楼主: coldhope
[求助] 被分解的尺寸标注如何全部恢复
已领礼包: 20个
发表于 2017-1-14 12:15:17 | 显示全部楼层
真服了这个图了, 所有尺寸都是散的不说,还所有东西都画到0层上,这是小日本画的图?
而且看了图,还不如一楼的图,一楼的好在尺寸大多还是按着顺序的, 这个图完全没顺序啊。
楼主,一楼和第二次的图,哪个是你画的? 哪个是软件生成的?
发表于 2017-1-14 23:47:01 | 显示全部楼层
写好了, 试试
处理了你2.rar里面的第一个图,都炸开后,执行TT,总共210个标注。执行命令前,记得把你们那个尺寸标注样式1-30给拷贝到图中来,否则生成的尺寸没有圆箭头。
附件是处理好的图
文件名称:Drawing1.rar
下载次数:6  文件大小:169.02 KB
(defun c:tt (/ #endpoint #startpoint ang bdim box center dstyle eline height
               k p1 p2 pnts ss ss1 ss2 ss3 ss5 strpnts tf txt v1 v2 x
               xdimpnt xdims y
  (defun _ssadd (ss5 ss)
    (mapcar
      '(lambda (x)
         (ssadd x ss5)
      (xdrx_pickset->ents ss)
  (defun _process1 (ss3)
    (mapcar
      '(lambda (x)
         (setq pnts (xdrx_getpropertyvalue x "vertices")
               v2 (mapcar
                    (cadr pnts)
                    (car pnts)
               v2 (xdrx_vector_normalize v2)
         (if (equal (/ pi 2.0) (abs (xd::geom:angleformat
                                                          (xdrx_vector_angle v1 v2)
                               ) 1e-3
           (progn
             (if (and
                   (xdrx_entity_intersectwith x ss2)
                   (< (length xdimpnt) 2)
                   (vl-every '(lambda (y)
                                (xdrx_getpropertyvalue y "startpoint"
                                                       "endpoint"
                                (and
                                  (not (equal (xdrx_point_dist2line
        (car pnts) #startpoint #endpoint
                                              ) 0 1
        (cadr pnts) #startpoint #endpoint
                                              ) 0 1
                              ) xdims
               (progn
                 (setq xdims (cons x xdims))
                 (if (vl-position (car pnts) (list p1 p2))
                   (setq xdimpnt (cons (cadr pnts) xdimpnt)
                   (setq xdimpnt (cons (car pnts) xdimpnt))
      (xdrx_pickset->ents ss3)
    xdimpnt
  (defun _process (x)
    (setq box (xdrx_entity_box x)
          center (xd::geom:get9pt x 5)
          height (xdrx_getpropertyvalue x "textheight")
          txt (xdrx_getpropertyvalue x "textstring")
          box (xdrx_points_offset 30.0 (xd::pnts:close box))
          eline nil
    (if (and
          (if (xdrx_string_regexps "^[0-9.]+$" txt)
            (setq ss1 (ssget "cp" box '((0 . "LINE"))))
      (progn
        (mapcar
          '(lambda (x)
             (if (equal (xdrx_getpropertyvalue x "length") (atof txt) 1)
               (setq eline x)
          (xdrx_pickset->ents ss1)
        (if eline
          (progn
            (setq p1 (xdrx_getpropertyvalue eline "startpoint")
                  p2 (xdrx_getpropertyvalue eline "endpoint")
                  v1 (mapcar
                       p2
                       p1
                  v1 (xdrx_vector_normalize v1)
                  ang (xd::geom:angleformat (angle p1 p2))
            (if (setq ss2 (ssget "f" (list p1 p2) '((0 . "CIRCLE"))))
              (progn
                (if (setq ss3 (ssget "f" (list p1 p2) '((0 . "LINE"))))
                  (progn
                    (ssdel eline ss3)
                    (setq xdimpnt nil
                          xdims nil
                    (setq xdimpnt (_process1 ss3))
                    (if (= (length xdimpnt) 2)
                      (progn
                        (_ssadd ss5 ss2)
                        (ssadd x ss5)
                        (_ssadd ss5 ss3)
                        (if (xdrx_object_get "dimstyle" "1-30")
                          (setq dstyle "1-30")
                          (setq dstyle "iso-25")
                        (xdrx_dimension_makerotate (car xdimpnt)
                                                   (cadr xdimpnt) p1 ang
                                                   dstyle
                        (setq k (1+ k))
                        (setq bdim t)
                        (setq strpnts (xdrx_entity_getstretchpoint
        (entlast)
                        (if (> (distance (last strpnts) center) (/ height
        2.0
                          (xdrx_entity_movestretchpoint (entlast)
                                                        (mapcar
                                                          center
                                                          (last strpnts)
                                                        ) 4
  (xdrx_begin)
  (xdrx_initssget "\n选取组合成标注的数字<全选>:")
  (if (or
        (setq ss (xdrx_ssget '((0 . "*TEXT") (1 . "*[0-9]*"))))
        (setq ss (xdrx_ssget "X" '((0 . "*TEXT") (1 . "*[0-9]*"))))
    (progn
      (setq ss5 (ssadd)
            bdim nil
      (setq tf (xd::doc:safezoom ss))
      (setq k 0 kk 0)
      (xdrx_statusbar_begin "处理中" (sslength ss))
      (mapcar
        '(lambda (x)
           (_process x)
           (setq kk (1+ kk))
           (xdrx_statusbar_setpos kk)
      (xdrx_statusbar_end)
      (xdrx_entity_delete ss5)
      (xdrx_prompt "\n生成了" k "个尺寸标注.")
      (if tf
        (xdrx_document_zoomprevious)
    (xdrx_prompt "\n图中没有符合条件的数字文本.")
  (xdrx_end)
  (princ)
已领礼包: 17个
发表于 2017-1-15 13:38:10 | 显示全部楼层
newer 一直膜拜的大神
 楼主| 发表于 2017-1-18 13:47:02 | 显示全部楼层
对不起回信晚了,这两天年底太忙了
程序是要另存为 .lsp吧,运行后显示未定义 XDRX_BEGIN
我下载了API 函数库和晓东工具箱,可是我们用的都是日文系统,装不上啊
愁死我了,这么好的程序用不了
 楼主| 发表于 2017-1-18 13:57:12 | 显示全部楼层
日文系统下怎样加载API函数库和晓东工具箱
发表于 2017-1-18 14:15:08 | 显示全部楼层
运行, regedit.exe
把注册表下面图画红框的截图,贴到论坛
发表于 2017-1-18 14:19:55 | 显示全部楼层
你安装晓东工具箱时候,系统什么提示? 看到的都截图贴上来
已领礼包: 1268个
发表于 2017-1-18 19:20:06 来自手机 | 显示全部楼层
日文版后面的号应该不一样,可能安装不上
GMT+8, 2026-11-3 07:31 , Processed in 0.511774 second(s), 43 queries , Gzip On.
