查看: 3321|回复: 6
[每日一码] lisp直接利用VBA函数
发表于 2016-12-23 13:04:07 | 显示全部楼层 |阅读模式
把最近发的函数整理一下,欢迎大家测试其它函数是否可用
;;将十进制数 9 转换为 4 个字符的二进制数 (1001)
;;(Dec2Bin 9 4)=>"1001"
(defun Dec2Bin (Dec Bin / WorksheetFunction)
  (or *excel*
      (setq *excel* (vlax-get-or-create-object "excel.application"))
  (setq WorksheetFunction (vlax-get *excel* 'WorksheetFunction))
  (vlax-invoke WorksheetFunction 'Dec2Bin Dec Bin)
;;反cos
;;(Acos 0.86602540378443864676372317075294)=>0.523599弧度(30度)
(defun Acos (Num / WorksheetFunction)
  (or *excel*
  (vlax-invoke WorksheetFunction 'Acos Num)
;;反sin
;;(Asin 0.5)=>0.523599弧度(30度)
(defun Asin (Num / WorksheetFunction)
  (or *excel*
  (vlax-invoke WorksheetFunction 'Asin Num)
;;(WeekNum "2008年3月9日" 1)一年中的周数,一周开始于星期日,返回“11”
;;(WeekNum "2008年3月9日" 2)一年中的周数,一周开始于星期一,返回“10”
(defun WeekNum (express Num / WorksheetFunction)
  (or *excel*
  (vlax-invoke WorksheetFunction 'WeekNum express Num)
;;(Weekday "February 12, 1969")=>值为 4,因为February 12, 1969是星期四
(defun Weekday (express / WorksheetFunction)
  (or *excel*
  (vlax-invoke WorksheetFunction 'Weekday express)
;;求和
;;(Sum '(6 7 8))=>21
(defun Sum (express / WorksheetFunction)
  (or *excel*
  (apply 'vlax-invoke (cons WorksheetFunction (cons 'Sum express)))
;;第几个最大数
;;(Large '(6 7 8) 1)=>8第一个最大数
(defun Large (express Num / WorksheetFunction)
  (or *excel*
  (apply 'vlax-invoke (cons WorksheetFunction (cons 'Large (list express Num))))
;查找替换
;;(Replace "ABcDCF" "C" "阿")=>"ABcD阿F"
(defun Replace (express find rep)
  (or *scr*
      (setq *scr* (vlax-create-object "MSScriptControl.ScriptControl.1"))
  (vlax-put *scr* "language" "vbs")
  (vlax-invoke
    *scr*
    'ExecuteStatement
    (strcat "x = Replace(" (VL-PRIN1-TO-STRING express) "," (VL-PRIN1-TO-STRING find) "," (VL-PRIN1-TO-STRING rep) ")")
  (vlax-invoke *scr* 'eval "x")
;;输入对话框 By 819534890
;;(inputbox "信息" "题头" "默认值")
(defun inputbox        (info title default)
  (or *scr* (setq *scr* (vlax-create-object "MSScriptControl.ScriptControl.1")))
  (vlax-invoke
    *scr*
    'ExecuteStatement
    (strcat "str=InputBox("
            (vl-prin1-to-string info)
            (vl-prin1-to-string title)
            (vl-prin1-to-string default)
  (vlax-invoke *scr* 'eval "str")
;;提示信息框 By 819534890
;(msgbox "信息" 2 "题头"),不同的button值自己试试
(defun msgbox (info button title / SCR)
  (vlax-invoke
    *scr*
    'ExecuteStatement
    (strcat "str=MsgBox("
            (vl-prin1-to-string button)
;;平均值
;;(Average '(6 7 8))=>7.0
(defun Average (express / WorksheetFunction)
  (or *excel*
  (apply 'vlax-invoke (cons WorksheetFunction (cons 'Average express)))
