查看: 1271|回复: 5
[求助] 请老师帮助看看,如何判断选中的图元是否有面积属性
发表于 2017-4-22 10:36:01 | 显示全部楼层 |阅读模式
如题,我想获得选中图元的面积,之前如何判断选中的图元是否有面积属性?
已领礼包: 1268个
发表于 2017-4-22 10:54:11 | 显示全部楼层
(vl-catch-all-apply 'vla-get-area (list (vlax-ename->vla-object (car (entsel))))
发表于 2017-4-22 11:54:01 | 显示全部楼层
(vlax-method-applicable-p obj  'area)
已领礼包: 1268个
发表于 2017-4-22 13:39:23 | 显示全部楼层
Determines if an object has a specified property
(vlax-property-available-p obj prop [check-modify])
Arguments
obj
A VLA-object.
property
A symbol or string naming the property to be checked.
check-modify
If T is specified for this argument, vlax-property-available-p also checks that the property can be modified.
 楼主| 发表于 2017-4-22 13:40:41 | 显示全部楼层
谢谢,测试了一下,很好用
GMT+8, 2026-11-5 22:45 , Processed in 0.452392 second(s), 44 queries , Gzip On.
