查看: 1618|回复: 2
[每日一码] Xref API 文档
已领礼包: 13个
发表于 2017-2-13 14:41:11 | 显示全部楼层 |阅读模式
问题:
如何用OBJECTARX创建XREFS ?
回答:
The following function have been introduced with ObjectARX 2000:
acedXrefAttach()
acedXrefOverlay()
acedXrefUnload()
acedXrefDetach()
acedXrefReload()
acedXrefBind()
acedXrefXBind()
acedXrefCreateBlockname()
下面是帮助手册没有写入的信息。
The following information is not found in the ObjectARX Reference Manual because
they were mistakenly excluded. Here's more information on them:
Common Rules
--  All Xref APIs operate on the current document only.
--  The APIs provide document locking internally. If the document cannot be
locked they return Acad::ErrorStatus eLockViolation.
-- No input validation or range checking is done other than checking for NULL
pointers or strings. Input validation is the caller's responsibility.
--  Xref log file processing is available if option is enabled.
--  Normal AutoCAD behavior with regards to output indicators, such as, progress
meters, and msgs, may be turned off when scripts enabled && cmdecho == 0, or
menu macros enabled && menuecho == 0, or menu encryption set.
The attached sample application uses these functions to implement a set of very
simple xref commands.  Each command uses one of the Xref API functions, and very
little else, so it should be easy to see how they should be used.  Here is a
list of which sample command implements which API function:
   XRA uses acedXrefAttach()
   XRO uses acedXrefOverlay()
   XRU uses acedXrefUnload()
   XRD uses acedXrefDetach()
   XRR uses acedXrefReload()
   XRB uses acedXrefBind()
   XRI uses acedXrefBind() (with the insertBind method)
Acad::ErrorStatus
acedXrefAttach(const char* XrefPathname,
const char* XrefBlockname,
AcDbObjectId* pXrefBTRid = NULL,
AcDbObjectId* pXrefRefid        = NULL,
const AcGePoint3d* pXrefInsertPt = NULL,
const AcGeScale3d*    pXrefScale = NULL,
const double* pXrefRotateAngle = NULL,
const Adesk::Boolean bQuiet = Adesk::kTrue);
Attaches an xref file to the current document.
Returns:
Returns Acad::eOk if operation is successful.
Parameters:
const char* XrefPathname [in] Xref file pathname
const char* XrefBlockname [in] Xref block name symbol to use
AcDbObjectId* pXrefBTRid [out,optional] AcDbObjectId ptr for the
attached/overlaid Xref block object Id
AcDbObjectId* pXrefRefid [out,optional] AcDbObjectId ptr for the
attached/overlaid Xref block reference object Id
const AcGePoint3d* pXrefInsertPt [in,optional] AcGePoint3d ptr for Insertion Pt
const AcGeScale3d* pXrefScale [in,optional] AcGeVector3d ptr for Scale factor
const double* pXrefRotateAngle [in, optional] double ptr for Rotate
angle(radians)
const Adesk::Boolean bQuiet [in, optional] Flag to suppress output msgs
Default behavior is as follows:
Insertion Point(X,Y,Z) = 0.0, 0.0, 0.0
Scale Factor(X,Y,Z) = 1.0, 1.0, 1.0
Rotation Angle(radians) = 0.0
Acad::ErrorStatus
acedXrefOverlay(const char* XrefPathname,
Creates an xref overlay to the current document.
Returns:
Parameters:
angle(radians)
Acad::ErrorStatus
acedXrefUnload(const char* XrefBlockname,
Unloads the Xref block by its given block name. This assumes a valid Xref block
exists in the current document.
Returns:
Parameters:
const char* XrefBlockname [in] Xref block name symbol for unload
const Adesk::Boolean bQuiet [in,optional] Flag to suppress output msgs
Acad::ErrorStatus
acedXrefDetach(const char* XrefBlockname,
Detaches the Xref block by its given block name. This assumes a valid Xref block
Returns:
Parameters:
const char* XrefBlockname [in] Xref block name symbol for detach
Acad::ErrorStatus
acedXrefReload(const char* XrefBlockname,
Reloads the Xref block by its given block name. This assumes a valid Xref block
Returns:
Parameters:
const char* XrefBlockname [in] Xref block name symbol for reload
Acad::ErrorStatus
acedXrefBind(const char* XrefBlockname,
const Adesk::Boolean bInsertBind = Adesk::kFalse,
Changes the Bind type of the Xref block by its given block name. This assumes a
valid Xref block exists in the current document.
Returns:
Parameters:
const char* XrefBlockname [in] Xref block name symbol for bind change
const Adesk::Boolean bInsertBind [in, optional] Converts Xref symbols to
insert-like bind names.
Acad::ErrorStatus
acedXrefXBind(const AcDbObjectIdArray symbolIds,
const bool bQuiet = true);
Binds symbols from xrefs to the current drawing.
Returns:
Parameters:
const AcDbObjectIdArray [in] object ids of symbol table records to be bound
Acad::ErrorStatus
acedXrefCreateBlockname(const char* XrefPathname,
char*& XrefBlockname);
Accepts a Xref file pathname and returns an internally allocated block name
symbol string buffer which follows the AutoCAD policy rules for its creation.
Typically, is composed of the filename of the Xref file. A return error will
occur if the block name cannot be created. The block name string's buffer must
be released via the acutDelString().
Returns:
Parameters:
const char* XrefPathname [in] pointer to a Xref file pathname
char*& XrefBlockname [out] Returns a pointer to a copy of the block
name symbol string
已领礼包: 271个
发表于 2017-2-13 16:06:08 | 显示全部楼层
好资料,值得学习
已领礼包: 85个
发表于 2017-2-13 17:56:06 | 显示全部楼层
支持楼主分享经验
GMT+8, 2026-11-3 07:35 , Processed in 0.512587 second(s), 32 queries , Gzip On.
