::object:handlestr
xd::object:id
xd::object:reactors
xd::odcl:closefloatingform
xd::odcl:getcolorvalue
xd::odcl:getcuractiveform
xd::odcl:getfloatingform
xd::odcl:gridaddlist
xd::odcl:gridcheckboxstatusinvert
xd::odcl:gridgetcheckboxstatus
xd::odcl:gridsetalignment
xd::odcl:gridsetcheckboxstatus
xd::odcl:gridsetheight
xd::odcl:setevent
xd::pickset:allgroups
xd::pickset:copy
xd::pickset:curveintersbaseent
xd::pickset:drag
xd::pickset:duplicate
xd::pickset:entnextall
xd::pickset:getboxatecs
xd::pickset:getmaxheight
xd::pickset:getpolylinevertices
xd::pickset:getsub
xd::pickset:gripdisplay
xd::pickset:l2pl
xd::pickset:mirror
xd::pickset:numentities
xd::pickset:polyfence
xd::pickset:rdupent
xd::pickset:redraw
xd::pickset:setoverride
xd::pickset:tablesort
xd::pickset:tablesortatecs
xd::pnt:cutz
xd::pnt:dist2line
xd::pnt:drawarrow
xd::pnt:elementzero
xd::pnt:getcirpnts
xd::pnt:getrecpnts
xd::pnt:isbetween
xd::pnt:isinside
xd::pnt:isinside1
xd::pnt:islefttopbyline
xd::pnt:ison
xd::pnt:isout
xd::pnt:ispits
xd::pnt:makecrosshair
xd::pnt:mark
xd::pnt:nearpoint
xd::pnt:onwhichside
xd::pnt:quadrant
xd::pnt:setz
xd::pnt:tobox
xd::pnt:ucs
xd::pnt:ucs2wcs
xd::pnt:wcs
xd::pnt:z0
xd::pnts:3p->box
xd::pnts:area
xd::pnts:between
xd::pnts:box
xd::pnts:centroid
xd::pnts:clockwise
xd::pnts:close
xd::pnts:cutz
xd::pnts:diluting
xd::pnts:divide
xd::pnts:elementfuzz
xd::pnts:elementzero
xd::pnts:fitcircle
xd::pnts:fitline
xd::pnts:inotherpnts
xd::pnts:inscreen
xd::pnts:isclockwise
xd::pnts:isclosed
xd::pnts:isconvex
xd::pnts:isinpolywithpnts
xd::pnts:maxx->maxy
xd::pnts:maxx->miny
xd::pnts:maxy->maxx
xd::pnts:maxy->minx
xd::pnts:minx->maxy
xd::pnts:minx->miny
xd::pnts:miny->maxx
xd::pnts:miny->minx
xd::pnts:orthoproject
xd::pnts:peremiter
xd::pnts:perimeter
xd::pnts:project
xd::pnts:removedup
xd::pnts:setz
xd::pnts:sort
xd::pnts:sortbyangle
xd::pnts:transform
xd::pnts:ucs2wcs
xd::pnts:unclockwise
xd::pnts:visible
xd::pnts:wcs2ucs
xd::pnts:withpath
xd::pnts:z0
xd::polyline:-index+
xd::polyline:addfillet
xd::polyline:anglegroup
xd::polyline:centroid
xd::polyline:changestartpnt
xd::polyline:fillettype
xd::polyline:filteratindex
xd::polyline:getindexatpnt
xd::polyline:getlengthat-index+
xd::polyline:getvertices
xd::polyline:isperpat-seg+
xd::polyline:isrectang
xd::polyline:issquare
xd::polyline:make
xd::polyline:midpntatindexs
xd::polyline:nearindex
xd::polyline:onsegat
xd::polyline:rectmake
xd::polyline:removeallfillet
xd::polyline:removebugle
xd::polyline:removefillet
xd::polyline:resetfirstvertex
xd::polyline:resetstartpoint
xd::polyline:revertbulge
xd::polyline:segindex
xd::polyline:setfillet
xd::polyline:setisfillet
xd::polyline:setpointat
xd::polyline:setwidth
xd::polyline:verticesinpolygon
xd::queue:push
xd::reactor:base
xd::reactor:ed-register
xd::reactor:ed-unregister
xd::reactor:ed-writecommoncmd
xd::reactor:editor-base
xd::reactor:helper-editor-callback
xd::reactor:helper-other-callback
xd::reactor:init
xd::reactor:ob-register
xd::reactor:ob-unregister
xd::reactor:object-base
xd::reactor:readxdata
xd::reactor:register
xd::reactor:savexdata
xd::reference:getglobalscale
xd::reference:setglobalscale
xd::ss:ents
xd::ss:tmphide
xd::ss:transform
xd::ssget
xd::stack:clear
xd::stack:depth
xd::stack:list
xd::stack:pop
xd::stack:push
xd::stack:top
xd::string:actualmaxwidth
xd::string:actualwidth
xd::string:cechrsplit
xd::string:convertcurrency
xd::string:escapecha
xd::string:format
xd::string:getwords
xd::string:isnum
xd::string:isnumend
xd::string:isnumstart
xd::string:matchbetween
xd::string:matchbetweene
xd::string:matchnumafter
xd::string:modf
xd::string:regexpr
xd::string:regexps
xd::string:singlechr
xd::string:strpad
xd::string:substnth
xd::string:tailfill
xd::string:unformat
xd::symbol:clear
xd::symbol:get
xd::symbol:list
xd::symbol:names
xd::symbol:put
xd::sysvar:init
xd::sysvar:pop
xd::sysvar:push
xd::table:autosize
xd::table:begin
xd::table:celltile
xd::table:closegridline
xd::table:columnswidth
xd::table:columnwidth
xd::table:compose
xd::table:direction
xd::table:drawcell
xd::table:drawgridline
xd::table:end
xd::table:fillgap
xd::table:getallmergecells
xd::table:getcellcontentent
xd::table:getcellent
xd::table:getcellextents
xd::table:getcellid
xd::table:getcellidatcolumn
xd::table:getcellvalues
xd::table:getcolumn
xd::table:getcolumnnos
xd::table:getentbycolumn
xd::table:getentbyrow
xd::table:getmerge
xd::table:getmergedcelladdr
xd::table:getmergerange
xd::table:getrow
xd::table:gettextheight
xd::table:gettextstyle
xd::table:gettextwidthfactor
xd::table:gettitle
xd::table:getuniquename
xd::table:getvertcellmargin
xd::table:gridline2cells
xd::table:height
xd::table:index
xd::table:ismergedcell
xd::table:isrowcellhasgap
xd::table:isvalidrowcolumn
xd::table:listindexvalues
xd::table:make
xd::table:make2block
xd::table:makefromlist
xd::table:mapping
xd::table:numcolumns
xd::table:numlcolumns
xd::table:numrows
xd::table:reflection
xd::table:reset
xd::table:rowcolnum
xd::table:rowfillgap
xd::table:rowheight
xd::table:setalignment
xd::table:setcellheight
