查看: 1947|回复: 6
[每日一码] ARX插入图像的代码
发表于 2017-1-10 15:36:18 | 显示全部楼层 |阅读模式
void InsertImage()
    ACHAR* szName = _T("MyTest");
    ACHAR *fileName = _T("C:\\temp\\newImage.jpeg");
    AcGePoint3d org(10,10,0);
    AcDbDatabase *pDb =
      acdbHostApplicationServices()->workingDatabase();
     AcDbRasterImageDef* pImageDef = new AcDbRasterImageDef();
     Acad::ErrorStatus es = pImageDef->setSourceFileName(fileName);
     if(es != Acad::eOk)
          delete pImageDef;
          return;
     es = pImageDef->load();
     ASSERT(es == Acad::eOk);
     AcDbObjectId dictID = AcDbRasterImageDef::imageDictionary(pDb);
     if (dictID==AcDbObjectId::kNull)
         es = AcDbRasterImageDef::createImageDictionary(pDb, dictID);
         if(es!= Acad::eOk)
              delete pImageDef;
              ads_printf(_T("\nCould not create dictionary\n"));
              return;
     AcDbDictionary* pDict = NULL;
     es = acdbOpenObject((AcDbObject*&)pDict,
                                            dictID, AcDb::kForWrite);
     if(es != Acad::eOk)
          delete pImageDef;
          ads_printf(_T("\nCould not open dictionary\n"));
          return;
     BOOL bExist = pDict->has(szName);
     AcDbObjectId objID;
     if (!bExist)
          pDict->setAt(szName, pImageDef, objID);
     else
          pDict->getAt(szName,
                    (AcDbObject*&)pImageDef,AcDb::kForWrite);
          objID = pImageDef->objectId();
     // close Dictionary and Definition.
     pDict->close();
     pImageDef->close();
     AcDbRasterImage* pImage = new AcDbRasterImage;
     es = pImage->setImageDefId(objID);
     if (es != Acad::eOk)
          delete pImage;
          return;
    AcDbObjectId modelId;
    modelId = acdbSymUtil()->blockModelSpaceId(pDb);
    AcDbBlockTableRecord *pBTRecord;
    acdbOpenAcDbObject((AcDbObject*&)pBTRecord,
                                    modelId, AcDb::kForWrite);
     es = pBTRecord->appendAcDbEntity(pImage);
     pBTRecord->close();
     AcDbObjectId entID = pImage->objectId();
     AcGePoint3d TempPoint3d(3.0, 0, 0);
     AcGeVector3d LowerRightVector = TempPoint3d.asVector();
     AcGePoint3d TempPoint3d2(0, 1.5, 0);
     AcGeVector3d OnPlaneVector = TempPoint3d2.asVector();
     if (pImage->setOrientation(org,
                LowerRightVector, OnPlaneVector) !=Adesk::kTrue)
          ads_printf(_T("\nSet Orientation failed."));
          pImage->close();
          return;
     pImage->setDisplayOpt(AcDbRasterImage::kShow, Adesk::kTrue);
     pImage->setDisplayOpt(AcDbRasterImage::kTransparent,
                                                    Adesk::kTrue);
    AcDbObjectPointer<AcDbRasterImageDefReactor>
                                            rasterImageDefReactor;
    // new it
    rasterImageDefReactor.create();
    // Set the entity to be its owner.
    es = rasterImageDefReactor->setOwnerId(pImage->objectId());
    // if ok
    if (es == Acad::eOk)
        AcDbObjectId defReactorId;
        // assign the object an objectId
        es = pDb->addAcDbObject(defReactorId,
                            rasterImageDefReactor.object());
        // if ok
            // set the image reactor id
            pImage->setReactorId(defReactorId);
            AcDbObjectPointer<AcDbRasterImageDef>
                rasterImagedef(pImage->imageDefId(),
                                            AcDb::kForWrite);
            // if ok
            if (rasterImagedef.openStatus() == Acad::eOk)
                rasterImagedef->addPersistentReactor(defReactorId);
     pImage->close();
发表于 2017-1-10 19:11:41 | 显示全部楼层
谢谢作者,学习中
发表于 2017-1-11 08:05:17 | 显示全部楼层
回的人少,我来小顶一下
发表于 2017-1-11 08:30:43 | 显示全部楼层
好好学习天天向上
发表于 2017-1-11 08:50:06 | 显示全部楼层
调试了下,证明代码可用。如果再加上图像文件对话框选择,图像原始尺寸的识别,图像尺寸及插入位置的设置,就更方便使用了。不过,有了这个核心代码,其它功能比较容易加入。再次真诚地谢谢作者!
发表于 2017-1-11 09:12:23 | 显示全部楼层
谢谢!!!!!!
发表于 2017-1-11 11:26:18 | 显示全部楼层
确实是难得好帖啊,顶先
GMT+8, 2026-11-22 08:11 , Processed in 0.288122 second(s), 20 queries , Gzip On, File On.
