查看: 2244|回复: 5
[每日一码] 填充数据格式及重建边界的代码
已领礼包: 20个
发表于 2017-2-9 11:41:53 | 显示全部楼层 |阅读模式
1、命令方法
(command "-hatchedit" OBJ "b" "r" "y")
2、VLISP方法
(defun c:ReBound (/ loops layerN HObjts Hobj_ Hobj_VLA lpNum)
  (defun AT:Test (ent layer / _2dpt layer ss i a b ss2 i2 d)
    (vl-load-com)
    (defun _2dpt (pt) (list (car pt) (cadr pt) 0.))
    (vla-getboundingbox (vlax-ename->vla-object ent) 'a 'b)
    (if        (setq ss2
               (apply
                 'ssget
                 (append
                   (list "_W")
                   (mapcar
                     '(lambda (x) (trans (_2dpt (vlax-safearray->list x)) 0 1))
                     (list a b)
                   '(((0 . "~HATCH,ARC,CIRCLE,LINE,LWPOLYLINE")))
      (repeat (setq i2 (sslength ss2))
        (entmod
          (subst
            (cons 8 layer)
            (assoc 8 (setq d (entget (ssname ss2 (setq i2 (1- i2))))))
            d
    (princ)
  (defun Loops (lpn Vlnme EntN Lynm / BndL)
    (vla-GetLoopAt Vlnme lpn 'lp)
    (if        (vl-catch-all-error-p
          (setq        BndL (vl-catch-all-apply
                       'vlax-safearray->list
                       (list lp)
      (progn
        (command "_-HATCHEDIT" EntN "_B" "_P" "_Y")
        (AT:Test EntN Lynm)
      (foreach itm BndL
        (vla-put-layer itm Lynm)
  (prompt "\nSelect Hatch for Boundary:")
  (setq HObjts (ssget ":L" '((0 . "HATCH"))))
  (repeat (setq i (sslength HObjts))
    (setq Hobj_ (ssname HObjts (setq i (1- i))))
    (setq Hobj_VLA (vlax-ename->vla-object Hobj_))
    (if        (= (setq lpNum (vla-get-numberofloops Hobj_VLA)) 1)
      (loops 0 Hobj_VLA Hobj_ (vla-get-layer Hobj_VLA))
      (progn
        (setq lp_ -1)
        (repeat        lpNum
          (loops (setq lp_ (1+ lp_)) Hobj_VLA Hobj_ layerN)
  (princ)
HATCH填充的数据格式:
Hatch boundary path data group codes
Group code
Description
92
Boundary path type flag (bit coded):
0 = Default; 1 = External; 2 = Polyline
4 = Derived; 8 = Textbox; 16 = Outermost
varies
Polyline boundary type data (only if boundary = polyline). See Polyline boundary data table below
93
Number of edges in this boundary path (only if boundary is not a polyline)
72
Edge type (only if boundary is not a polyline):
1 = Line; 2 = Circular arc; 3 = Elliptic arc; 4 = Spline
varies
Edge type data (only if boundary is not a polyline). See appropriate Edge data table below
97
Number of source boundary objects
330
Reference to source boundary objects (multiple entries)
Polyline boundary data group codes
Group code
Description
72
Has bulge flag
73
Is closed flag
93
Number of polyline vertices
10
Vertex location (in OCS)
DXF: X value; APP: 2D point (multiple entries)
20
DXF: Y value of vertex location (in OCS) (multiple entries)
42
Bulge (optional, default = 0)
Line edge data group codes
Group code
Description
10
Start point (in OCS)
20
DXF: Y value of start point (in OCS)
11
Endpoint (in OCS)
21
DXF: Y value of endpoint (in OCS)
Arc edge data group codes
Group code
Description
10
Center point (in OCS)
20
DXF: Y value of center point (in OCS)
40
Radius
50
Start angle
51
End angle
73
Is counterclockwise flag
Ellipse edge data group codes
Group code
Description
10
20
11
Endpoint of major axis relative to center point (in OCS)
21
DXF: Y value of endpoint of major axis (in OCS)
40
Length of minor axis (percentage of major axis length)
50
Start angle
51
End angle
73
Spline edge data group codes
Group code
Description
94
Degree
73
Rational
74
Periodic
95
Number of knots
96
Number of control points
40
Knot values (multiple entries)
10
Control point (in OCS)
20
DXF: Y value of control point (in OCS)
42
Weights (optional, default = 1)
97
Number of fit data
11
Fit datum (in OCS)
21
DXF: Y value of fit datum (in OCS)
12
Start tangent
DXF: X value; APP: 2D vector
22
DXF: Y value of start tangent (in OCS)
13
End tangent
23
DXF: Y value of end tangent (in OCS)
已领礼包: 1304个
发表于 2017-2-9 11:54:48 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 862个
发表于 2017-2-9 12:38:36 | 显示全部楼层
正需要,支持楼主大人了!
已领礼包: 9341个
发表于 2017-2-10 11:12:13 | 显示全部楼层
感谢 marting 分享学习!!!!
发表于 2021-1-26 13:28:54 | 显示全部楼层
如果只是重建边界的话,楼主要不要试试,cad自带的功能“hatchgenerateboundary”,直接选中图案,输入”hatchgenerateboundary“,会自动生成边界。生成的边界跟楼主软件编出来的相比有不同,楼主的是通过hatchedit里的b重建边界,p多段线,y多段线关联填充。cad自带的生成边界是不关联填充的多段线,我一般会把这个长长的命令,替换成he,也比较简单不需要加载lsp
GMT+8, 2026-11-4 17:43 , Processed in 0.563017 second(s), 40 queries , Gzip On.
