查看: 3276|回复: 6
[每日一码] 一个工具箱的自动加载程序的设计的例子
已领礼包: 20个
发表于 2017-1-20 13:35:33 | 显示全部楼层 |阅读模式
;;; 判断是否加载本文件
(if (car (atoms-family 1 '("vl-load-com")))
  (vl-load-com)
  ;;else
  (progn
    (Alert
      "这个程序集是为AutoCAD 2000以及更高的版本设计的,许多程序有可能在没有Visual Lisp for R14支持的AutoCAD R14上不能正确地运行。"
    (exit)                                ; 版本不符,退出加载。
(defun InitCywApplication (/
                           ;; 内部函数
                           GetMyApplicationPath
                           GetCywPath               strParse
                           StrUnParse               Cyw_AddSupportPath
                           Load_CywMenu               Cyw_placemenu
                           ;; 局部变量
                           Cyw_cmdecho_save
;;; 取得本程序的路径
  (defun GetMyApplicationPath (AppID)
    (vl-registry-read
      (strcat
        "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\"
        AppID
        "_is1"
      "Inno Setup: App Path"
  (defun GetCywPath ()
    (GetMyApplicationPath "cyw for AutoCAD")
;;; 解析字符串为表(函数来自明经通道转载)
  (defun strParse (Str Delimiter / SearchStr StringLen return n char)
    (setq SearchStr Str)
    (setq StringLen (strlen SearchStr))
    (setq return '())
    (while (> StringLen 0)
      (setq n 1)
      (setq char (substr SearchStr 1 1))
      (while (and (/= char Delimiter) (/= char ""))
        (setq n (1+ n))
        (setq char (substr SearchStr n 1))
      ) ;_ end of while
      (setq return (cons (substr SearchStr 1 (1- n)) return))
      (setq SearchStr (substr SearchStr (1+ n) StringLen))
    ) ;_ end of while
    (reverse return)
  ) ;_ end of defun
;;; 反解析表为字符串(函数来自明经通道转载)
  (defun StrUnParse (Lst Delimiter / return)
    (setq return "")
    (foreach str Lst
      (setq return (strcat return Delimiter str))
    ) ;_ end of foreach
    (substr return 2)
  ) ;_ end of defun
;;; 添加支持文件搜索路径
;;; note:  第二个参数如果为真, 插最前,否则插最后
  (defun Cyw_AddSupportPath (PathToAdd isFirst / supportlist)
    (if        (not
          (vl-string-search
            (strcase (strcat pathToAdd ";"))
            (strcase (strcat (getenv "ACAD") ";"))
        )                                ; 保证不重复添加
      (progn
        (setq supportlist (strparse (getenv "ACAD") ";"))
        (setq supportlist
               (vl-remove-if-not
                 'vl-file-directory-p
                 supportlist
        )                                ; 移除不存在的文件夹
        (if isFirst
          (setq supportlist (cons PathToAdd supportlist))
          (setq supportlist (append supportlist (list PathToAdd)))
        (setenv "ACAD" (strUnParse supportlist ";"))
  (defun Load_CywMenu (/ acadver)
    (setq acadver (atof (getvar "acadver")))
    (cond
      ((and (>= acadver 15.0) (< acadver 16.0))
       (command "_menuload" "Cyw.mns")
      ((and (>= acadver 16.0) (<= acadver 16.1))
       (command "_menuload" "Cyw2004.mns")
      ((>= acadver 16.2) (command "_menuload" "Cyw2006.mns"))
  ;; The following code "placemenu" from LUCAS(龙龙仔)
  (defun Cyw_placemenu (/ n)
    (if        (menugroup "Cyw")
      (progn
        (setq n 1)
        (while (< n 24)
          (if (menucmd (strcat "P" (itoa n) ".1=?"))
