查看: 1498|回复: 2
[每日一码] 几个视图ARX代码
发表于 2017-1-10 13:50:06 | 显示全部楼层 |阅读模式
static bool GetActiveViewPortInfo (AcDbDatabase *pDb, ads_real &height, ads_real &width,
        AcGePoint3d &target, AcGeVector3d &viewDir,
        ads_real &viewTwist,
        AcDbObjectId ¤tVsId,
        bool getViewCenter)
          // if not ok
          if (pDb == NULL)
                return false;
          // get the current document associated with the PDb database and set it current
          AcApDocument *pDoc = acDocManager->document(pDb);
          acDocManager->setCurDocument(pDoc);
          acDocManager->lockDocument(pDoc);
          // make sure the active view port is uptodate
          acedVports2VportTableRecords();
          // open the view port records
          AcDbViewportTablePointer pVTable(pDb->viewportTableId(), AcDb::kForRead);
          // if we opened them ok
          if (pVTable.openStatus() == Acad::eOk)
                AcDbViewportTableRecord *pViewPortRec = NULL;
                Acad::ErrorStatus es = pVTable->getAt (_T("*Active"), pViewPortRec, AcDb::kForRead);
                if (es == Acad::eOk)
                  // get the height of the view
                  height = pViewPortRec->height ();
                  // get the width
                  width = pViewPortRec->width ();
                  // if the user wants the center of the viewport used
                  if (getViewCenter == true)
                        struct resbuf rb;
                        memset (&rb, 0, sizeof (struct resbuf));
                        // get the system var VIEWCTR
                        acedGetVar (_T("VIEWCTR"), &rb);
                        // set that as the target
                        target = AcGePoint3d (rb.resval.rpoint[X], rb.resval.rpoint[Y], rb.resval.rpoint[Z]);
                  // we want the viewport's camera target setting
                  else
                        // get the target of the view
                        target = pViewPortRec->target ();
                  // get the view direction
                  viewDir = pViewPortRec->viewDirection ();
                  // get the view twist of the viewport
                  viewTwist = pViewPortRec->viewTwist ();
                  // return the current Visual Style
                  currentVsId = pViewPortRec->visualStyle();
                // close after use
                pViewPortRec->close();
          acDocManager->unlockDocument(pDoc);
          // now restore the original document
          acDocManager->setCurDocument(acDocManager->mdiActiveDocument());
          return (true);
// set the passed AcGsView to the *Active* AutoCAD AcDbDatabase view
        static AcDbObjectId SetViewTo(AcGsView *pView, AcDbDatabase *pDb, AcGeMatrix3d& viewMat)
          // we are going to set the view to the current view of the drawing
          // The overall approach is to calculate the extents of the database in the coordinate system of the view
          // Calculate the extents in WCS
          AcGePoint3d extMax = pDb->extmax();
          AcGePoint3d extMin = pDb->extmin();
          // initialize it with sensible numbers - even if there is no entity
          if (extMin.distanceTo(extMax) > 1e20)
                  extMin.set(0, 0, 0);
                  extMax.set(100, 100, 100);
          // get the view port information - see parameter list
          ads_real height = 0.0, width = 0.0, viewTwist = 0.0;
          AcGePoint3d targetView;
          AcGeVector3d viewDir;
          AcDbObjectId currentVsId;
          GetActiveViewPortInfo (pDb, height, width, targetView, viewDir, viewTwist, currentVsId, true);
          // we are only interested in the directions of the view, not the sizes, so we normalise.
          viewDir = viewDir.normal();
          // Our view coordinate space consists of z direction
          // get a perp vector off the z direction
          // Make sure its normalised
          AcGeVector3d viewXDir = viewDir.perpVector ().normal();
          // correct the x angle by applying the twist
          viewXDir = viewXDir.rotateBy (viewTwist, -viewDir);
          // now we can work out y, this is of course perp to the x and z directions. No need to normalise this,
          // as we know that x and z are of unit length, and perpendicular, so their cross product must be on unit length
          AcGeVector3d viewYDir = viewDir.crossProduct (viewXDir);
          // find a nice point around which to transform the view. We'll use the same point as the center of the view.
          AcGePoint3d boxCenter = extMin + 0.5 * ( extMax - extMin );
          // create a transform from WCS to View space
          // this represents the transformation from WCS to the view space. (Actually not quite since
          // we are keeping the fixed point as the center of the box for convenience )
          viewMat = AcGeMatrix3d::alignCoordSys (boxCenter, AcGeVector3d::kXAxis, AcGeVector3d::kYAxis, AcGeVector3d::kZAxis,
                boxCenter, viewXDir, viewYDir, viewDir).inverse();
          AcDbExtents wc**tents(extMin, extMax);
          // now we have the view Extents
          AcDbExtents viewExtents = wc**tents;
          // transforms the extents in WCS->view space
          viewExtents.transformBy (viewMat);
          // get the extents of the AutoCAD view
          double xMax = fabs(viewExtents.maxPoint ().x - viewExtents.minPoint ().x);
          double yMax = fabs(viewExtents.maxPoint ().y - viewExtents.minPoint ().y);
          // setup the view
          AcGePoint3d eye = boxCenter + viewDir;
          // upvector
          pView->setView(eye, boxCenter, viewYDir, xMax, yMax);
          // update the gsView
          refreshView(pView);
          return currentVsId;
static void refreshView(AcGsView *pView)
          if (pView != NULL)
                pView->invalidate();
                pView->update();
发表于 2017-1-11 08:55:05 | 显示全部楼层
以前看见过类似代码,但一直没有搞明白。再次学习中
发表于 2017-1-11 11:28:02 | 显示全部楼层
我只是路过打酱油的
GMT+8, 2026-11-22 11:30 , Processed in 0.412576 second(s), 12 queries , Gzip On, File On.