xd::table:setcellvalue
xd::table:setcolumnwidth
xd::table:setmerge
xd::table:setrowheight
xd::table:settextheight
xd::table:settextstring
xd::table:settextstyle
xd::table:settextwidthfactor
xd::table:settile
xd::table:settype
xd::table:setvertcellmargin
xd::table:sideopen
xd::table:toexcel
xd::table:totalheight
xd::table:type
xd::table:unformat
xd::table:values
xd::table:width
xd::text:adjust
xd::text:adjustalignment
xd::text:box
xd::text:indexatcursor
xd::text:indexatpoint
xd::text:init
xd::text:make
xd::text:merge
xd::text:pointatindex
xd::text:setalignment
xd::text:splitby
xd::text:splitbyspace
xd::text:stringbetween
xd::ucs:angle
xd::ucs:coordsys
xd::ucs:getplane
xd::ucs:zdir
xd::undoend
xd::undomark
xd::unloadapi
xd::var:getdrawingscale
xd::var:getdrawingunit
xd::var:getratio
xd::var:getscaleratio
xd::var:setdrawingscale
xd::var:setdrawingunit
xd::xml:addchildnodes
xd::xml:getchildnodes
xd::xml:getdocument
xd::xml:getelementbyname
xd::xml:getnodeproperties
xd::xml:getparentnodes
xd::xml:obj->list
xd::xml:save
xd::xml:saveas
xd::xml:setnodeattributes
xd::xml:setnodeproperties
评分
参与人数 1D豆 +5 收起 理由
WhoCanSay + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
回复 支持 1 反对 0
 楼主| 发表于 2016-11-26 01:11:05 | 显示全部楼层
再看看XDRX API 的 1478个函数
(defun c:tt ()
  (setq a (atoms-family 1))
  (setq        b (mapcar '(lambda (x)
                     (if (xdrx_string_regexps "^xd(rx|ex|ge).*)" x)
                       (strcase x t)
                  a
  (setq c (vl-remove nil b))
  (setq d (vl-sort c '(lambda (x y) (< x y))))
  (xd::list:tofile "o:\\2.txt" d)
xdex_book_addfont
xdex_book_addformat
xdex_book_addsheet
xdex_book_close
xdex_book_colorpack
xdex_book_colorunpack
xdex_book_datepack
xdex_book_dateunpack
xdex_book_deletesheet
xdex_book_getactivesheet
xdex_book_getallsheet
xdex_book_insertsheet
xdex_book_load
xdex_book_open
xdex_book_save
xdex_book_setactivesheet
xdex_book_setdefaultfont
xdex_book_setopertype
xdex_book_setworkformat
xdex_book_sheettype
xdex_book_type
xdex_book_version
xdex_cell_addr2rc
xdex_cell_getformat
xdex_cell_isdate
xdex_cell_isformula
xdex_cell_ismerge
xdex_cell_rc2addr
xdex_cell_read
xdex_cell_readrange
xdex_cell_type
xdex_cell_write
xdex_cell_writerange
xdex_getpropertyvalue
xdex_setpropertyvalue
xdex_sheet_clear
xdex_sheet_colishidden
xdex_sheet_colnums
xdex_sheet_colsethidden
xdex_sheet_colwidth
xdex_sheet_copycell
xdex_sheet_copyrange
xdex_sheet_delnamedrange
xdex_sheet_footer
xdex_sheet_footermargin
xdex_sheet_getmergecell
xdex_sheet_getnamedrange
xdex_sheet_header
xdex_sheet_headermargin
xdex_sheet_insertcol
xdex_sheet_insertrow
xdex_sheet_ishidden
xdex_sheet_name
xdex_sheet_nummerges
xdex_sheet_range
xdex_sheet_readrange
xdex_sheet_removecol
xdex_sheet_removemerge
xdex_sheet_removerow
xdex_sheet_rowheight
xdex_sheet_rowishidden
xdex_sheet_rownums
xdex_sheet_rowsethidden
xdex_sheet_setcellformat
xdex_sheet_setcolformat
xdex_sheet_setcolumn
xdex_sheet_setcolwidth
xdex_sheet_setcurcell
xdex_sheet_setfooter
xdex_sheet_setheader
xdex_sheet_sethidden
xdex_sheet_setmerge
xdex_sheet_setname
xdex_sheet_setnamedrange
xdex_sheet_setrangeformat
xdex_sheet_setrow
xdex_sheet_setrowformat
xdex_sheet_setrowheight
xdex_sheet_type
xdex_sheet_writerange
xdge::constructor
xdge::copy
xdge::entity:2d->3d
xdge::entity:3d->2d
xdge::entity:make
xdge::entity:mirror
xdge::entity:rotateby
xdge::entity:scaleby
xdge::entity:transformby
xdge::entity:translateby
xdge::free
xdge::getpropertyvalue
xdge::help
xdge::isequalto
xdge::isgeentity
xdge::iskindof
xdge::method
xdge::mirror
xdge::numentities
xdge::setpropertyvalue
xdge::type
xdrx_2dpolyline_make
xdrx_3dpolyline_make
xdrx_3dsolid->3dface
xdrx_3dsolid_createbox
xdrx_3dsolid_createfrustum
xdrx_3dsolid_createpyramid
xdrx_3dsolid_createsphere
xdrx_3dsolid_createtorus
xdrx_3dsolid_createwedge
xdrx_3dsolid_make
xdrx_3dsolid_vertex
xdrx_3ptoarc
xdrx_addpane
xdrx_arc_make
xdrx_arc_setcenter
xdrx_arc_setendangle
xdrx_arc_setradius
xdrx_arc_setstartangle
xdrx_arcdiv
xdrx_arctopoly
xdrx_arxload
xdrx_arxzoom
xdrx_assoclist_assoc
xdrx_assoclist_del1
xdrx_assoclist_del2
xdrx_assoclist_sort1
xdrx_assoclist_sort2
xdrx_attrib_fieldlength
xdrx_attrib_isconstant
xdrx_attrib_isinvisible
xdrx_attrib_ismtextattribute
xdrx_attrib_ispreset
xdrx_attrib_isreallylocked
xdrx_attrib_isverifiable
xdrx_attrib_lockposition
xdrx_attrib_setinvisible
xdrx_attrib_setlockposition
xdrx_attrib_settag
xdrx_attrib_tag
xdrx_attrib_tomtextattribute
xdrx_attrib_updatemtextattribute
xdrx_attribute_fieldlength
xdrx_attribute_isconstant
xdrx_attribute_isinvisible
xdrx_attribute_ismtextattribute
xdrx_attribute_ispreset
xdrx_attribute_isreallylocked
xdrx_attribute_isverifiable
xdrx_attribute_setinvisible
xdrx_attribute_setlockposition
xdrx_attribute_settag
xdrx_attribute_tag
xdrx_attribute_tomtextattribute
xdrx_attribute_updatemtextattribute
xdrx_attributedef_make
xdrx_begin
xdrx_block->entities
xdrx_block->insert
xdrx_block_addattribdef
xdrx_block_append_entity
xdrx_block_appendentity
xdrx_block_attribute2text
xdrx_block_fromfile
xdrx_block_getcomments