;;list中有Round,而 RoundDown RoundUp Ceiling Ceiling_Precise是没有的
;;(RoundDown 3.1256 2)=>3.12
(defun RoundDown (express num / WorksheetFunction)
  (or *excel*
  (apply 'vlax-invoke (cons WorksheetFunction (list 'RoundDown  express  num)))
;;;(Text1 123 "正;负;零")=>"正"
;;;(Text1 123 "0000")=>"0123"格式化字串,不足前面补0
;;;其它功能请核查VBA format Text
(defun Text1 (express form / WorksheetFunction)
  (apply 'vlax-invoke (cons WorksheetFunction (list 'Text express form)))
;;阶乘
;;(Fact 4)===>24.0
(defun Fact (num / WorksheetFunction)
  (vlax-invoke WorksheetFunction 'Fact num)
;;转换
;;这个功能太强
;;(CONVERT1 1.0 "lbm" "kg")=> 将 1 磅转换为千克 (0.453592)
(defun CONVERT1 (number from_unit to_unit / WorksheetFunction)
  (apply 'vlax-invoke (cons WorksheetFunction (list 'CONVERT number from_unit to_unit)))
;;;; WorksheetFunction: nil
;;;; Property values:
;;;;   Application (RO) = #<VLA-OBJECT _Application 0eb937b4>
;;;;   Creator (RO) = 1480803660
;;;;   Parent (RO) = #<VLA-OBJECT _Application 0eb937b4>
;;;; Methods supported:
;;;;   AccrInt (7)
;;;;   AccrIntM (5)
;;;;   Acos (1)
;;;;   Acosh (1)
;;;;   Aggregate (30)
;;;;   AmorDegrc (7)
;;;;   AmorLinc (7)
;;;;   And (30)
;;;;   Asc (1)
;;;;   Asin (1)
;;;;   Asinh (1)
;;;;   Atan2 (2)
;;;;   Atanh (1)
;;;;   AveDev (30)
;;;;   Average (30)
;;;;   AverageIf (3)
;;;;   AverageIfs (29)
;;;;   BahtText (1)
;;;;   BesselI (2)
;;;;   BesselJ (2)
;;;;   BesselK (2)
;;;;   BesselY (2)
;;;;   BetaDist (5)
;;;;   BetaInv (5)
;;;;   Beta_Dist (6)
;;;;   Beta_Inv (5)
;;;;   Bin2Dec (1)
;;;;   Bin2Hex (2)
;;;;   Bin2Oct (2)
;;;;   BinomDist (4)
;;;;   Binom_Dist (4)
;;;;   Binom_Inv (3)
;;;;   Ceiling (2)
;;;;   Ceiling_Precise (2)
;;;;   ChiDist (2)
;;;;   ChiInv (2)
;;;;   ChiSq_Dist (3)
;;;;   ChiSq_Dist_RT (2)
;;;;   ChiSq_Inv (2)
;;;;   ChiSq_Inv_RT (2)
;;;;   ChiSq_Test (2)
;;;;   ChiTest (2)
;;;;   Choose (30)
;;;;   Clean (1)
;;;;   Combin (2)
;;;;   Complex (3)
;;;;   Confidence (3)
;;;;   Confidence_Norm (3)
;;;;   Confidence_T (3)
;;;;   Convert (3)
;;;;   Correl (2)
;;;;   Cosh (1)
;;;;   Count (30)
;;;;   CountA (30)
;;;;   CountBlank (1)
;;;;   CountIf (2)
;;;;   CountIfs (30)
;;;;   CoupDayBs (4)
;;;;   CoupDays (4)
;;;;   CoupDaysNc (4)
;;;;   CoupNcd (4)
;;;;   CoupNum (4)
;;;;   CoupPcd (4)
;;;;   Covar (2)
;;;;   Covariance_P (2)
;;;;   Covariance_S (2)
;;;;   CritBinom (3)
;;;;   CumIPmt (6)
;;;;   CumPrinc (6)
;;;;   DAverage (3)
;;;;   Days360 (3)
;;;;   Db (5)
;;;;   Dbcs (1)
;;;;   DCount (3)
;;;;   DCountA (3)
;;;;   Ddb (5)
;;;;   Dec2Bin (2)
;;;;   Dec2Hex (2)
;;;;   Dec2Oct (2)
;;;;   Degrees (1)
;;;;   Delta (2)
;;;;   DevSq (30)
;;;;   DGet (3)
;;;;   Disc (5)
;;;;   DMax (3)
