查看: 1423|回复: 3
[求助] dxf怎么定义啊?
发表于 2016-12-18 22:14:12 | 显示全部楼层 |阅读模式
一段小代码,用来判定所选直线,缺少dxf
(defun c:zz()
(setq ee (entlast)
      Dat (entget ee)
       p1 (dxf 10 Dat)
       p2 (dxf 11 Dat)
(cond
((equal (car p1) (car p2) 1e-11) (princ "竖线"))
((equal (cadr p1) (cadr p2) 1e-11) (princ "横线"))
(T (princ "斜线"))
发表于 2016-12-18 22:23:07 | 显示全部楼层
取组码 10 的值。
用 组码 搜索论坛,
 楼主| 发表于 2016-12-18 23:11:41 | 显示全部楼层
多谢版主指点,请帮我看看下面代码有什么问题?cad报错误: 参数类型错误: listp 10
(defun c:zz()
(setq ee (entlast)
      Dat (entget ee)
       p1 (dxf 10 Dat)
       p2 (dxf 11 Dat)
(cond
(T (princ "斜线"))
(defun DXF (elst klst / massoc)
  (setq        massoc (function (lambda (lst key / l)
                           (setq l
                                  (vl-remove-if-not '(lambda (x) (= (car x) key)) lst)
                           (if (= (length l) 10)
                             (cdar l)
                             (mapcar 'cdr l)
  (if (listp klst)
    (mapcar (function (lambda (x) (apply massoc (list elst x))))
            klst
    (apply massoc (list elst  klst))
发表于 2016-12-19 00:01:06 | 显示全部楼层
DXF函数就是取组码10的值
(defun dxf(code ed)
  (cdr (assoc code ed))
GMT+8, 2026-11-5 22:46 , Processed in 0.431779 second(s), 35 queries , Gzip On.
