查看: 18527|回复: 91
[每日一码] 在多段线上拖动标注文字
 火 [复制链接]
已领礼包: 20个
发表于 2017-2-16 22:49:33 | 显示全部楼层 |阅读模式
(defun c:plLen (/ cEnt tStr tBox tHgt tWid gr sPt cPt lAng bPt tPt pt1
                pt2 pt3        pt4)
  (vl-load-com)
  (if (and (setq cEnt (car (entsel "\nSelect Object: ")))
           (member (cdr (assoc 0 (entget cEnt)))
                   '("LWPOLYLINE" "POLYLINE" "LINE")
           ) ;_ end of member
      ) ;_ end of and
    (progn
      (setq tStr (rtos (vla-get-length
                         (vlax-ename->vla-object cEnt)
                       ) ;_ end of vla-get-length
                       2
                       2
                 ) ;_ end of rtos
            tBox (textbox (list (cons 1 tStr) (cons 40 (getvar "TEXTSIZE")))
                 ) ;_ end of textbox
            tHgt (- (cadadr tBox) (cadar tBox))
            twid (- (caadr tBox) (caar tBox))
      ) ;_ end of setq
      (princ "\nPosition Text...")
      (while (eq 5 (car (setq gr (grread t 5 0))))
        (redraw)
        (if (listp (setq sPt (cadr gr)))
          (progn
            (setq cPt  (vlax-curve-getClosestPointto cEnt sPt)
                  lAng (angle cPt sPt)
                  bpt  (polar cPt lAng (/ (getvar "TEXTSIZE") 2.))
                  tpt  (polar bpt lAng tHgt)
                  mPt  (polar bPt lAng (/ tHgt 2.))
                  pt1  (polar bpt (+ lAng (/ pi 2.)) (/ tWid 2.))
                  pt2  (polar bPt (- lAng (/ pi 2.)) (/ tWid 2.))
                  pt3  (polar tpt (+ lAng (/ pi 2.)) (/ tWid 2.))
                  pt4  (polar tPt (- lAng (/ pi 2.)) (/ tWid 2.))
            ) ;_ end of setq
            (grvecs (list -3 pt1 pt2 pt3 pt4 pt1 pt3 pt2 pt4))
          ) ;_ end of progn
        ) ;_ end of if
      ) ;_ end of while
      (if (eq 3 (car gr))
        (progn
          (setq lAng (- lAng (/ pi 2.)))
          (cond        ((and (> lAng (/ pi 2)) (<= lAng pi))
                 (setq lAng (- lAng pi))
                ((and (> lAng pi) (<= lAng (/ (* 3 pi) 2)))
                 (setq lAng (+ lAng pi))
          ) ;_ end of cond
          (Make_Text mPt tStr lAng)
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of progn
    (princ "\n<!> Incorrect Selection <!>")
  ) ;_ end of if
  (redraw)
  (princ)
) ;_ end of defun
函数 Make_Text:
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 6056个
发表于 2017-2-17 00:01:59 | 显示全部楼层
正需要,支持楼主大人了!
已领礼包: 9341个
发表于 2017-2-17 08:17:51 | 显示全部楼层
确实是难得好帖啊,顶先一下!!!!
已领礼包: 6881个
发表于 2017-2-17 08:38:51 | 显示全部楼层
感谢你的分享
谢谢你
已领礼包: 5800个
发表于 2017-2-17 08:57:17 | 显示全部楼层
非常好程序,非常感谢楼主!!!
已领礼包: 2965个
财富等级: 家财万贯
发表于 2017-2-17 09:42:06 | 显示全部楼层
回复学习,谢谢分享
已领礼包: 1307个
发表于 2017-2-17 10:06:16 | 显示全部楼层
很炫的效果。
已领礼包: 862个
发表于 2017-2-17 13:12:19 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 1337个
发表于 2017-2-17 20:01:47 | 显示全部楼层
这个挺好玩的!
已领礼包: 312个
发表于 2017-2-17 21:39:55 | 显示全部楼层
看看函数 Make_Text
已领礼包: 195个
发表于 2017-2-18 09:16:03 | 显示全部楼层
修改了一下。
已领礼包: 1482个
发表于 2017-2-18 10:11:17 | 显示全部楼层
感谢楼主分享
已领礼包: 2670个
财富等级: 家财万贯
发表于 2017-2-18 13:43:05 | 显示全部楼层
wow nice ...............
已领礼包: 77个
发表于 2017-2-18 21:50:32 | 显示全部楼层
能否输入比例?
发表于 2017-2-18 21:59:48 | 显示全部楼层
代码分享下
GMT+8, 2026-11-3 06:05 , Processed in 0.643865 second(s), 63 queries , Gzip On.