xdrx_block_getentities
xdrx_block_geterased
xdrx_block_getlayout
xdrx_block_getorigin
xdrx_block_getpathname
xdrx_block_getsortentstable
xdrx_block_getxrefdatabase
xdrx_block_getxrefstatus
xdrx_block_hasattdef
xdrx_block_isanonymous
xdrx_block_i**plodable
xdrx_block_islayout
xdrx_block_isoverlay
xdrx_block_isunloaded
xdrx_block_isxref
xdrx_block_make
xdrx_block_setcomments
xdrx_block_setexplodable
xdrx_block_setisunloaded
xdrx_block_setorigin
xdrx_block_setpathname
xdrx_block_text2attribute
xdrx_block_update
xdrx_circle_make
xdrx_circle_setradius
xdrx_color_aci2rgb
xdrx_color_aciselect
xdrx_color_hls2rgb
xdrx_color_long2rgb
xdrx_color_rgb2aci
xdrx_color_rgb2gray
xdrx_color_rgb2grey
xdrx_color_rgb2hls
xdrx_color_rgb2long
xdrx_color_select
xdrx_container_depth
xdrx_container_iter
xdrx_container_pop
xdrx_container_popall
xdrx_container_push
xdrx_coordfrompixeltoworld
xdrx_coordfromworldtopixel
xdrx_cursoroff
xdrx_cursoron
xdrx_curve->polyline
xdrx_curve->region
xdrx_curve->spline
xdrx_curve_asfence
xdrx_curve_box
xdrx_curve_break
xdrx_curve_closestpoint
xdrx_curve_direction
xdrx_curve_extend
xdrx_curve_fillet
xdrx_curve_getclosestpoint
xdrx_curve_getclosestpointtoprojection
xdrx_curve_getdistatparam
xdrx_curve_getdistatpoint
xdrx_curve_getendparam
xdrx_curve_getendpoint
xdrx_curve_getfirstderiv
xdrx_curve_getinters
xdrx_curve_getoffsetcurves
xdrx_curve_getparamatdist
xdrx_curve_getparamatpoint
xdrx_curve_getplane
xdrx_curve_getpoint
xdrx_curve_getpointatdist
xdrx_curve_getpointatparam
xdrx_curve_getpointsatdist
xdrx_curve_getprojectcurve
xdrx_curve_getsamplepoints
xdrx_curve_getsecondderiv
xdrx_curve_getsplitcurves
xdrx_curve_getstartparam
xdrx_curve_getstartpoint
xdrx_curve_info
xdrx_curve_int
xdrx_curve_intersect
xdrx_curve_intersectbreak
xdrx_curve_isclosed
xdrx_curve_iscoplanar
xdrx_curve_isinside
xdrx_curve_isperiodic
xdrx_curve_isplanar
xdrx_curve_join
xdrx_curve_offset
xdrx_curve_remove_dup
xdrx_curve_removedup
xdrx_curve_reverse
xdrx_curve_setclosed
xdrx_curve_subtract
xdrx_curve_trim
xdrx_curve_union
xdrx_database_clean
xdrx_database_cleardbmod
xdrx_database_close
xdrx_database_erasedentityrestore
xdrx_database_ha**ternal
xdrx_database_i**ternal
xdrx_database_issavebyadesk
xdrx_database_lastsavedmaintenanceversion
xdrx_database_lastsavever
xdrx_database_maintenancereleaseversion
xdrx_database_readdwg
xdrx_database_save
xdrx_database_seldb
xdrx_database_summaryinfo
xdrx_database_undorecording
xdrx_database_verguid
xdrx_dimension_break
xdrx_dimension_isusedefaulttextposition
xdrx_dimension_make2lang
xdrx_dimension_make3pang
xdrx_dimension_makealign
xdrx_dimension_makediametric
xdrx_dimension_makeordinate
xdrx_dimension_makeradial
xdrx_dimension_makerotate
xdrx_dimension_measurement
xdrx_dimension_normal
xdrx_dimension_position
xdrx_dimension_removeoverride
xdrx_dimension_setelevation
xdrx_dimension_sethorrotation
xdrx_dimension_setnormal
xdrx_dimension_setoverride
xdrx_dimension_setstyle
xdrx_dimension_settext
xdrx_dimension_settextposition
xdrx_dimension_settextrotation
xdrx_dimension_textbox
xdrx_dimension_textposition
xdrx_dimension_update
xdrx_dimension_usedefaulttextposition
xdrx_document->lastpts
xdrx_document_apipath
xdrx_document_assureincurrentview
xdrx_document_clearacadcmdline
xdrx_document_closeall
xdrx_document_closeallother
xdrx_document_closecurdoc
xdrx_document_colors
xdrx_document_delayedinvoke
xdrx_document_forcedwgredraw
xdrx_document_funcexecstatus
xdrx_document_getclipboard
xdrx_document_getcmdlinetext
xdrx_document_getcpoint
xdrx_document_getmousecoord
xdrx_document_getmousepixel
xdrx_document_getprec
xdrx_document_getsafeviewtwist
xdrx_document_getversionex
xdrx_document_ispaperspace
xdrx_document_isptoutscreen
xdrx_document_iswcs
xdrx_document_loadedarxapps
xdrx_document_loadedlispapps
xdrx_document_loadlinetype
xdrx_document_lock
xdrx_document_makeablock
xdrx_document_pan
xdrx_document_pandown
xdrx_document_panleft
xdrx_document_panright
xdrx_document_panup
xdrx_document_pixelbox
xdrx_document_redraw
xdrx_document_sendcmdstr
xdrx_document_sendesc
xdrx_document_sendstring
xdrx_document_setbackcolor
xdrx_document_setclipboard
xdrx_document_setcmdbarfocus
xdrx_document_setprec
xdrx_document_setundo
xdrx_document_stuffacadcmdline
xdrx_document_ucsoff
xdrx_document_ucson
xdrx_document_unlock
xdrx_document_viewres
xdrx_document_viewsave
xdrx_document_viewset
xdrx_document_xrefrepath
xdrx_document_zoomall
xdrx_document_zoomcenter
xdrx_document_zoome
xdrx_document_zoomentities
xdrx_document_zoomextents
xdrx_document_zoomprevious
xdrx_document_zoomscaled
xdrx_document_zoomwindow
xdrx_donut_make
xdrx_donut_modify
xdrx_drag_dim
xdrx_drag_dim3pang
xdrx_drag_dimline
xdrx_drag_getlastmatrix
xdrx_drag_getlastpoint
xdrx_drag_initget
xdrx_drag_jig
xdrx_drag_move
xdrx_drag_rotate
xdrx_drag_rotdim
xdrx_drag_scale
xdrx_drag_setcursor
xdrx_drag_setmatrix
xdrx_drag_setmode
xdrx_drag_setscalefactor
xdrx_dragarc
xdrx_draggen
xdrx_dragsscale
xdrx_dragssmove
xdrx_drawent
xdrx_drawing_pixelbox
xdrx_drawing_viewres
xdrx_drawing_viewsave
