查看: 1708|回复: 2
[每日一码] JOIN LINE然后转换成3D POLYLNE
发表于 2016-12-13 13:41:29 | 显示全部楼层 |阅读模式
(defun c:joinlines23dpolys (/ *error* _vl-position uniquechain adoc ss ti
                              elst e e1 ee eg egg entl pl p pp f chainl
                              vertl vts tmp
  (vl-load-com)
  (defun *error* (m)
    (vla-endundomark adoc)
    (if m
      (prompt m)
    (princ)
  )                                       ; (_vl-position 3.29 '(1.1 2.2 3.3
                                       ; 4.4 5.5 6.6 7.7 8.8 9.9) 0.01 nil)
                                       ; => 2 (!k => nil) ;;
  (defun _vl-position (e l tol k)
    (if (null k)
      (setq k 0)
    (if (not (equal e (car l) tol))
      (progn
        (setq k (1+ k))
        (if (cdr l)
          (_vl-position e (cdr l) tol k)
          (setq k nil)
      k
  (defun uniquechain (l)
    (if l
      (cons (car l) (uniquechain (vl-remove-if '(lambda (x)
                                                  (or
                                                    (and
                                                      (equal (caar l)
                                                             (car x) 1e-6
                                                      (equal (cadar l)
                                                             (cadr x) 1e-6
                                                    (and
                                                      (equal (caar l)
                                                             (cadr x) 1e-6
                                                      (equal (cadar l)
                                                             (car x) 1e-6
                                                ) l
  (vla-startundomark (setq adoc (vla-get-activedocument
                                                        (vlax-get-acad-object)
  (setq ss (ssget "_:L" '((0 . "LINE"))))
  (setq ti (car (_vl-times)))
  (setq elst (vl-remove-if 'listp (mapcar
                                    'cadr
                                    (ssnamex ss)
  (setq entl (mapcar
               '(lambda (x)
                  (list (vlax-curve-getstartpoint x)
                        (vlax-curve-getendpoint x) x
               elst
  (setq entl (uniquechain entl))
  (foreach e elst
    (entdel e)
  (setq elst (mapcar
               'caddr
               entl
  (foreach e elst
    (entdel e)
  (while (or
           ee
           (setq e (car elst)
                 e1 e
    (if (vl-some '(lambda (x)
                    (or
                      (equal (vlax-curve-getstartpoint e)
                             (vlax-curve-getstartpoint x) 1e-6
                             (vlax-curve-getendpoint x) 1e-6
                      (equal (vlax-curve-getendpoint e)
                  ) (setq tmp (vl-remove e elst))
      (cond
        ((vl-some '(lambda (x)
                     (if (equal (vlax-curve-getstartpoint e)
                       (setq ee x)
                       (setq ee nil)
                   ) tmp
          (if (not (vl-position e eg))
            (setq eg (cons e eg))
                       (setq ee x)
                       (setq ee nil)
                   ) tmp
                     (if (equal (vlax-curve-getendpoint e)
                       (setq ee x)
                       (setq ee nil)
                   ) tmp
                       (setq ee x)
                       (setq ee nil)
                   ) tmp
      (if (null eg)
              egg (cons eg egg)
              ee nil
              eg nil
              f nil
        (if (null f)
          (progn
            (setq ee e1
                  f t
          (progn
            (setq ee nil
                  egg (cons eg egg)
                  eg nil
                  f nil
    (setq elst (vl-remove e elst))
    (if ee
      (setq e ee)
  (foreach eg egg
    (if (/= (length eg) 1)
      (while (> (length eg) 1)
        (setq pp nil
              f nil
        (setq entl (mapcar
                     '(lambda (x)
                     eg
        (setq pl (vl-remove-if '(lambda (x)
                                  (= (type x) 'ENAME)
                                ) (apply
                                    'append
                                    entl
        (while (setq p (car pl))
          (if (_vl-position p (cdr pl) 1e-6 nil)
                                      (equal p x 1e-6)
                                    ) pl
            (setq pp p
                  pl (cdr pl)
        (if pp
          (setq e (vl-some '(lambda (x)
                              (if (or
                                    (equal (car x) pp 1e-6)
                                    (equal (cadr x) pp 1e-6)
                                x
                            ) entl
          (setq e (car entl))
        (while e
          (setq chainl (cons e chainl))
                              (cond
