查看: 1800|回复: 1
[每日一码] 在AUTOCAD 2015 使用3DPOLY命令中使用回调的代码
已领礼包: 13个
发表于 2017-2-14 20:42:19 | 显示全部楼层 |阅读模式
回调函数是myTest3DPolyCallback, 主命令函数是MyGroupTestSendCommand3
static int myTest3DPolyCallback(void *pData)
        if (acedCmdCWasCancelled())
                acutPrintf(_T("\n3DPoly Command was cancelled..."));
                return 0;
        if (is3DPolyActive())
                int res = acedCommandC(&myTest3DPolyCallback, NULL, RTSTR, PAUSE, RTNONE);
                acedCallBackOnCancel();
                acutPrintf(_T("\nmyTest3DPolyCallback: 3DPoly is active. res=%d"), res);
                return 1;
        CallWhen3DPolyDone();
        return 0;
static Adesk::Boolean is3DPolyActive()
        struct resbuf rb;
        acedGetVar(_T("CMDNAMES"), &rb);
        if (_tcsstr(rb.resval.rstring, _T("3DPOLY")))
                return Adesk::kTrue;
        return Adesk::kFalse;
static void CallWhen3DPolyDone()
        acutPrintf(_T("\n3DPoly Command completed..."));
static void MyGroupTestSendCommand3(void)
        acedCommandC(&myTest3DPolyCallback, NULL, RTSTR, _T("_.3DPOLY"), RTSTR, PAUSE, RTSTR, PAUSE, RTNONE);
        acutPrintf(ACRX_T("\nAfter acedCommandC call. acedCommandC is asynchronous..."));
GMT+8, 2026-11-3 06:16 , Processed in 0.568052 second(s), 30 queries , Gzip On.
