查看: 1695|回复: 3
[每日一码] 删除一个图层上所有引用该层的实体,并删除图层定义
发表于 2017-2-5 02:12:43 | 显示全部楼层 |阅读模式
void eraseLayer(CString layerName)
        AcDbDatabase *pDataBase = acdbHostApplicationServices()->workingDatabase();
        // get the AcDbObjectId of the layer
        AcDbLayerTable *pLayerTable;
        if (pDataBase->getSymbolTable(pLayerTable, AcDb::kForRead) != Acad::eOk)
                return;
        if (!pLayerTable->has(layerName))
                pLayerTable->close();
                return;
        AcDbObjectId layerId;
        if (pLayerTable->getAt(layerName, layerId) != Acad::eOk)
                return;
        // iterate through the AcDbBlockTable
        AcDbBlockTable *pBlockTable;
        if (pDataBase->getSymbolTable(pBlockTable, AcDb::kForRead) != Acad::eOk)
                return;
        AcDbBlockTableIterator *pTableIterator;
        if (pBlockTable->newIterator(pTableIterator) != Acad::eOk)
                pBlockTable->close();
                return;
        while (!pTableIterator->done())
                AcDbBlockTableRecord *pRecord;
                if (pTableIterator->getRecord(pRecord, AcDb::kForRead) == Acad::eOk)
                        // iterate through the AcDbBlockTableRecord
                        AcDbBlockTableRecordIterator *pRecordIterator;
                        if (pRecord->newIterator(pRecordIterator) == Acad::eOk)
                                while (!pRecordIterator->done())
                                        AcDbEntity *pEntity;
                                        if (pRecordIterator->getEntity(pEntity, AcDb::kForRead) == Acad::eOk)
                                                if (pEntity->layerId() == layerId)
                                                        if (pEntity->upgradeOpen() == Acad::eOk)
        pEntity->erase();
                                                pEntity->close();
                                        pRecordIterator->step();
                                delete pRecordIterator;
                        pRecord->close();
                pTableIterator->step();
        delete pTableIterator;
        // check if there is any other AcDbHardPointerId on the layer
        // if not, erase the layer
        AcDbObjectIdArray purgableIds;
        purgableIds.append(layerId);
        if (pDataBase->purge(purgableIds) == Acad::eOk)
                if (purgableIds.length() > 0)
                        AcDbLayerTableRecord *pLayer;
                        if (acdbOpenObject(pLayer, layerId, AcDb::kForWrite) == Acad::eOk)
                                pLayer->erase();
                                pLayer->close();
发表于 2017-2-5 09:00:07 来自手机 | 显示全部楼层
感谢楼主分享了这么多的arx实例 ,相信会激发更多的人学习arx的兴趣
发表于 2017-2-5 09:14:16 来自手机 | 显示全部楼层
发表于 2019-4-1 16:49:22 | 显示全部楼层
版主,如果是天正自定义实体,对象的图层跟它子实体的图层不一样,要怎样把子对象移到0层或其它层上?
GMT+8, 2026-11-22 09:11 , Processed in 0.375485 second(s), 14 queries , Gzip On, File On.
