查看: 1160|回复: 1
[每日一码] 用VLISP创建Layout
发表于 2017-2-14 14:14:28 | 显示全部楼层 |阅读模式
(defun c:addMyLayout ()
  (vl-load-com)
  (setq acadApp (vlax-get-Acad-object))
  (setq acadDoc (vla-get-ActiveDocument acadApp))
  (setq layouts (vla-get-Layouts acadDoc))
  ;; Delete the layout named "Test" if it exists
  (vlax-for objLayout layouts
    (if (= (vla-get-name objLayout) "Test")
      (progn
        (princ
          (strcat
            "\nDeleted Layout named "
        (vla-delete objLayout) ;delete the Layout
        (vlax-release-object objLayout) ;release the Layout Object
      ) ;progn
    ) ;if
  ) ;vlax-for
  (setq layoutObj (vla-add layouts "Test"))
  ;; Assign Grayscale.CTB to the Layout
  (vla-put-StyleSheet layoutObj "Grayscale.ctb")
  ;; Assign DWF configuration to the Layout
  (if (= (substr (vlax-variant-value (vla-getvariable acadDoc "ACADVER")) 1 2) "15")
    (vla-put-configname layoutObj "PublishToWeb DWF.pc3")
    (vla-put-configname layoutObj "DWF6 ePlot.pc3")
  ) ;if
  ;; Assign Paper Size B to the Layout
  (vla-put-canonicalmedianame
    layoutObj
    "ANSI_expand_B_(11.00_x_17.00_Inches)"
  ;; Make the new Layout Active
  (vla-put-activelayout acadDoc layoutObj)
  ;; Example getting StyleSheet and Configname, not doing anything
  ;; with them here however
  (setq currPStyle (vla-Get-StyleSheet layoutObj))
  (setq currConfig (vla-Get-configname layoutObj))
  (princ)
已领礼包: 6056个
发表于 2017-2-14 22:41:53 | 显示全部楼层
谢谢分享。
GMT+8, 2026-11-6 02:38 , Processed in 0.374294 second(s), 31 queries , Gzip On.
