查看: 5128|回复: 5
[求助] 求AcDbOle2Frame的实例,越详细越好
发表于 2017-3-3 16:18:02 | 显示全部楼层 |阅读模式
悬赏20D豆未解决
如题
已领礼包: 859个
发表于 2017-3-3 16:59:10 | 显示全部楼层
Sets the AcDbOle2Frame object to use the MFC COleClientItem object pointed to by pItem.
The COleClientItem class used by AutoCAD is a modified version of the class that ships from Microsoft. This means that it is not possible for applications to create their own COleClientItem objects for use by this function. This function can only be used with COleClientItem objects created by AutoCAD (that is, the object from another AcDbOle2Frame object).
不能自己创建,只能从已有的  AcDbOle2Frame object 创建
已领礼包: 13个
发表于 2017-3-3 22:00:08 | 显示全部楼层
下面是个例子,检索图中所有的OLE2FRAME对象
  1. #include "dbsymtb.h"          //
  2. #include "dbmain.h"           // Entity base class
  3. #include "dbole.h"            // OLE2 container
  4. void fListOle()
  5. {
  6. AcDbBlockTable *pBT = NULL;
  7. AcDbBlockTableRecord *pBTR = NULL;
  8. //get the Modelspace block table record
  9. acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBT,AcDb::kForRead);
  10. pBT->getAt(ACDB_MODEL_SPACE,pBTR,AcDb::kForRead);
  11. pBT->close();
  12. //iterate the Modelspace
  13. AcDbBlockTableRecordIterator *pIter = NULL;
  14. pBTR->newIterator(pIter);
  15. AcDbEntity *pEnt;
  16. AcDbOle2Frame *pOle;
  17. char buf1[255];
  18. while(!pIter->done())
  19. {
  20.   pIter->getEntity(pEnt,AcDb::kForRead);
  21.   pOle = AcDbOle2Frame::cast(pEnt);
  22.   if(pOle != NULL)
  23.   {
  24.    //LinkPath is valid only for Linked objects
  25.    if (OT_LINK == pOle->getType())
  26.    {
  27.     if(TRUE == pOle->getLinkPath(buf1,sizeof(buf1))) acutPrintf("\nLink Path: %s",buf1);
  28.    }[code=cpp]
  29. #include "dbsymtb.h"          //
  30. #include "dbmain.h"           // Entity base class
  31. #include "dbole.h"            // OLE2 container
  32. void fListOle()
  33. {
  34. AcDbBlockTable *pBT = NULL;
  35. AcDbBlockTableRecord *pBTR = NULL;
  36. //get the Modelspace block table record
  37. acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBT,AcDb::kForRead);
  38. pBT->getAt(ACDB_MODEL_SPACE,pBTR,AcDb::kForRead);
  39. pBT->close();
  40. //iterate the Modelspace
  41. AcDbBlockTableRecordIterator *pIter = NULL;
  42. pBTR->newIterator(pIter);
  43. AcDbEntity *pEnt;
  44. AcDbOle2Frame *pOle;
  45. char buf1[255];
  46. while(!pIter->done())
  47. {
  48.   pIter->getEntity(pEnt,AcDb::kForRead);
  49.   pOle = AcDbOle2Frame::cast(pEnt);
  50.   if(pOle != NULL)
  51.   {
  52.    //LinkPath is valid only for Linked objects
  53.    if (OT_LINK == pOle->getType())
  54.    {
  55.     if(TRUE == pOle->getLinkPath(buf1,sizeof(buf1))) acutPrintf("\nLink Path: %s",buf1);
  56.    }
  57.   }
  58.   pOle->close();
  59.   pIter->step();
  60. }
  61. //close the block table record
  62. pBTR->close();
  63. delete pIter;
  64. }
  pOle->close();
  pIter->step();
pBTR->close();
delete pIter;
[/code]
 楼主| 发表于 2017-3-7 09:47:55 | 显示全部楼层
有没有添加图片 或者 WORD的例子?我添加总是添加不进去
发表于 2017-3-7 10:32:15 | 显示全部楼层
用CAD命令吧
GMT+8, 2026-11-3 01:29 , Processed in 0.567050 second(s), 38 queries , Gzip On.
