查看: 1259|回复: 2
[每日一码] 分离(Detach)Xref
已领礼包: 20个
发表于 2017-4-5 17:48:40 | 显示全部楼层 |阅读模式
[Plain Text] 纯文本查看 复制代码
(defun DetachXref (name / xref)
  (if (and (not (vl-catch-all-error-p (setq xref (vl-catch-all-apply 'vla-item
                                                   (list
                                                     (vla-get-blocks
                                                       (vla-get-activedocument (vlax-get-acad-object))
                                                     name
           (= :vlax-true (vla-get-isxref xref))
    (vla-detach xref)
  (princ)
已领礼包: 6468个
发表于 2017-4-6 00:03:54 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 6056个
发表于 2017-4-14 00:04:30 | 显示全部楼层
正需要,支持楼主大人了!
GMT+8, 2026-11-5 22:12 , Processed in 0.410113 second(s), 33 queries , Gzip On.