;;;;   DMin (3)
;;;;   Dollar (2)
;;;;   DollarDe (2)
;;;;   DollarFr (2)
;;;;   DProduct (3)
;;;;   DStDev (3)
;;;;   DStDevP (3)
;;;;   DSum (3)
;;;;   Duration (6)
;;;;   DVar (3)
;;;;   DVarP (3)
;;;;   EDate (2)
;;;;   Effect (2)
;;;;   EoMonth (2)
;;;;   Erf (2)
;;;;   ErfC (1)
;;;;   ErfC_Precise (1)
;;;;   Erf_Precise (1)
;;;;   Even (1)
;;;;   ExponDist (3)
;;;;   Expon_Dist (3)
;;;;   Fact (1)
;;;;   FactDouble (1)
;;;;   FDist (3)
;;;;   Find (3)
;;;;   FindB (3)
;;;;   FInv (3)
;;;;   Fisher (1)
;;;;   FisherInv (1)
;;;;   Fixed (3)
;;;;   Floor (2)
;;;;   Floor_Precise (2)
;;;;   Forecast (3)
;;;;   Frequency (2)
;;;;   FTest (2)
;;;;   Fv (5)
;;;;   FVSchedule (2)
;;;;   F_Dist (4)
;;;;   F_Dist_RT (3)
;;;;   F_Inv (3)
;;;;   F_Inv_RT (3)
;;;;   F_Test (2)
;;;;   GammaDist (4)
;;;;   GammaInv (3)
;;;;   GammaLn (1)
;;;;   GammaLn_Precise (1)
;;;;   Gamma_Dist (4)
;;;;   Gamma_Inv (3)
;;;;   Gcd (30)
;;;;   GeoMean (30)
;;;;   GeStep (2)
;;;;   Growth (4)
;;;;   HarMean (30)
;;;;   Hex2Bin (2)
;;;;   Hex2Dec (1)
;;;;   Hex2Oct (2)
;;;;   HLookup (4)
;;;;   HypGeomDist (4)
;;;;   HypGeom_Dist (5)
;;;;   IfError (2)
;;;;   ImAbs (1)
;;;;   Imaginary (1)
;;;;   ImArgument (1)
;;;;   ImConjugate (1)
;;;;   ImCos (1)
;;;;   ImDiv (2)
;;;;   ImExp (1)
;;;;   ImLn (1)
;;;;   ImLog10 (1)
;;;;   ImLog2 (1)
;;;;   ImPower (2)
;;;;   ImProduct (30)
;;;;   ImReal (1)
;;;;   ImSin (1)
;;;;   ImSqrt (1)
;;;;   ImSub (2)
;;;;   ImSum (30)
;;;;   Index (4)
;;;;   Intercept (2)
;;;;   IntRate (5)
;;;;   Ipmt (6)
;;;;   Irr (2)
;;;;   IsErr (1)
;;;;   IsError (1)
;;;;   IsEven (1)
;;;;   IsLogical (1)
;;;;   IsNA (1)
;;;;   IsNonText (1)
;;;;   IsNumber (1)
;;;;   IsOdd (1)
;;;;   ISO_Ceiling (2)
;;;;   Ispmt (4)
;;;;   IsText (1)
;;;;   Kurt (30)
;;;;   Large (2)
;;;;   Lcm (30)
;;;;   LinEst (4)
;;;;   Ln (1)
;;;;   Log (2)
;;;;   Log10 (1)
;;;;   LogEst (4)
;;;;   LogInv (3)
;;;;   LogNormDist (3)
;;;;   LogNorm_Dist (4)
;;;;   LogNorm_Inv (3)
;;;;   Lookup (3)
;;;;   Match (3)
;;;;   Max (30)
;;;;   MDeterm (1)
;;;;   MDuration (6)
;;;;   Median (30)
;;;;   Min (30)
;;;;   MInverse (1)
;;;;   MIrr (3)
;;;;   MMult (2)
;;;;   Mode (30)
;;;;   Mode_Mult (30)
;;;;   Mode_Sngl (30)
;;;;   MRound (2)
;;;;   MultiNomial (30)
;;;;   NegBinomDist (3)
;;;;   NegBinom_Dist (4)
;;;;   NetworkDays (3)
;;;;   NetworkDays_Intl (4)
;;;;   Nominal (2)
;;;;   NormDist (4)
;;;;   NormInv (3)
;;;;   NormSDist (1)
;;;;   NormSInv (1)
;;;;   Norm_Dist (4)
;;;;   Norm_Inv (3)
;;;;   Norm_S_Dist (2)
;;;;   Norm_S_Inv (1)
;;;;   NPer (5)
;;;;   Npv (30)
;;;;   Oct2Bin (2)
;;;;   Oct2Dec (1)
