查看: 1817|回复: 4
[求助] 如何根据两端点和弧长画弧线?
已领礼包: 10个
发表于 2017-3-21 09:41:02 | 显示全部楼层 |阅读模式
如何根据两端点和弧长画弧线?
已领礼包: 20个
发表于 2017-3-21 11:38:58 | 显示全部楼层
  1. (defun ArcStartEndLength (startPoint              endPoint        arcLength
  2.                           /            newton    chord        ang
  3.                           rad            mid              cen
  4.                          )
  5.   ;; use the Newton method to compute the arc half angle according to its length and chord
  6.   (defun newton        (arc chord / k x)
  7.     (setq k (/ chord arc)
  8.           x (sqrt (- 6 (* 6 k)))
  9.     )
  10.     (repeat 6
  11.       (setq x (- x (/ (- (sin x) (* k x)) (- (cos x) k))))
  12.     )
  13.   )
  14.   (setq chord (distance startPoint endPoint))
  15.   (if (< chord arcLength)
  16.     (progn
  17.       (setq ang        (newton arcLength chord)
  18.             rad        (abs (/ chord 2. (sin ang)))
  19.             mid        (mapcar        '(lambda (p1 p2) (/ (+ p1 p2) 2.0))
  20.                         startPoint
  21.                         endPoint
  22.                 )
  23.       )
  24.       (if (equal (/ pi 2) ang 1e-009)
  25.         (setq cen mid
  26.               rad (/ chord 2.)
  27.         )
  28.         (setq
  29.           cen (polar mid
  30.                      (+ (angle startPoint endPoint) (/ pi 2))
  31.                      (* rad (cos ang))
  32.               )
  33.         )
  34.       )
  35.       (entmakex
  36.         (list
  37.           (cons 0 "ARC")
  38.           (cons 10 cen)
  39.           (cons 40 rad)
  40.           (cons 50 (angle cen startPoint))
  41.           (cons 51 (angle cen endPoint))
  42.         )
  43.       )
  44.     )
  45.   )
  46. )
  47. (defun c:tt ()
  48.   (if (and (setq len (getreal "\nArc Length<Quit>:"))
  49.            (setq p1 (getpoint "\nStart point<Quit>:"))
  50.            (setq p2 (getpoint p1 "\nEnd Point<Quit>:"))
  51.       )
  52.     (progn
  53.       (ArcStartEndLength p1 p2 len)
  54.     )
  55.   )
  56.   (princ)
  57. )
菜鸟不会用啊,怎么画出来是个长方形,能不能说明一下操作步骤,  详情 回复 发表于 2021-4-11 10:39
已领礼包: 10个
 楼主| 发表于 2017-3-21 15:06:23 | 显示全部楼层
谢谢大师,可行。
发表于 2020-11-15 10:34:25 | 显示全部楼层
cad2018用不了呢
已领礼包: 10个
发表于 2021-4-11 10:39:29 | 显示全部楼层
GMT+8, 2026-11-4 18:14 , Processed in 0.428754 second(s), 42 queries , Gzip On.
