查看: 3215|回复: 9
[每日一码] 模拟ZOOM命令的ARX代码
发表于 2017-1-24 12:23:39 | 显示全部楼层 |阅读模式
// This is command 'ZOOMEXT, by Fenton Webb [Apr/17/2002], DevTech, Autodesk
void asdkzoomExt()
        // get the extents of the drawing
        AcDbViewTableRecord view;
        AcGePoint3d max =
                acdbHostApplicationServices()->workingDatabase()->extmax(),
                min = acdbHostApplicationServices()->workingDatabase()->extmin();
        AcGePoint2d max_2d (max, max);
        AcGePoint2d min_2d (min, min);
        // now set the view centre point
        view.setCenterPoint (min_2d + (max_2d - min_2d) / 2.0);
        // now height and width of view
        view.setHeight(max_2d - min_2d);
        view.setWidth (max_2d - min_2d);
        // set the view
        acedSetCurrentView (&view, NULL);
        // updates the extents
        acdbHostApplicationServices()->workingDatabase()->updateExt(TRUE);
// This is command 'ZOOMWIN, by Fenton Webb [Apr/17/2002], DevTech, Autodesk
void asdkzoomWin()
        AcGePoint3d max, min;
        // get the window coords
        int res = acedGetPoint (NULL, "\nPick zoom window pnt : ",
                asDblArray(min));
        // if ok
        if (res == RTNORM)
                res = acedGetCorner (asDblArray(min), "\nPick other corner : ",
                        asDblArray(max));
                // set the view
发表于 2017-1-25 00:21:16 | 显示全部楼层
謝謝版主的提供,來學習一下!!
发表于 2017-1-28 08:38:13 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-1-29 09:26:21 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2017-1-29 09:33:14 | 显示全部楼层
感觉很有用,已经用到了
发表于 2017-1-30 20:40:31 | 显示全部楼层
好资料,学习了。
发表于 2017-2-13 11:10:44 | 显示全部楼层
vs2005下测试有点问题,主要是参数问题,改了一下:
void  asdkzoomExt()
         //get the extents of the drawing
        AcGePoint3d max =
        AcGePoint2d max_2d (max.x , max.y );
        AcGePoint2d min_2d (min.x , min.y );
        view.setHeight(max_2d.y  - min_2d.y );
        view.setWidth (max_2d.x  - min_2d.x );
        // set the view
void  asdkzoomWin()
        int res = acedGetPoint (NULL, L"\nPick zoom window pnt : ",asDblArray(min));
        // if ok
        if (res == RTNORM)
                res = acedGetCorner (asDblArray(min), L"\nPick other corner : ",asDblArray(max));
                // set the view
发表于 2017-3-5 21:08:30 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2018-7-7 11:52:19 来自手机 | 显示全部楼层
这个好,恰好需要
发表于 2018-7-9 00:13:54 来自手机 | 显示全部楼层
版主,我没明年为什么为updateext,不要最后一个updateext有没有什么影响。我看手册里updateext会遍历所有对象再求ext,对象一多比如有几十万感觉影响速度啊
GMT+8, 2026-11-22 09:57 , Processed in 0.180085 second(s), 26 queries , Gzip On, File On.
