查看: 1942|回复: 1
[每日一码] 转换Annotative Text到 Text
已领礼包: 20个
发表于 2017-1-17 10:14:29 | 显示全部楼层 |阅读模式
;;; Scan entire drawing for Annotative Text and Convert to Text
;;; find mtext or text and remove dxf -1 102 330 360 and
;;; make new entity then delete old entity.
(defun c:AnnoConvertText (/ ss)
  (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT"))))
    ((lambda (i / e)
       (while (setq e (ssname ss (setq i (1+ i))))
         (if (entmakex (vl-remove-if (function (lambda (x)
                                                 (vl-position (car x) '
                                                              (-1 102 330
        360
                                     ) (entget e)
           (entdel e)
       )                               ; while
     ) -1
    )                                       ; lambda
  )                                       ; if
  (princ)
已领礼包: 1094个
发表于 2021-12-2 06:39:09 | 显示全部楼层
感谢分享转换Annotative Text到 Text
GMT+8, 2026-11-3 01:43 , Processed in 0.432764 second(s), 30 queries , Gzip On.