;;;;   Oct2Hex (2)
;;;;   Odd (1)
;;;;   OddFPrice (9)
;;;;   OddFYield (9)
;;;;   OddLPrice (8)
;;;;   OddLYield (8)
;;;;   Or (30)
;;;;   Pearson (2)
;;;;   Percentile (2)
;;;;   Percentile_Exc (2)
;;;;   Percentile_Inc (2)
;;;;   PercentRank (3)
;;;;   PercentRank_Exc (3)
;;;;   PercentRank_Inc (3)
;;;;   Permut (2)
;;;;   Phonetic (1)
;;;;   Pi ()
;;;;   Pmt (5)
;;;;   Poisson (3)
;;;;   Poisson_Dist (3)
;;;;   Power (2)
;;;;   Ppmt (6)
;;;;   Price (7)
;;;;   PriceDisc (5)
;;;;   PriceMat (6)
;;;;   Prob (4)
;;;;   Product (30)
;;;;   Proper (1)
;;;;   Pv (5)
;;;;   Quartile (2)
;;;;   Quartile_Exc (2)
;;;;   Quartile_Inc (2)
;;;;   Quotient (2)
;;;;   Radians (1)
;;;;   RandBetween (2)
;;;;   Rank (3)
;;;;   Rank_Avg (3)
;;;;   Rank_Eq (3)
;;;;   Rate (6)
;;;;   Received (5)
;;;;   Replace (4)
;;;;   ReplaceB (4)
;;;;   Rept (2)
;;;;   Roman (2)
;;;;   Round (2)
;;;;   RoundDown (2)
;;;;   RoundUp (2)
;;;;   RSq (2)
;;;;   RTD (30)
;;;;   Search (3)
;;;;   SearchB (3)
;;;;   SeriesSum (4)
;;;;   Sinh (1)
;;;;   Skew (30)
;;;;   Sln (3)
;;;;   Slope (2)
;;;;   Small (2)
;;;;   SqrtPi (1)
;;;;   Standardize (3)
;;;;   StDev (30)
;;;;   StDevP (30)
;;;;   StDev_P (30)
;;;;   StDev_S (30)
;;;;   StEyx (2)
;;;;   Substitute (4)
;;;;   Subtotal (30)
;;;;   Sum (30)
;;;;   SumIf (3)
;;;;   SumIfs (29)
;;;;   SumProduct (30)
;;;;   SumSq (30)
;;;;   SumX2MY2 (2)
;;;;   SumX2PY2 (2)
;;;;   SumXMY2 (2)
;;;;   Syd (4)
;;;;   Tanh (1)
;;;;   TBillEq (3)
;;;;   TBillPrice (3)
;;;;   TBillYield (3)
;;;;   TDist (3)
;;;;   Text (2)
;;;;   TInv (2)
;;;;   Transpose (1)
;;;;   Trend (4)
;;;;   Trim (1)
;;;;   TrimMean (2)
;;;;   TTest (4)
;;;;   T_Dist (3)
;;;;   T_Dist_2T (2)
;;;;   T_Dist_RT (2)
;;;;   T_Inv (2)
;;;;   T_Inv_2T (2)
;;;;   T_Test (4)
;;;;   USDollar (2)
;;;;   Var (30)
;;;;   VarP (30)
;;;;   Var_P (30)
;;;;   Var_S (30)
;;;;   Vdb (7)
;;;;   VLookup (4)
;;;;   Weekday (2)
;;;;   WeekNum (2)
;;;;   Weibull (4)
;;;;   Weibull_Dist (4)
;;;;   WorkDay (3)
;;;;   WorkDay_Intl (4)
;;;;   Xirr (3)
;;;;   Xnpv (2)
;;;;   YearFrac (3)
;;;;   YieldDisc (5)
;;;;   YieldMat (6)
;;;;   ZTest (3)
;;;;   Z_Test (3)
又花了一个下午,测试了更多可用的函数,搞了个压缩包收点辛苦费,换酒喝
excel可利用函数.zip
4.5 KB, 下载次数: 46, 下载积分: D豆 -1 , 活跃度 1
售价: 5 D豆  [记录]
发表于 2016-12-23 13:07:16 | 显示全部楼层
是不是应该提高个判断系统是否安装EXCEL的函数? 没装就提示然后退出
or 前加一个if  发表于 2016-12-23 13:10
发表于 2016-12-23 15:33:44 | 显示全部楼层
牛。
发表于 2016-12-31 21:27:26 来自手机 | 显示全部楼层
*excel*是nil就表示没有装EXCEL
发表于 2021-11-25 06:14:43 | 显示全部楼层
感谢分享lisp直接利用VBA函数
发表于 2021-11-25 09:55:19 | 显示全部楼层
感谢共享!
GMT+8, 2026-11-22 07:49 , Processed in 0.542165 second(s), 22 queries , Gzip On, File On.
