查看: 1703|回复: 1
[每日一码] 每个层单独保存DWG文件
发表于 2016-12-13 17:38:20 | 显示全部楼层 |阅读模式
;; Layers to Drawings  -  Lee Mac  -  2011  -  [url]www.lee-mac.com[/url]
;; WBlocks objects on each layer in a drawing to separate drawing files.
(defun c:lay2dwg ( / _UniqueFilename acdoc acsel fpath typevar )
    (defun _UniqueFilename ( seed / f i )
        (setq i 1)
        (if (findfile (setq f (strcat seed ".dwg")))
            (while (findfile (setq f (strcat seed "(" (itoa (setq i (1+ i))) ").dwg"))))
        f
    (defun _UniqueItem ( collection seed / i )
        (setq i 1)
        (while
            (null
                (vl-catch-all-error-p
                    (vl-catch-all-apply 'vla-item
                        (list collection (strcat seed (itoa (setq i (1+ i)))))
        (strcat seed (itoa i))
    (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
          acsel (vla-get-selectionsets acdoc)
          acsel (vla-add acsel (_UniqueItem acsel "lay2dwg"))
          fpath (strcat (getvar 'DWGPREFIX) (cadr (fnsplitl (getvar 'DWGNAME))) "_")
    (vla-clear acsel)
    (setq typevar
        (vlax-make-variant
             (vlax-safearray-fill
                 (vlax-make-safearray vlax-vbinteger '(0 . 1)) '(8 410)
    (vlax-for layer (vla-get-layers acdoc)
        (vla-select acsel acselectionsetall nil nil typevar
            (vlax-make-variant
                    (vlax-make-safearray vlax-vbvariant '(0 . 1)) (list (vla-get-name layer) "Model")
        (if (< 0 (vla-get-count acsel))
            (progn
                (vla-wblock acdoc (_UniqueFilename (strcat fpath (vla-get-name layer))) acsel)
                (vla-clear acsel)
    (vla-delete acsel)
    (princ)
(vl-load-com) (princ)
已领礼包: 1094个
发表于 2021-11-15 00:41:34 | 显示全部楼层
感谢分享每个层单独保存DWG文件
GMT+8, 2026-11-3 02:49 , Processed in 0.942470 second(s), 31 queries , Gzip On.
