查看: 910|回复: 4
AUTOCAD拷贝粘贴失败或者时间很长的解决方案
发表于 2017-2-13 11:15:11 | 显示全部楼层 |阅读模式
Issue:When trying to copy and paste elements in an AutoCAD drawing, the process hangs for a long time (even several minutes), or it fails to work and may even crash the program.
Solution:Several things can cause copy and paste to stop working, the most basic of which is data corruption in the drawing.
To fix the copy and paste functionality, try repairing the drawing using the following methods:
Recover the drawing
Use the RECOVER command to open the drawing. This will audit the file and fix all errors that it can.
Remove excessive linetypes
Use the PURGE command and select all options to purge extra linetypes that may be in the drawing. For AutoCAD 2012, 2013, and 2014, use also the DGN Hotfix (the hotfix is rolled into AutoCAD 2015 and newer and is not available for AutoCAD 2011 and older). Here are the links:Delete constraints
Too many constraints will slow down a drawing and stop copy and paste from working. Often these are not visible in the drawing and can be turned on under the Parametric tab on the ribbon. To remove them, select all elements in the drawing and use the DELCON command.
Reset the scale list
Use the -SCALELISTEDIT command and choose the Reset option.
Delete layer filters
Use the FILTERS command to delete all layer filters.
Reset the Windows Clipboard
Memory fragmentation may have corrupted the clipboard. Exit and relaunch AutoCAD to reset it.
Install Object Enablers that may be required to prevent Proxy Graphics
Object Enablers allow for the objects to display instead of Proxy Graphics. Install object enablers for drawings created with applications such as Autodesk AutoCAD Civil 3D
See Also:AutoCAD DWG files unexpectedly increase in file size
Copy and paste fails when DWG file contains Xref
已领礼包: 1304个
发表于 2017-2-13 12:15:01 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 107个
发表于 2017-3-27 06:51:25 | 显示全部楼层
全是鸟文 看不懂
百度了一下 还是看不懂
问题:当试图在AutoCAD绘图中复制和粘贴元素时,这个过程会持续很长时间(甚至几分钟),否则会失败,甚至会导致程序崩溃。
解决方案:一些东西会导致复制和粘贴停止工作,其中最基本的是数据损坏的图纸。
要修复复制和粘贴功能,请尝试使用以下方法修复绘图:
复原图
使用“恢复”命令打开绘图。这将审计文件和修复所有错误,它可以。
去除过量的线型
使用Purge命令并选择清除多余的线型,可以绘图中的所有选项。AutoCAD 2012,2013,和2014,使用的DGN hotfix(热修复轧成AutoCAD 2015和更新不适用于AutoCAD 2011及以上)。以下是链接:
DGN清除AutoCAD 2013 / 2014
DGN清除AutoCAD 2012
DGN修补程序和AutoCAD LT
删除约束
太多的限制会减慢绘图和停止复制和粘贴工作。这些通常在绘图中是不可见的,并且可以在参数选项卡上打开。删除它们,选择绘图中的所有元素,并使用达康命令。
重置规模列表
使用- scalelistedit命令并选择重置期权。
删除图层过滤器
使用筛选器命令删除所有图层筛选器。
重置Windows剪贴板
内存碎片可能已损坏剪贴板。退出并重新启动AutoCAD重置。
安装对象的推动者,可能需要防止代理图形
对象技术允许代替代理图形显示对象。安装与应用如Autodesk AutoCAD Civil 3D对象创建图纸的推动者
参见:AutoCAD的DWG文件的文件大小意外增加
复制和粘贴失败时,DWG文件包含外部参照
发表于 2017-4-11 10:42:57 | 显示全部楼层
没有中文的吗
GMT+8, 2026-11-4 02:52 , Processed in 0.443835 second(s), 37 queries , Gzip On.