            (setq n (+ n 1))
            (progn
              (if (> n 3)
                (setq n (- n 2))
                (setq n 3)
              )                                ;if
              (menucmd (strcat "p" (itoa n) "=+Cyw.pop1"))
              (setq n 25)
            )                                ;progn
          )                                ;if
        )                                ;while
      )                                        ;progn
    )                                        ;if
    (princ)
;;; 主程序:
  (setq Cyw_cmdecho_save (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  ;; 加载下拉菜单
  (Cyw_AddSupportPath (GetCywPath) nil)
  ;; 如果菜单组还没有被加载,则加载之
  (if (not (menugroup "Cyw"))
    (Load_CywMenu)
  ;; 插到合适的位置
  (Cyw_placemenu)
  (setvar "cmdecho" Cyw_cmdecho_save)
  (setq Cyw_cmdecho_save nil)
  (princ)
) ;_end of defun initCywApplication
(initCywApplication)
;; 加载主程序
(if (findfile "mm.lsp")
  (load "mm.lsp")
(if (findfile "LSP_shzgb.LSP")
  (load "LSP_shzgb.LSP")
(if (findfile "initial.lsp")
  (load "initial.lsp")
(if (findfile "int_str.lsp")
  (load "int_str.lsp")
(if (findfile "ahobj.lsp")
  (load "ahobj.lsp")
(if (findfile "FASTZOOM.LSP")
  (LOAD "FASTZOOM.LSP")
(if (findfile "puu.lsp")
  (load "puu.lsp")
(if (findfile "chgt.lsp")
  (load "chgt.lsp")
(if (findfile "ddchprop")
  (load "ddchprop")
(if (findfile "wbbj.VLX")
  (load "wbbj.VLX")
(if (findfile "y.VLX")
  (load "y.VLX")
(if (findfile "ddmodify.VLX")
  (load "ddmodify.VLX")
(if (findfile "BatchPlot.lsp")
  (load "BatchPlot.lsp")
(if (findfile "pjgb.arx")
  (arxLOAD "pjgb.arx")
(if (findfile "chtext.LSP")
  (LOAD "chtext.LSP")
(if (findfile "ff.LSP")
  (LOAD "ff.LSP")
(if (findfile "ali1.LSP")
  (LOAD "ali1.LSP")
  (LOAD "chtext.LSP")
(if (findfile "qzfl.lsp")
  (LOAD "qzfl.lsp")
(if (findfile "jss.vlx")
  (LOAD "jss.vlx")
(if (findfile "wbdq.vlx")
  (LOAD "wbdq.vlx")
(if (findfile "zhuang.lsp")
  (LOAD "zhuang.lsp")
(if (findfile "gbj.vlx")
  (LOAD "gbj.vlx")
(if (findfile "miban.vlx")
  (LOAD "miban.vlx")
(princ)
评分
参与人数 1D豆 +5 收起 理由
shuaier + 5
查看全部评分
已领礼包: 1268个
发表于 2017-1-20 15:56:57 | 显示全部楼层
用 Inno Setup 制作的安装程序可以直接把 Support 路径写入注册表,对全部 alisp 程序,加上 acad.lsp 或者 acaddocxxx.lsp 就可以自动加载了
已领礼包: 3191个
发表于 2017-1-20 16:02:21 | 显示全部楼层
啥也不说了,感谢楼主分享!有收获
已领礼包: 862个
发表于 2017-1-21 20:07:33 | 显示全部楼层
正需要,支持楼主大人了!
已领礼包: 312个
发表于 2017-1-21 20:32:56 来自手机 | 显示全部楼层
太有用了,感谢!
已领礼包: 4个
发表于 2020-4-7 10:21:59 | 显示全部楼层
太需要了,,,,,,,,,,,,,,,,,
发表于 2021-3-6 12:45:18 | 显示全部楼层
正需要,支持楼主大人了!
GMT+8, 2026-11-3 09:40 , Processed in 0.489433 second(s), 45 queries , Gzip On.
