查看: 1862|回复: 3
[每日一码] Creating an AutoCAD table linked to an Excel spreadsheet using .NET
已领礼包: 6个
发表于 2016-12-23 13:29:20 | 显示全部楼层 |阅读模式
In the last post I promised to tackle this issue, and so here we are again. :-)
Note: the code in this post relies on enhanced table functionality introduced in AutoCAD 2008, so please don't get frustrated trying to make this work in previous versions.
The following C# code follows on from yesterday's, taking the spreadsheet selected by the user and linking it to a newly-created table in the active AutoCAD drawing. I haven't bothered with line numbering in the below code, as it follows on almost exactly from the code shown last time (aside from renaming the namespace, the command and the function, as well as adding a string constant at the top of the function implementation).
Here's what happens when you run the TFS command and select your favourite XLS for linking (I used mass-balance.xls from AutoCAD 2008's Sample\Mechanical Sample folder):
At this stage I haven't focused at all on formating - this is just coming in "as is", without any adjustment of cell alignments, column widths or row heights.
I chose to hardcode the name of the Data Link we use for the spreadsheet. You can run the DATALINK command to check on it, after the command has executed:
It doesn't seem to be an issue if you repeat the command and bring in a different spreadsheet using the same link - the link appears to continue (although I haven't performed exhaustive testing). If it does prove to be a problem it should be simple enough to create a unique Data Link per spreadsheet imported (or even per time the command is run).
Posted on August 22, 2007 at 05:40 PM in AutoCAD, AutoCAD .NET, Excel, Tables | Permalink
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
namespace LinkToExcel
  public class Commands
    [CommandMethod("TFS")]
    static public void TableFromSpreadsheet()
      // Hardcoding the string
      // Could also select for it
      const string dlName =
        "Import table from Excel demo";
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      OpenFileDialog ofd =
        new OpenFileDialog(
          "Select Excel spreadsheet to link",
          null,
          "xls; xlsx",
          "ExcelFileToLink",
          OpenFileDialog.OpenFileDialogFlags.
            DoNotTransferRemoteFiles
      System.Windows.Forms.DialogResult dr =
        ofd.ShowDialog();
      if (dr != System.Windows.Forms.DialogResult.OK)
        return;
      ed.WriteMessage(
        "\nFile selected was \"{0}\".",
        ofd.Filename
      PromptPointResult ppr =
        ed.GetPoint(
          "\nEnter table insertion point: "
      if (ppr.Status != PromptStatus.OK)
        return;
      // Remove the Data Link, if it exists already
      DataLinkManager dlm = db.DataLinkManager;
      ObjectId dlId = dlm.GetDataLink(dlName);
      if (dlId != ObjectId.Null)
        dlm.RemoveDataLink(dlId);
      // Create and add the Data Link
      DataLink dl = new DataLink();
      dl.DataAdapterId = "AcExcel";
      dl.Name = dlName;
      dl.Description =
        "Excel fun with Through the Interface";
      dl.ConnectionString = ofd.Filename;
      dl.DataLinkOption =
        DataLinkOption.PersistCache;
      dl.UpdateOption |=
        (int)UpdateOption.AllowSourceUpdate;
      dlId = dlm.AddDataLink(dl);
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      using (tr)
        tr.AddNewlyCreatedDBObject(dl, true);
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId,
            OpenMode.ForRead
        Table tb = new Table();
        tb.TableStyle = db.Tablestyle;
        tb.Position = ppr.Value;
        tb.SetDataLink(0, 0, dlId, true);
        tb.GenerateLayout();
        BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            db.CurrentSpaceId,
            OpenMode.ForWrite
        btr.AppendEntity(tb);
        tr.AddNewlyCreatedDBObject(tb, true);
        tr.Commit();
      // Force a regen to display the table
      ed.Regen();
已领礼包: 2759个
财富等级: 家财万贯
发表于 2016-12-24 15:24:46 | 显示全部楼层
学习!!!!!!!!!!!!!
已领礼包: 4044个
发表于 2016-12-25 16:51:41 | 显示全部楼层
回复学习学习
发表于 2020-12-28 12:56:03 | 显示全部楼层
现在代码链接的是整个工作表,怎么实现链接Excel工作表,如“A1:H7”区域。求楼主解答。
GMT+8, 2026-11-3 06:03 , Processed in 0.653344 second(s), 37 queries , Gzip On.