xdrx_drawing_zoome
xdrx_drawing_zoomw
xdrx_draworder->back
xdrx_draworder->top
xdrx_draworder_above
xdrx_draworder_bellow
xdrx_draworder_getfulldorder
xdrx_draworder_gethandle
xdrx_draworder_getrelativeorder
xdrx_draworder_isa->b
xdrx_draworder_remove
xdrx_draworder_removeall
xdrx_draworder_swap
xdrx_dynblock->static
xdrx_dynblock_aynblockid
xdrx_dynblock_dynblockid
xdrx_dynblock_getproperty
xdrx_dynblock_getvalue
xdrx_dynblock_hasname
xdrx_dynblock_isdyn
xdrx_dynblock_setvalue
xdrx_ellipse_make
xdrx_end
xdrx_entdbsinit
xdrx_entity_align
xdrx_entity_boundingboxintersectwith
xdrx_entity_box
xdrx_entity_copy
xdrx_entity_delete
xdrx_entity_explode
xdrx_entity_getecs
xdrx_entity_getgridentityucs
xdrx_entity_getgrippoint
xdrx_entity_getlayout
xdrx_entity_getplane
xdrx_entity_getproperty
xdrx_entity_getrealcolor
xdrx_entity_getstretchpoint
xdrx_entity_gettransparency
xdrx_entity_intersectwith
xdrx_entity_matchprop
xdrx_entity_mirror
xdrx_entity_move
xdrx_entity_movegrippoint
xdrx_entity_movestretchpoint
xdrx_entity_orthoprjintersectwith
xdrx_entity_osnappoint
xdrx_entity_preventities
xdrx_entity_redraw
xdrx_entity_removedup
xdrx_entity_rotate
xdrx_entity_rotate3d
xdrx_entity_safetransformedcopy
xdrx_entity_scale
xdrx_entity_setcolor
xdrx_entity_setelevation
xdrx_entity_setlayer
xdrx_entity_setlinetype
xdrx_entity_setlinetypescale
xdrx_entity_setlineweight
xdrx_entity_setplotsytlename
xdrx_entity_setpropertiesfrom
xdrx_entity_setproperty
xdrx_entity_settransparency
xdrx_entity_setvisible
xdrx_entity_stretch
xdrx_entity_transform
xdrx_entity_transformedcopy
xdrx_entsel
xdrx_face_make
xdrx_fcf_make
xdrx_findfiles
xdrx_findshx
xdrx_gd2dcl
xdrx_genboundary
xdrx_geom_3p2arc
xdrx_geom_arc2poly
xdrx_geom_arcdiv
xdrx_geom_bpoly
xdrx_geom_clipboundary
xdrx_geom_getcirdivnum
xdrx_geom_poly2arc
xdrx_geom_searchalloutline
xdrx_geom_searchoutline
xdrx_geom_searchregions
xdrx_getactivewindow
xdrx_getaperture
xdrx_getarea
xdrx_getblockinfo
xdrx_getclipboard
xdrx_getcurvenormal
xdrx_getdir
xdrx_getdist
xdrx_getentdata
xdrx_getentdxf
xdrx_getinters
xdrx_getlyrcolor
xdrx_getlyrdef
xdrx_getlyrname
xdrx_getmd5
xdrx_getnearpt
xdrx_getnested
xdrx_getosmode
xdrx_getparent
xdrx_getperpline
xdrx_getpoint
xdrx_getpointatdist
xdrx_getpolyvtx
xdrx_getprefix
xdrx_getproductname
xdrx_getpropertyvalue
xdrx_getptss
xdrx_getrandstr
xdrx_getrandstr1
xdrx_getsamplept
xdrx_getscreenbox
xdrx_getspt
xdrx_getss
xdrx_gettch
xdrx_gettime
xdrx_gettopwindow
xdrx_getxdata
xdrx_grdraw
xdrx_group->pickset
xdrx_group_appendentity
xdrx_group_box
xdrx_group_del
xdrx_group_delete
xdrx_group_getdescription
xdrx_group_hasentity
xdrx_group_isanoymous
xdrx_group_isnotaccessible
xdrx_group_isselectable
xdrx_group_list
xdrx_group_make
xdrx_group_numentities
xdrx_group_removeentity
xdrx_group_rename
xdrx_group_replaceentity
xdrx_group_setanoymous
xdrx_group_setcolor
xdrx_group_setdescription
xdrx_group_sethighlight
xdrx_group_setlayer
xdrx_group_setlinescale
xdrx_group_setlinetype
xdrx_group_setselectable
xdrx_group_setvisiblity
xdrx_hatch->lines
xdrx_hatch->pattern
xdrx_hatch_append_loop
xdrx_hatch_appendloop
xdrx_hatch_explode
xdrx_hatch_externalloopmake
xdrx_hatch_getregion
xdrx_hatch_hasmultiexternalloop
xdrx_hatch_info
xdrx_hatch_make
xdrx_hatch_make_boundary
xdrx_hatch_merge
xdrx_hatch_mkbpoly
xdrx_hatch_modify_angle
xdrx_hatch_modify_double
xdrx_hatch_modify_pattern
xdrx_hatch_modify_scale
xdrx_hatch_modify_style
xdrx_hatch_pattern_data
xdrx_hatch_pattern_name
xdrx_hatch_patterndata
xdrx_hatch_patterndef
xdrx_hatch_patternname
xdrx_hatch_rduploop
xdrx_hatch_remake
xdrx_hatch_remove_loop
xdrx_hatch_removeloop
xdrx_hatch_setangle
xdrx_hatch_setdouble
xdrx_hatch_setpattern
xdrx_hatch_setscale
xdrx_hatch_setstyle
xdrx_hook_tracemouse
xdrx_hotkey_maskesc
xdrx_hotkey_resesc
xdrx_image_boundary
xdrx_image_brightness
xdrx_image_clipboundary
xdrx_image_clipboundarytype
xdrx_image_contrast
xdrx_image_fade
xdrx_image_getreferences
xdrx_image_isclip
xdrx_image_removeclip
xdrx_image_setframe
xdrx_image_setquality
xdrx_image_setunits
xdrx_image_vars
xdrx_init
xdrx_initget
xdrx_initssget
xdrx_insert_appendattribute
xdrx_insert_appendwipeout
xdrx_insert_blocktablerecord
xdrx_insert_blocktransform
xdrx_insert_box
xdrx_insert_clip
xdrx_insert_getattribs
xdrx_insert_getclipinfo
xdrx_insert_info
xdrx_insert_isclip
xdrx_insert_make
xdrx_insert_normal
xdrx_insert_position
xdrx_insert_removeclip
xdrx_insert_removewipeout
xdrx_insert_rotation
xdrx_insert_scalefactors
xdrx_interst
xdrx_isinside
xdrx_ison
xdrx_isptoffscr
xdrx_iswcs
xdrx_kernel_tolerance
xdrx_killalllisptimer
xdrx_killlisptimer
xdrx_layer_getcolor
xdrx_layer_getdescription
xdrx_layer_getlinetype
xdrx_layer_getlineweight
xdrx_layer_getmaterialid
xdrx_layer_getplotstyle
xdrx_layer_getproperty
xdrx_layer_gettransparency
xdrx_layer_getvpdflt
xdrx_layer_hasanyoverrides
xdrx_layer_isfrozen
xdrx_layer_ishidden
xdrx_layer_isinuse
xdrx_layer_islocked
xdrx_layer_isplottable
xdrx_layer_layerisoff
xdrx_layer_make
xdrx_layer_referenced
xdrx_layer_removealloverrides
