查看: 1285|回复: 1
[每日一码] Create a MPolygon in AutoCAD using .NET By Augusto Goncalves MPolygon is a c...
已领礼包: 13个
发表于 2017-2-5 16:31:13 | 显示全部楼层 |阅读模式
MPolygon is a custom object created for AutoCAD Map 3D, but is also available in vanilla AutoCAD from ObjectARX. To use it from .NET, then the project need to reference the AcMPolygonMGD.dll and it is required to load the object enabler AcMPolygonObj19.dbx into AutoCAD prior to using MPolygon functions. Both files can be found in AutoCAD's install folder.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Geometry
Public Class MPolygonCommandClass
  ' to make sure the required DBX is loaded
  ' let's implement the extension application
  ' and load it on Initilize
  Implements IExtensionApplication
  Public Sub Initialize() _
    Implements IExtensionApplication.Initialize
    ' Make sure that AcMPolygonObj19.dbx is loaded for MPolygon
    ' the 19 version number is valid for AutoCAD 2013
    Autodesk.AutoCAD.Runtime. _
      SystemObjects.DynamicLinker.LoadModule( _
        "AcMPolygonObj19.dbx", False, False)
  End Sub
  Public Sub Terminate() _
    Implements IExtensionApplication.Terminate
    ' nothing is required for this sample
  End Sub
  <CommandMethod("CreateMPolygon")> _
  Public Sub CreateMPolygon()
    Dim db As Database = Application. _
      DocumentManager.MdiActiveDocument.Database
    Using transaction As Transaction = _
      db.TransactionManager.StartTransaction()
      Try
        ' open the block tabela and the model space
        Dim bt As BlockTable = transaction.GetObject( _
          db.BlockTableId, OpenMode.ForRead)
        Dim btr As BlockTableRecord = transaction.GetObject( _
          bt(BlockTableRecord.ModelSpace), _
          OpenMode.ForWrite)
        ' start creating the MPolygon
        ' by its loop
        Dim mPolygonLoop As MPolygonLoop
        mPolygonLoop = New MPolygonLoop()
        mPolygonLoop.Add(New BulgeVertex(New Point2d(2, 2), 0))
        mPolygonLoop.Add(New BulgeVertex(New Point2d(2, 1), 0))
        mPolygonLoop.Add(New BulgeVertex(New Point2d(1, 1), 0))
        mPolygonLoop.Add(New BulgeVertex(New Point2d(1, 2), 0))
        ' finally create the entity and append
        ' the the model space
        Dim mPolygon As MPolygon = New MPolygon()
        mPolygon.AppendMPolygonLoop(mPolygonLoop, False, 0)
        btr.AppendEntity(mPolygon)
        transaction.AddNewlyCreatedDBObject(mPolygon, True)
        transaction.Commit()
      Catch ex As Exception
        Debug.WriteLine(ex.ErrorStatus)
        Debug.WriteLine(ex.Message)
      End Try
    End Using
  End Sub
End Class
已领礼包: 10个
发表于 2020-9-19 18:55:54 | 显示全部楼层
thank artc.
GMT+8, 2026-11-3 04:03 , Processed in 0.368079 second(s), 30 queries , Gzip On.
