查看: 4067|回复: 6
[每日一码] LISP加载.MLN(多线样式)文件
已领礼包: 20个
发表于 2017-2-7 17:04:53 | 显示全部楼层 |阅读模式
(defun c:LoadMlStyles (/ mlFileName)
   (setq mlFileName (getstring "\nEnter MLN file name: "))
   (if (/= nil mlFileName)
      (LoadMln mlFileName)
   (princ)
(defun LoadMln (mlnFile / f mlineDict same newStyle xName)
   (setq mlnFile (findfile mlnFile))
   (setq f (open mlnFile "r"))
   ;;(setq f (open mlnFile "r"))
   (if (= NIL f)
      (princ "\nInvalid MLN file.\n")
      (progn
         ;; Get the MLINESTLYE dictionary.
         (setq mlineDict (dictsearch (namedobjdict) "ACAD_MLINESTYLE"))
         ;; Create the beginning of an MLINESTYLE object.
         (setq same (list (cons 0 "MLINESTYLE")
                                 ;;(cons 102 "{ACAD_REACTORS")
                                 ;;(cons 330 (cdr (assoc -1 mlineDict)))
                                 ;;(cons 102 "}")
                                 (cons 100 "AcDbMlineStyle")
         ;; Read the data of the MLINESTYLE
         (while (/= nil (setq mlStyle (ReadObject f)))
            ;; Create the complete MLINESTYLE object.
            (setq newStyle (append same mlStyle)
                     xName    (entmakex newStyle)
            ;; Append it to the MLINESTYLE dictionary.
            (dictadd (cdr (assoc -1 mlineDict))
               (cdr (assoc 2 newStyle))
               xName
   (close f)
   (princ)
[hide]
(defun ReadObject (f / ObjectList firstLine code value)
   (setq ObjectList nil)
   ;; Skip the 'MLSTYLE'.
   (setq firstLine (read-line f))
   (if (/= nil firstLine)
      (progn
         (while (/= 0 (setq code (atoi (read-line f))))
            (setq value (vl-string-trim " " (read-line f)))
            (if (or (= code 2)
                      (= code 3)
                      (= code 6)
               (setq ObjectList (append ObjectList (list (cons code value))))
            (if (or (= code 70)
                      (= code 62)
                      (= code 71)
               (setq ObjectList (append ObjectList (list (cons code (atoi value)))))
            (if (or (= code 51)
                      (= code 52)
               ;; Code 51 and 52 must be converted into degrees.
               (setq ObjectList (append ObjectList (list (cons code (angtof value 0)))))
            (if (= code 49)
               (setq ObjectList (append ObjectList (list (cons code (atof value)))))
   ObjectList
已领礼包: 6056个
发表于 2017-2-10 00:18:18 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 815个
发表于 2018-2-20 20:05:30 | 显示全部楼层
在其他图纸上加载多线定义非常方便
已领礼包: 6468个
发表于 2018-2-24 00:09:47 | 显示全部楼层
学习源码。
已领礼包: 7214个
发表于 2018-2-24 07:39:07 | 显示全部楼层
谢谢分享!
已领礼包: 3657个
发表于 2018-2-24 16:06:05 | 显示全部楼层
如何提取图里的线形到文件呢?
已领礼包: 20个
 楼主| 发表于 2018-2-24 17:14:39 | 显示全部楼层
你说的“线型”不是这个帖子说的多线样式吧?
GMT+8, 2026-11-4 07:22 , Processed in 0.719786 second(s), 41 queries , Gzip On.