xdrx_layer_setcolor
xdrx_layer_setdescription
xdrx_layer_setisfrozen
xdrx_layer_setishidden
xdrx_layer_setislocked
xdrx_layer_setisoff
xdrx_layer_setisplottable
xdrx_layer_setlinetype
xdrx_layer_setlineweight
xdrx_layer_setmaterialid
xdrx_layer_setplotstyle
xdrx_layer_setproperty
xdrx_layer_settransparency
xdrx_layer_setvpdflt
xdrx_leader_make
xdrx_line1
xdrx_line_make
xdrx_line_midp
xdrx_line_nearpoint
xdrx_line_onwhichside
xdrx_linetype_comments
xdrx_linetype_dashlengthat
xdrx_linetype_hasshx
xdrx_linetype_isscaledtofit
xdrx_linetype_load
xdrx_linetype_make
xdrx_linetype_numdashes
xdrx_linetype_patternlength
xdrx_linetype_setcomments
xdrx_linetype_setdashlengthat
xdrx_linetype_setisscaledtofit
xdrx_linetype_setnumdashes
xdrx_linetype_setpatternlength
xdrx_linetype_setshapeisucsorientedat
xdrx_linetype_setshapenumberat
xdrx_linetype_setshapeoffsetat
xdrx_linetype_setshaperotationat
xdrx_linetype_setshapescaleat
xdrx_linetype_setshapestyleat
xdrx_linetype_settextat
xdrx_linetype_shapeisucsorientedat
xdrx_linetype_shapenumberat
xdrx_linetype_shapeoffsetat
xdrx_linetype_shaperotationat
xdrx_linetype_shapescaleat
xdrx_linetype_shapestyleat
xdrx_linetype_textat
xdrx_load
xdrx_maskesc
xdrx_math_abs
xdrx_math_acos
xdrx_math_asin
xdrx_math_atan
xdrx_math_atan2
xdrx_math_ceil
xdrx_math_cos
xdrx_math_cosh
xdrx_math_degtodms
xdrx_math_degtor
xdrx_math_dmstodeg
xdrx_math_dmstor
xdrx_math_exp
xdrx_math_floor
xdrx_math_fmod
xdrx_math_frexp
xdrx_math_hypot
xdrx_math_ldexp
xdrx_math_log
xdrx_math_log10
xdrx_math_modf
xdrx_math_movebit
xdrx_math_pow
xdrx_math_rand
xdrx_math_rtodeg
xdrx_math_rtodms
xdrx_math_sin
xdrx_math_sinh
xdrx_math_sqrt
xdrx_math_tan
xdrx_math_tanh
xdrx_matrix->local
xdrx_matrix_align
xdrx_matrix_aligncoordsys
xdrx_matrix_aligncoordsystem
xdrx_matrix_block2wcs
xdrx_matrix_det
xdrx_matrix_ecs2wcs
xdrx_matrix_getangleandaxis
xdrx_matrix_getcoordsystem
xdrx_matrix_identity
xdrx_matrix_image2wcs
xdrx_matrix_inverse
xdrx_matrix_isequal
xdrx_matrix_ismirror
xdrx_matrix_isscaledortho
xdrx_matrix_issingular
xdrx_matrix_isuniscaledortho
xdrx_matrix_ms2ps
xdrx_matrix_norm
xdrx_matrix_plane2wcs
xdrx_matrix_postmultby
xdrx_matrix_premultby
xdrx_matrix_product
xdrx_matrix_product1
xdrx_matrix_ps2ms
xdrx_matrix_scalefactor
xdrx_matrix_setcoordsystem
xdrx_matrix_setmirror
xdrx_matrix_setprojection
xdrx_matrix_setrotation
xdrx_matrix_setscale
xdrx_matrix_settranslation
xdrx_matrix_translation
xdrx_matrix_transpose
xdrx_matrix_ucs2wcs
xdrx_matrix_wcs2dcs
xdrx_matrix_wcs2plane
xdrx_matrix_wcs2ucs
xdrx_menu_allnames
xdrx_messenger
xdrx_midp
xdrx_minsert_explode
xdrx_minsert_make
xdrx_mleader_addleader
xdrx_mleader_addleaderline
xdrx_mleader_make
xdrx_mleader_makestyle
xdrx_mline_appendseg
xdrx_mline_element
xdrx_mline_getclosestpoint
xdrx_mline_getplane
xdrx_mline_isclosed
xdrx_mline_justification
xdrx_mline_make
xdrx_mline_makestyle
xdrx_mline_movevertexat
xdrx_mline_normal
xdrx_mline_numverts
xdrx_mline_removelastseg
xdrx_mline_scale
xdrx_mline_setclosed
xdrx_mline_setnormal
xdrx_mline_setscale
xdrx_mline_setstyle
xdrx_mline_setsupressendcaps
xdrx_mline_setsupressstartcaps
xdrx_mline_style
xdrx_mline_vertexat
xdrx_modal2modeless
xdrx_modent
xdrx_msgbox
xdrx_mtext_actualheight
xdrx_mtext_actualwidth
xdrx_mtext_attachment
xdrx_mtext_box
xdrx_mtext_contents
xdrx_mtext_direction
xdrx_mtext_flowdirection
xdrx_mtext_getboundingpoints
xdrx_mtext_getecs
xdrx_mtext_height
xdrx_mtext_linespacingfactor
xdrx_mtext_linespacingstyle
xdrx_mtext_location
xdrx_mtext_make
xdrx_mtext_reset
xdrx_mtext_setheight
xdrx_mtext_setwidth
xdrx_mtext_width
xdrx_nextent
xdrx_object_classname
xdrx_object_clone
xdrx_object_delete
xdrx_object_delete_xrecord
xdrx_object_extensiondictionary
xdrx_object_get
xdrx_object_get_xrecord
xdrx_object_getxdata
xdrx_object_getxrecord
xdrx_object_hasreferences
xdrx_object_hasxrecord
xdrx_object_isa
xdrx_object_iscontainer
xdrx_object_iterator
xdrx_object_next
xdrx_object_notifyer
xdrx_object_owner
xdrx_object_parent
xdrx_object_reactor
xdrx_object_regen
xdrx_object_removexdata
xdrx_object_removexrecord
xdrx_object_set_xrecord
xdrx_object_setowner
xdrx_object_setxdata
xdrx_object_setxrecord
xdrx_object_swapid
xdrx_objectstack_depth
xdrx_objectstack_pop
xdrx_objectstack_popall
xdrx_objectstack_push
xdrx_objectstack_top
xdrx_p2ldist
xdrx_p2ldist_arc
xdrx_parea
xdrx_pbarbegin
xdrx_pbarend
xdrx_pbarsetpos
xdrx_pickset->ents
xdrx_pickset_clipbypoly
xdrx_pickset_draggen
xdrx_pickset_getatpoint
xdrx_pickset_highlight
xdrx_pickset_intersect
xdrx_pickset_redraw
xdrx_pickset_removedupline
xdrx_pickset_subtract
xdrx_pickset_union
xdrx_planarent_getcoordsystem
xdrx_planarent_intersect
xdrx_planarent_iscoplanar
xdrx_planarent_isparallel
xdrx_planarent_isperpendicular
xdrx_point_convert2d
xdrx_point_dist2line
xdrx_point_getrelationatclosedcurve
xdrx_point_isinside
xdrx_point_isinside1
xdrx_point_ison
xdrx_point_make
xdrx_point_orthoproject
xdrx_point_project
xdrx_point_transform
xdrx_pointmonitor
xdrx_points_area
xdrx_points_boundingboxintersect
