查看: 1248|回复: 2
[求助] 关于填充图案的解析
发表于 2017-1-19 10:03:58 | 显示全部楼层 |阅读模式
大家好, 想实现如下图的功能:
将目前版本的CAD中支持的填充图案,在.NET 的FORM程序加载出来,不知道CAD有没有类似直接读取PAT文件内容后生成Image格式的方法?
如果没有需要自己读取格式后生成吗?
谢谢大家;
发表于 2017-1-19 10:06:48 | 显示全部楼层
我只是路过打酱油的
发表于 2017-1-20 00:34:33 | 显示全部楼层
.下面是.net通过DrawableOverrule实现填充的代码,你可以看看是否有帮助
If you need an entity to appear hatched temporarily, drawable overrule can be used for this purpose. Drawing the hatch pattern from an WorldDraw / ViewportDraw can be simple or a little complex depending on the pattern that you want to use. To let the hatch pattern correctly fill the boundary, a clip boundary can be created in your overrule. This simplifies the overrule implementation as the pattern can be created to cover the entity while the clip boundary takes care of clipping it to the actual entity bounds.
Here are two screenshots before and after clipping
Here is a sample code to hatch a circle with the cross pattern using DrawableOverrule
public  class  HatchedCircleOverrule
        : DrawableOverrule
        public  override  bool  IsApplicable(RXObject subject)
                Circle circle = subject as  Circle;
                if  (circle.Database == null )
                        return  false ;
                return  true ;
        public  override  void  ViewportDraw
                (Drawable drawable, ViewportDraw vd)
                base .ViewportDraw(drawable, vd);
                Circle circle = (Circle)drawable;
                Point3d cenPt = circle.Center;
                ClipBoundary cb = new  ClipBoundary();
                cb.DrawBoundary = false ;
                FrontAndBackClipping clipping
                        = vd.Viewport.FrontAndBackClipping;
                cb.ClippingBack = clipping.ClipBack;
                cb.ClippingFront = clipping.ClipFront;
                cb.NormalVector = vd.Viewport.ViewDirection;
                cb.BackClipZ = clipping.Back;
                cb.FrontClipZ = clipping.Front;
                Point2dCollection clipPts
                        = new  Point2dCollection();
                double  paramIncr =
                        (circle.EndParam - circle.StartParam) / 100;
                double  param = circle.StartParam;
                Plane pln = new  Plane(cenPt, circle.Normal);
                for  (int  cnt = 0; cnt < 100; cnt++)
                        clipPts.Add(
                                circle.GetPointAtParameter(param).Convert2d(pln));
                        param += paramIncr;
                clipPts.Add(
                        circle.GetPointAtParameter(circle.EndParam).Convert2d(pln));
                cb.SetAptPoints(clipPts);
                vd.Geometry.PushClipBoundary(cb);
                vd.SubEntityTraits.TrueColor
                        = new  EntityColor(0, 255, 0);
                Point3dCollection vertices
                        = new  Point3dCollection();
                int  divs = 8;
                double  delX = circle.Diameter / divs;
                double  delY = circle.Diameter / divs;
                for  (int  row = 0; row <= divs; row++)
                        Point3d currPt =
                                cenPt
                                - Vector3d.XAxis * circle.Radius
                                - Vector3d.YAxis * circle.Radius
                                + Vector3d.YAxis * row * delY;
                        for  (int  col = 0; col <= divs; col++)
                                vertices.Clear();
                                vertices.Add(
                                        currPt + Vector3d.XAxis * delX * 0.25);
                                vertices.Add(
                                        currPt - Vector3d.XAxis * delX * 0.25);
                                vd.Geometry.Polyline(
                                        vertices, Vector3d.ZAxis, new  IntPtr (-1));
                                vertices.Clear();
                                vertices.Add(
                                        currPt + Vector3d.YAxis * delY * 0.25);
                                vertices.Add(
                                        currPt - Vector3d.YAxis * delY * 0.25);
                                currPt = currPt + Vector3d.XAxis * delX;
                vd.Geometry.PopClipBoundary();
        public  override  bool  WorldDraw
                (Drawable drawable, WorldDraw wd)
                base .WorldDraw(drawable, wd);
                // call viewportdraw
                return  false ;
public  class  Commands  : IExtensionApplication
        private  static  HatchedCircleOverrule  _hco;
        void  IExtensionApplication.Initialize() { }
        void  IExtensionApplication.Terminate()
                if  (_hco != null )
                        Overrule.RemoveOverrule
                                (RXClass.GetClass(typeof (Circle)), _hco);
                        _hco.Dispose();
                        _hco = null ;
        [CommandMethod("StartOR" )]
        public  void  StartORMethod()
                Document doc
                        = Application .DocumentManager.MdiActiveDocument;
                if  (_hco == null )
                        _hco = new  HatchedCircleOverrule ();
                        _hco.SetCustomFilter();
                        Overrule.AddOverrule
                                _hco, true );
                        Overrule.Overruling = true ;
                doc.Editor.WriteMessage("\nOverruling started !" );
                doc.Editor.Regen();
        [CommandMethod("StopOR" )]
        public  void  StopORMethod()
                Document doc
                if  (_hco != null )
                        Overrule.RemoveOverrule(
                        Overrule.Overruling = false ;
                        _hco.Dispose();
                        _hco = null ;
                doc.Editor.WriteMessage("\nOverruling stopped !" );
                doc.Editor.Regen();
GMT+8, 2026-11-22 11:04 , Processed in 0.314140 second(s), 13 queries , Gzip On, File On.
