查看: 1699|回复: 3
[每日一码] 选择指定长度范围内的LINE
已领礼包: 20个
发表于 2016-12-25 15:24:35 | 显示全部楼层 |阅读模式
(defun c:getlines ( / a e i m n p q s x )
    (initget 6)
    (setq m (cond ((getdist "\nSpecify lower bound for length <none>: ")) (0.0)))
    (initget 6)
    (setq n (cond ((getdist "\nSpecify upper bound for length <none>: ")) (1e308)))
    (if (setq s (ssget "_X" (list '(0 . "LINE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
        (repeat (setq i (sslength s))
            (setq e (ssname s (setq i (1- i)))
                  x (entget e)
                  p (cdr (assoc 10 x))
                  q (cdr (assoc 11 x))
                  a (rem (angle p q) (/ pi 2.0))
            (if (not (and (<= m (distance p q) n) (or (equal 0.0 a 1e-8) (equal (/ pi 2.0) a 1e-8))))
                (ssdel e s)
        (princ "\nNo lines found in the current layout.")
    (sssetfirst nil s)
    (princ)
已领礼包: 6881个
发表于 2016-12-25 20:54:00 | 显示全部楼层
谢谢你的分享
已领礼包: 6056个
发表于 2016-12-25 21:55:50 | 显示全部楼层
支持分享源码。
已领礼包: 1094个
发表于 2021-11-23 06:05:00 | 显示全部楼层
感谢分享选择指定长度范围内的LINE
GMT+8, 2026-11-3 00:13 , Processed in 0.420199 second(s), 35 queries , Gzip On.