xdrx_points_boundingboxintersectwith
xdrx_points_box
xdrx_points_centroid
xdrx_points_chull
xdrx_points_closestpair
xdrx_points_delaunay
xdrx_points_ghull
xdrx_points_ghull1
xdrx_points_hullwidth
xdrx_points_maxareabox
xdrx_points_maxdiameter
xdrx_points_maxperimeterbox
xdrx_points_mhull
xdrx_points_minareabox
xdrx_points_mincircle
xdrx_points_minperimeterbox
xdrx_points_mirror
xdrx_points_move
xdrx_points_normal
xdrx_points_offset
xdrx_points_orthoproject
xdrx_points_qhull
xdrx_points_rotate
xdrx_points_scale
xdrx_points_sortoncurve
xdrx_points_transform
xdrx_pointsbox
xdrx_pointsmirror
xdrx_pointsmove
xdrx_pointsoffset
xdrx_pointsrotate
xdrx_pointsscale
xdrx_polyfacemesh_make
xdrx_polygonmesh_make
xdrx_polyline->2dpolyline
xdrx_polyline->outline
xdrx_polyline_addvertexat
xdrx_polyline_arc2polyarc
xdrx_polyline_clip
xdrx_polyline_compress
xdrx_polyline_convertfrom
xdrx_polyline_convertto
xdrx_polyline_elevation
xdrx_polyline_fuzzclose
xdrx_polyline_getarcsegat
xdrx_polyline_getbulgeat
xdrx_polyline_getconstantwidth
xdrx_polyline_getcurvertex
xdrx_polyline_getinsidepoint
xdrx_polyline_getlinesegat
xdrx_polyline_getpointat
xdrx_polyline_getwidthsat
xdrx_polyline_hasbulges
xdrx_polyline_hasplinegen
xdrx_polyline_haswidth
xdrx_polyline_isonlylines
xdrx_polyline_ispolycirc
xdrx_polyline_isselfintersect
xdrx_polyline_make
xdrx_polyline_numverts
xdrx_polyline_onsegat
xdrx_polyline_polyarc2arc
xdrx_polyline_remake
xdrx_polyline_removevertexat
xdrx_polyline_reset
xdrx_polyline_segtype
xdrx_polyline_setbulgeat
xdrx_polyline_setconstantwidth
xdrx_polyline_setelevation
xdrx_polyline_setnormal
xdrx_polyline_setplinegen
xdrx_polyline_setpointat
xdrx_polyline_setthickness
xdrx_polyline_setwidthsat
xdrx_polyline_thickness
xdrx_polyline_windnumber
xdrx_polyline_xtrim
xdrx_polytoarc
xdrx_preferences_getaltfontfile
xdrx_preferences_getautosavepath
xdrx_preferences_getautotrackingveccolor
xdrx_preferences_getcolor
xdrx_preferences_getconfigfile
xdrx_preferences_getcursorsize
xdrx_preferences_getcustomdictionary
xdrx_preferences_getdriverspath
xdrx_preferences_getfontfilemap
xdrx_preferences_gethelpfilepath
xdrx_preferences_getlogfilepath
xdrx_preferences_getmaindictionary
xdrx_preferences_getmenufile
xdrx_preferences_getmodelspacebgncolor
xdrx_preferences_getobjectarxpath
xdrx_preferences_getpaperspacebgncolor
xdrx_preferences_getpostscriptprologfile
xdrx_preferences_getprinterconfigpath
xdrx_preferences_getprinterdescpath
xdrx_preferences_getprinterstylesheetpath
xdrx_preferences_getprintfile
xdrx_preferences_getprintspoolerpath
xdrx_preferences_getscreenmenu
xdrx_preferences_getsupportpath
xdrx_preferences_gettempfilepath
xdrx_preferences_gettemplatedwgpath
xdrx_preferences_gettempxrefpath
xdrx_preferences_gettexteditor
xdrx_preferences_gettexturemappath
xdrx_preferences_gettextwndbgncolor
xdrx_preferences_getwintextcolor
xdrx_preferences_getworkspacepath
xdrx_preferences_setaltfontfile
xdrx_preferences_setautosavepath
xdrx_preferences_setcolor
xdrx_preferences_setcustomdictionary
xdrx_preferences_setdriverspath
xdrx_preferences_setfontfilemap
xdrx_preferences_sethelpfilepath
xdrx_preferences_setlogfilepath
xdrx_preferences_setmaindictionary
xdrx_preferences_setmenufile
xdrx_preferences_setmodelspacebgncolor
xdrx_preferences_setobjectarxpath
xdrx_preferences_setpaperspacebgncolor
xdrx_preferences_setpostscriptprologfile
xdrx_preferences_setprinterconfigpath
xdrx_preferences_setprinterdescpath
xdrx_preferences_setprinterstylesheetpath
xdrx_preferences_setprintfile
xdrx_preferences_setprintspoolerpath
xdrx_preferences_setscreenmenu
xdrx_preferences_setsupportpath
xdrx_preferences_settempfilepath
xdrx_preferences_settemplatedwgpath
xdrx_preferences_settempxrefpath
xdrx_preferences_settexteditor
xdrx_preferences_settexturemappath
xdrx_preferences_settextwndbgncolor
xdrx_preferences_setwintextcolor
xdrx_preferences_setworkspacepath
xdrx_product_key
xdrx_product_lcid
xdrx_profile_copy
xdrx_profile_delete
xdrx_profile_export
xdrx_profile_getactive
xdrx_profile_getallnames
xdrx_profile_rename
xdrx_profile_reset
xdrx_profile_setactive
xdrx_prompt
xdrx_proxy->insert
xdrx_proxy_count
xdrx_proxy_erase
xdrx_queueexpr
xdrx_ray_make
xdrx_realsort1
xdrx_realsort2
xdrx_region->curve
xdrx_region_area
xdrx_region_booleanoper
xdrx_region_getplane
xdrx_region_info
xdrx_region_make
xdrx_region_numchanges
xdrx_region_vertex
xdrx_registerhook
xdrx_removehook
xdrx_removepane
xdrx_resesc
xdrx_resfont
xdrx_reslyr
xdrx_rlistdel1
xdrx_rlistdel2
xdrx_rlistsort1
xdrx_rlistsort2
xdrx_rtow
xdrx_runtime
xdrx_saveas
xdrx_savefiled
xdrx_savlyr
xdrx_savssnum
xdrx_search_poly_outline
xdrx_searchoutline
xdrx_selfont
xdrx_sendmessage
xdrx_setclipboard
xdrx_setenttodb
xdrx_setimgini
xdrx_setlisptimer
xdrx_setmark
xdrx_setprogressmeter
xdrx_setprogressmeterpos
xdrx_setpropertyvalue
xdrx_setsstodb
xdrx_setwallcurlyr
xdrx_setxdata
xdrx_setxdata1
xdrx_setxdata2
xdrx_setxdata3
xdrx_setxdata4
xdrx_shapefile_load
xdrx_shx2pl
xdrx_sleep
xdrx_slide->bmpfile
xdrx_slide->dwg
xdrx_slide->slb
xdrx_slide->sld