                                ((and
                                   pp
                                   (= (length chainl) 1)
                                  (if (equal (car e) pp 1e-6)
                                    (cond
                                      ((equal (cadr e) (car x) 1e-6)
                                        (setq f t)
                                        x
                                      ((equal (cadr e) (cadr x) 1e-6)
                                        (setq f nil)
                                        x
                                    (cond
                                      ((equal (car e) (car x) 1e-6)
                                        (setq f t)
                                        x
                                      ((equal (car e) (cadr x) 1e-6)
                                        (setq f nil)
                                        x
                                ((= (length chainl) 1)
                                  (cond
                                      (setq f t)
                                      x
                                      (setq f nil)
                                      x
                                (t
                                  (cond
                                    ((and
                                       f
                                      (setq f t)
                                      x
                                    ((and
                                       f
                                      (setq f nil)
                                      x
                                    ((and
                                       (null f)
                                      (setq f t)
                                      x
                                    ((and
                                       (null f)
                                      (setq f nil)
                                      x
                            ) (setq entl (vl-remove e entl))
        (setq chainl (reverse chainl))
        (if pp
          (setq vertl (append
                        (list (if (equal (caar chainl) pp 1e-6)
                                (caar chainl)
                                (cadar chainl)
                        (setq vts (mapcar
                                    '(lambda (a b)
                                       (cond
                                         ((equal (car a) (car b) 1e-6)
                                           (car a)
                                         ((equal (car a) (cadr b) 1e-6)
                                           (car a)
                                         ((equal (cadr a) (car b) 1e-6)
                                           (cadr a)
                                         ((equal (cadr a) (cadr b) 1e-6)
                                           (cadr a)
                                    chainl
                                    (cdr chainl)
                                         (equal x (last vts) 1e-6)
                                       ) (vl-remove-if '(lambda (x)
                                                          (= (type x) 'ENAME)
                                                        ) (last chainl)
          (setq vertl (append
                        (list (caar chainl))
                        (mapcar
                          '(lambda (a b)
                             (cond
                                 (car a)
                                 (car a)
                                 (cadr a)
                                 (cadr a)
                          chainl
                          (cdr chainl)
        (foreach chain chainl
          (setq eg (vl-remove (caddr chain) eg))
          (entdel (caddr chain))
        (setq chainl nil)
        (if (car vertl)
          (progn
            (entmake (list '(0 . "POLYLINE") '(100 . "AcDbEntity") '
                           (100 . "AcDb3dPolyline") '(66 . 1) '(10 0.0 0.0
        0.0
                           (if pp
                             (cons 70 8)
                             (cons 70 9)
                           ) '(210 0.0 0.0 1.0)
            (foreach pt vertl
              (entmake (list '(0 . "VERTEX") '(100 . "AcDbEntity") '
                             (100 . "AcDbVertex") '(100 . "AcDb3dPolylineVertex")
                             (cons 10 pt) '(70 . 32)
            (entmake (list '(0 . "SEQEND") '(100 . "AcDbEntity")))
        (setq vertl nil)
  (prompt "\nElapsed time : ")
  (princ (rtos (/ (- (car (_vl-times)) ti) 1000.0) 2 20))
  (prompt " seconds...")
  (*error* nil)
发表于 2021-11-12 07:17:22 | 显示全部楼层
感谢分享JOIN LINE然后转换成3D POLYLNE
发表于 2023-1-12 10:06:45 | 显示全部楼层
学习一下~~~~~
GMT+8, 2026-11-22 11:41 , Processed in 0.263823 second(s), 14 queries , Gzip On, File On.
