查看: 1520|回复: 1
[每日一码] 创建文字样式,写文字,修改样式的代码
已领礼包: 13个
发表于 2017-2-6 10:02:21 | 显示全部楼层 |阅读模式
static void ChangeStyle() {
        AcDbObjectId styleId;
        // Create a text style
                AcDbObjectPointer<AcDbTextStyleTable>
                        pTextStyleTable(acdbCurDwg()->textStyleTableId(), AcDb::kForWrite);
                AcDbObjectPointer<AcDbTextStyleTableRecord> pStyle;
                pStyle.create();
                pStyle->setName(L"MyStyle");
                pStyle->setFileName(L"romans.shx");
                if (pTextStyleTable->add(styleId, pStyle.object()) != Acad::eOk)
                        pTextStyleTable->getAt(L"MyStyle", styleId);
        acedAlert(L"created text style");
        AcDbObjectId idtext;
        // Create some text
                AcDbObjectPointer<AcDbText> pText;
                pText.create();
                pText->setDatabaseDefaults();
                pText->setTextStyle(styleId);
                pText->setTextString(L"Some text");
                pText->setHeight(10);
                AcDbObjectPointer<AcDbBlockTableRecord>
                        pSpace(acdbCurDwg()->currentSpaceId(), AcDb::kForWrite);
                pSpace->appendAcDbEntity(idtext, pText);
        acTransactionManagerPtr()->flushGraphics();
        acedUpdateDisplay();
        acedAlert(L"created text");
                // Change the font file for the text style
                        pStyle(styleId, AcDb::kForWrite);
                pStyle->setFileName(L"romand.shx");
                        pSpace(acdbCurDwg()->currentSpaceId(), AcDb::kForRead);
                AcDbBlockTableRecordIterator *pIter = NULL;
                pSpace->newIterator(pIter);
                AcDbObjectId id;
                for (; !pIter->done(); pIter->step())
                        id.setNull();
                        pIter->getEntityId(id);
                        if (id.objectClass()->isDerivedFrom(AcDbText::desc()) ||
                                id.objectClass()->isDerivedFrom(AcDbMText::desc()) ||
                                id.objectClass()->isDerivedFrom(AcDbDimension::desc()) ||
                                id.objectClass()->isDerivedFrom(AcDbBlockReference::desc()))
                                AcDbEntityPointer pEnt(id, AcDb::kForWrite);
                                if (pEnt.openStatus() == Acad::eOk)
                                        pEnt->recordGraphicsModified();
                delete pIter;
        acedAlert(L"Custom Regen Current Space");
已领礼包: 69个
发表于 2017-2-6 15:04:47 | 显示全部楼层
啥也不说了,感谢楼主分享哇!如何设置有大,小字体的样式? 如果自己选择的部分文字,如何修改字体样式?
GMT+8, 2026-11-3 06:08 , Processed in 0.624917 second(s), 30 queries , Gzip On.