xdrx_slide_add
xdrx_slide_del
xdrx_slide_del1
xdrx_slide_list
xdrx_slide_magic
xdrx_slide_make
xdrx_slide_rename
xdrx_solid_make
xdrx_sortpointoncurve
xdrx_spline_degree
xdrx_spline_elevatedegree
xdrx_spline_fittolerance
xdrx_spline_getcontrolpointat
xdrx_spline_getfitdata
xdrx_spline_getfitpointat
xdrx_spline_getfittangents
xdrx_spline_getnurbsdata
xdrx_spline_hasfitdata
xdrx_spline_insertfitpointat
xdrx_spline_insertknot
xdrx_spline_isnull
xdrx_spline_isrational
xdrx_spline_make
xdrx_spline_numcontrolpoints
xdrx_spline_numfitpoints
xdrx_spline_purgefitdata
xdrx_spline_removefitpointat
xdrx_spline_reversecurve
xdrx_spline_setcontrolpointat
xdrx_spline_setfitpointat
xdrx_spline_setfittol
xdrx_spline_setweightat
xdrx_spline_updatefitdata
xdrx_spline_weightat
xdrx_splpath
xdrx_srchdcl
xdrx_srchdim
xdrx_ssfree
xdrx_ssget
xdrx_ssjig
xdrx_statusbar_begin
xdrx_statusbar_end
xdrx_statusbar_setpos
xdrx_string_box
xdrx_string_decode
xdrx_string_encode
xdrx_string_extents
xdrx_string_find
xdrx_string_findoneof
xdrx_string_format
xdrx_string_insert
xdrx_string_join
xdrx_string_left
xdrx_string_length
xdrx_string_matchreplace
xdrx_string_merge
xdrx_string_mid
xdrx_string_rand
xdrx_string_rand1
xdrx_string_regexpr
xdrx_string_regexpreset
xdrx_string_regexps
xdrx_string_regexpv
xdrx_string_remove
xdrx_string_replace
xdrx_string_reverse
xdrx_string_right
xdrx_string_spanexcluding
xdrx_string_spanincluding
xdrx_string_split
xdrx_string_subst
xdrx_string_substr
xdrx_string_tok
xdrx_string_trimleft
xdrx_string_trimright
xdrx_string_urlencode
xdrx_surface_closestpoint
xdrx_surface_distance
xdrx_surface_signeddistance
xdrx_system_beep
xdrx_system_computername
xdrx_system_createfolder
xdrx_system_createguid
xdrx_system_currentfolder
xdrx_system_cursorpos
xdrx_system_deletefolder
xdrx_system_deleteprofilekey
xdrx_system_deleteprofilesection
xdrx_system_deltree
xdrx_system_drivetype
xdrx_system_exec
xdrx_system_filecopy
xdrx_system_filedel
xdrx_system_fileinuse
xdrx_system_filemove
xdrx_system_filerename
xdrx_system_find
xdrx_system_getacadtitle
xdrx_system_getacadwndrect
xdrx_system_getfileattributes
xdrx_system_getlogicaldrive
xdrx_system_getprofilesection
xdrx_system_getprofilesectionkeys
xdrx_system_getprofilesections
xdrx_system_getprofilestring
xdrx_system_getroamablerootfolder
xdrx_system_getscreenresolution
xdrx_system_getserial
xdrx_system_getsupportpath
xdrx_system_gettime
xdrx_system_julian2date
xdrx_system_listblockrefs
xdrx_system_pasetocmdline
xdrx_system_rgb
xdrx_system_screenmetrics
xdrx_system_searchpath
xdrx_system_selectfile
xdrx_system_selectfiles
xdrx_system_selectfolder
xdrx_system_setacadfocus
xdrx_system_setacadtitle
xdrx_system_setcurrentfolder
xdrx_system_setfileattributes
xdrx_system_shellexecute
xdrx_system_shortpath
xdrx_system_splitpath
xdrx_system_tempfolder
xdrx_system_username
xdrx_system_volumename
xdrx_system_winfolder
xdrx_system_winsysfolder
xdrx_system_writeprofilestring
xdrx_sysvar_length
xdrx_sysvar_pop
xdrx_sysvar_push
xdrx_sysvar_save
xdrx_table_alignment
xdrx_table_attachmentpoint
xdrx_table_backgroundcolor
xdrx_table_basepoint
xdrx_table_blockid
xdrx_table_blockrotation
xdrx_table_blockscale
xdrx_table_break
xdrx_table_breakflowdirection
xdrx_table_breakheight
xdrx_table_breakoffset
xdrx_table_breakoption
xdrx_table_breakspacing
xdrx_table_candelete
xdrx_table_caninsert
xdrx_table_cellstyle
xdrx_table_cellstyleoverrides
xdrx_table_celltype
xdrx_table_clearcelloverrides
xdrx_table_clearsubselection
xdrx_table_cleartablestyleoverrides
xdrx_table_close
xdrx_table_columnwidth
xdrx_table_contentcolor
xdrx_table_contenttype
xdrx_table_copyfrom
xdrx_table_deletecellcontent
xdrx_table_deletecolumns
xdrx_table_deleterows
xdrx_table_direction
xdrx_table_enablemergeall
xdrx_table_fieldid
xdrx_table_fitsize
xdrx_table_flowdirection
xdrx_table_forcedautosize
xdrx_table_getattributevalue
xdrx_table_getblockattributevalue
xdrx_table_getcellextents
xdrx_table_getgriddoublelinespacing
xdrx_table_getmergerange
xdrx_table_getoverride
xdrx_table_getsubselection
xdrx_table_gridcolor
xdrx_table_gridlineweight
xdrx_table_gridvisibility
xdrx_table_hasformula
xdrx_table_height
xdrx_table_hittest
xdrx_table_horzcellmargin
xdrx_table_insertcolumns
xdrx_table_insertrows
xdrx_table_isautoscale
xdrx_table_isbackgroundcolornone
xdrx_table_isempty
xdrx_table_isenablemergeall
xdrx_table_isheadersuppressed
xdrx_table_ismergedcell
xdrx_table_isregeneratetablesuppressed
xdrx_table_istitlesuppressed
xdrx_table_make
xdrx_table_makestyle
xdrx_table_margin
xdrx_table_mergecells
xdrx_table_minimumcolumnwidth
xdrx_table_minimumrowheight
xdrx_table_minimumtableheight
xdrx_table_minimumtablewidth
xdrx_table_numcolumns
xdrx_table_numcontents
xdrx_table_numdatarows
xdrx_table_numrows
xdrx_table_open
xdrx_table_recomputetableblock
xdrx_table_regen
xdrx_table_removestyle
xdrx_table_reselectsubregion
xdrx_table_rowheight
xdrx_table_rowtype
xdrx_table_select
xdrx_table_selectsubregion
xdrx_table_setalignment
xdrx_table_setautoscale
xdrx_table_setbackgroundcolor
