查看: 1257|回复: 2
[每日一码] ARX使用ActiveX 接口查找所有的XREF
发表于 2017-2-15 12:37:09 | 显示全部楼层 |阅读模式
Question
I would like to use ActiveX Automation in an ARX application to find all the
XREF block table records. How can this be done?
Answer
There are four interfaces needed, IAcadApplication, IAcadDocument, IAcadBlocks
and IAcadBlock. One approach is to use MFC's ClassWizard to generate them from
the acad.tlb by your selection. Then it is just a matter of using the interfaces.
In the sample below, the names are printed out at the Acad command line.
Note: See "Using MFC and ClassWizard to Access AutoCAD ActiveX Automation" in
the ObjectARX Developer's guide for more information on using the ActiveX interface.
#include "stdafx.h"
#include "acad.h" // generated by MFC ClassWizard
// no error checking for code brevity
void printXrefBtrs()
    IAcadApplication iApp(acedGetAcadWinApp()->GetIDispatch(TRUE));
    IAcadDocument iDoc(iApp.GetActiveDocument());
    IAcadBlocks iBlks(iDoc.GetBlocks());
    for(long i=0; i<iBlks.GetCount(); i++)
        _variant_t x(i);
        IAcadBlock iBlk(iBlks.Item(x));
        if(iBlk.GetIsXRef() == TRUE)
            CString str = iBlk.GetName();
            acutPrintf("\nBTR # %d is a Xref with name: %s", i,
str);
发表于 2018-9-16 09:38:38 | 显示全部楼层
正学习遍历xref,及时雨啊,谢谢啦
GMT+8, 2026-11-22 10:46 , Processed in 0.288547 second(s), 13 queries , Gzip On, File On.
