查看: 1919|回复: 6
[研讨] [查找替换]
发表于 2017-1-19 14:54:02 | 显示全部楼层 |阅读模式
;;[查找替换]成功
(defun w3 (str old New compare)
  (or *scr*
      (setq *scr* (vlax-create-object "MSScriptControl.ScriptControl.1"))
  (vlax-put *scr* "language" "vbscript")
  (vlax-invoke
    *scr*
    'ExecuteStatement
    (strcat "x = Replace("
            (VL-PRIN1-TO-STRING str)
            (VL-PRIN1-TO-STRING old)
            (VL-PRIN1-TO-STRING new)
            (VL-PRIN1-TO-STRING compare)
  (vlax-invoke *scr* 'eval "x")
;;;;;示例==>Command: w3 "5-5"
;;;(defun C:w3 ()
;;;  (w3 "5.5" "." "-" 1)
;;;(w3"1234567890123456""123""a" 1)=>"a4567890a456"
;;;Sub fig8()
;;;Set x = CreateObject("msscriptcontrol.scriptcontrol")
;;;x.Language = "vbscript"
;;;x.addcode "sub aa(): msgbox ""hello.."":end sub : sub bb:msgbox 3:end sub :sub cc: msgbox ""cc"":end sub"
;;;x.Run "aa"
;;;x.Run "bb"
;;;x.Run "cc"
;;;End Sub
(defun w6 ()
  (or *scr*
  (vlax-invoke
    *scr*
    'AddCode
    "sub aa(): msgbox \"hello..\":end sub : sub bb:msgbox 3:end sub :sub cc: msgbox \"cc\":end sub"
  (vlax-invoke *scr* 'run "aa")
  (vlax-invoke *scr* 'run "bb")
  (vlax-invoke *scr* 'run "cc")
;;;(w6);成功
;;;自定义函数的用法
;;;Sub fig8()
;;;x.addcode "function sum(x,y):sum=x+y:end function "
;;;bb = x.Run("sum", 2, 3)
;;;MsgBox bb
;;;End Sub
(defun w7 ()
  (or *scr*
  (vlax-invoke
    *scr*
    'AddCode
  (vlax-invoke *scr* 'run "sum" 2 3)
;;;(w7)=>5
 楼主| 发表于 2017-1-19 14:59:28 | 显示全部楼层
网上可以搜到《在VBA中使用JAVASCRIPT和VBSCRIPT(1)》,各位版主,有没有《在Lisp中使用JAVASCRIPT和VBSCRIPT(1)》?
问题:当我想将“人之初”三个字写入一个文本文件,没有成功?
;;;(w5)
(defun w5 ()
  (or *scr*
      (setq *scr* (vlax-get-or-create-object "msscriptcontrol.scriptcontrol"))
  (vlax-invoke
    *scr*
    'AddCode
    "Sub StrToTxt(ByVal txt As String)
            Open \"D://MySwap.txt\" For Output As #1
            Write #1, txt
            Close #1
    End Sub"
  );本句错误
  (vlax-invoke *scr* 'run "StrToTxt" "人之初")
在VBA中使用JAVASCRIPT和VBSCRIPT.doc
118.5 KB, 下载次数: 5, 下载积分: D豆 -1 , 活跃度 1
售价: 1 D豆  [记录]
已领礼包: 6056个
发表于 2017-1-21 22:15:44 | 显示全部楼层
谢谢分享!
已领礼包: 20个
发表于 2017-1-21 22:26:04 | 显示全部楼层
这本书确实有,还是你自己想的名字?
找到了,分享一下吧  发表于 2017-1-22 09:14
已领礼包: 10个
发表于 2020-5-15 17:40:44 | 显示全部楼层
喜欢看到简短的代码
已领礼包: 10个
发表于 2020-5-16 18:45:37 | 显示全部楼层
打卡了
GMT+8, 2026-11-4 03:00 , Processed in 0.685195 second(s), 44 queries , Gzip On.