xdrx_table_setbackgroundcolornone
xdrx_table_setblockattributevalue
xdrx_table_setblockid
xdrx_table_setblockrotation
xdrx_table_setblockscale
xdrx_table_setbreakflowdirection
xdrx_table_setbreakheight
xdrx_table_setbreakoffset
xdrx_table_setbreakoption
xdrx_table_setbreakspacing
xdrx_table_setcelltype
xdrx_table_setcolumnwidth
xdrx_table_setcontentcolor
xdrx_table_setdirection
xdrx_table_setfieldid
xdrx_table_setflowdirection
xdrx_table_setgridcolor
xdrx_table_setgridlineweight
xdrx_table_setgridvisibility
xdrx_table_setheight
xdrx_table_sethorzcellmargin
xdrx_table_setnormal
xdrx_table_setnumcolumns
xdrx_table_setnumrows
xdrx_table_setopenread
xdrx_table_setopenwrite
xdrx_table_setposition
xdrx_table_setrowheight
xdrx_table_setsubselection
xdrx_table_settablestyle
xdrx_table_settextheight
xdrx_table_settextrotation
xdrx_table_settextstring
xdrx_table_settextstyle
xdrx_table_settooltip
xdrx_table_setvertcellmargin
xdrx_table_setwidth
xdrx_table_style
xdrx_table_styleoverrides
xdrx_table_suppressheaderrow
xdrx_table_suppressregeneratetable
xdrx_table_suppresstitlerow
xdrx_table_textheight
xdrx_table_textrotation
xdrx_table_textstring
xdrx_table_textstringa
xdrx_table_textstyle
xdrx_table_unformat
xdrx_table_unmergecells
xdrx_table_vertcellmargin
xdrx_table_width
xdrx_temp
xdrx_text->mtext
xdrx_text_adjustalignment
xdrx_text_alignmentpoint
xdrx_text_box
xdrx_text_castshadows
xdrx_text_explode
xdrx_text_fieldtotext
xdrx_text_getproperty
xdrx_text_height
xdrx_text_horizontalmode
xdrx_text_isdefaultalignment
xdrx_text_ismirroredinx
xdrx_text_ismirrorediny
xdrx_text_make
xdrx_text_normal
xdrx_text_oblique
xdrx_text_position
xdrx_text_receiveshadows
xdrx_text_removefield
xdrx_text_setalignmentpoint
xdrx_text_setheight
xdrx_text_sethozmode
xdrx_text_setmirrorinx
xdrx_text_setmirroriny
xdrx_text_setnormal
xdrx_text_setoblique
xdrx_text_setposition
xdrx_text_setproperty
xdrx_text_setrotation
xdrx_text_setstring
xdrx_text_setstyle
xdrx_text_setthickness
xdrx_text_setvermode
xdrx_text_setwidthfactor
xdrx_text_string
xdrx_text_style
xdrx_text_thickness
xdrx_text_verticalmode
xdrx_text_widthfactor
xdrx_textbox
xdrx_textstyle_bigfontname
xdrx_textstyle_filename
xdrx_textstyle_flagbits
xdrx_textstyle_font
xdrx_textstyle_hasname
xdrx_textstyle_isbackward
xdrx_textstyle_isshapefile
xdrx_textstyle_isupside
xdrx_textstyle_isvalidfont
xdrx_textstyle_isvertical
xdrx_textstyle_make
xdrx_textstyle_obliquingangle
xdrx_textstyle_priorsize
xdrx_textstyle_setbigfontname
xdrx_textstyle_setfilename
xdrx_textstyle_setflagbits
xdrx_textstyle_setfont
xdrx_textstyle_setisshapefile
xdrx_textstyle_setisvertical
xdrx_textstyle_setobliquingangle
xdrx_textstyle_setpriorsize
xdrx_textstyle_settextsize
xdrx_textstyle_setxscale
xdrx_textstyle_textsize
xdrx_textstyle_xscale
xdrx_trace_make
xdrx_ttt
xdrx_ucs_remove
xdrx_ucs_set
xdrx_ucs_setactive
xdrx_ucs_setname
xdrx_ucsoff
xdrx_ucson
xdrx_undoend
xdrx_undostart
xdrx_vector_angle
xdrx_vector_angleonplane
xdrx_vector_crossproduct
xdrx_vector_divide
xdrx_vector_dotproduct
xdrx_vector_iscodirectional
xdrx_vector_isequal
xdrx_vector_isparallel
xdrx_vector_isperpendicular
xdrx_vector_isunitlength
xdrx_vector_iszerolength
xdrx_vector_largestelement
xdrx_vector_length
xdrx_vector_lengthsqrd
xdrx_vector_mirror
xdrx_vector_negate
xdrx_vector_normal
xdrx_vector_normalize
xdrx_vector_orthoproject
xdrx_vector_perpvector
xdrx_vector_product
xdrx_vector_project
xdrx_vector_rotate
xdrx_vector_rotateto
xdrx_vector_settosum
xdrx_vector_transform
xdrx_viewport_frozenlayerlist
xdrx_viewport_islayerfrozen
xdrx_viewport_setlayersfrozen
xdrx_viewport_thawalllayers
xdrx_viewport_thawlayers
xdrx_vport_get
xdrx_vport_info
xdrx_vport_updatedisplay
xdrx_winsock_getip
xdrx_winsock_getmac
xdrx_wipeout_make
xdrx_wtor
xdrx_xdata_apprename
xdrx_xdata_get
xdrx_xdata_remove
xdrx_xdata_set
xdrx_xdata_setbyproperty
xdrx_xdata_setdirection
xdrx_xdata_setdisplacement
xdrx_xdata_setdistance
xdrx_xdata_sethandle
xdrx_xdata_setinteger
xdrx_xdata_setlayer
xdrx_xdata_setlong
xdrx_xdata_setpoint
xdrx_xdata_setposition
xdrx_xdata_setreal
xdrx_xdata_setscale
xdrx_xdata_setstring
xdrx_xformss
xdrx_xline_make
xdrx_xml_close
xdrx_xml_load
xdrx_xml_read
xdrx_xml_save
xdrx_xref_ncopy
xdrx_yesorno
发表于 2016-11-26 08:17:12 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2016-11-26 10:58:29 | 显示全部楼层
哇,真多,不過沒幾個會用的,呵呵
发表于 2016-11-26 11:17:49 | 显示全部楼层
好好学习天天向上
发表于 2016-11-26 14:48:34 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2016-11-28 07:47:29 | 显示全部楼层
赞一个。难度在于vla-rotate之类的,很多连用法的资料都找不到。
发表于 2016-12-18 10:55:13 | 显示全部楼层
这是我见过的最长的一个帖子,很全面。
发表于 2016-12-18 11:23:30 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2016-12-18 11:59:18 | 显示全部楼层
帮助说明都没有啊
发表于 2017-3-17 00:10:10 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-7-16 00:09:05 来自手机 | 显示全部楼层
感谢分享,有专门详细介绍手册就好了,方便新手学习。
发表于 2018-2-21 16:32:11 来自手机 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2018-2-23 09:56:19 | 显示全部楼层
谢谢分享!
GMT+8, 2026-11-22 09:18 , Processed in 0.553346 second(s), 38 queries , Gzip On, File On.
