查看: 1735|回复: 2
[每日一码] 获取块定义的实体表
发表于 2017-4-29 15:33:37 | 显示全部楼层 |阅读模式
  1. (defun get-block-entities (blk / ent lst)
  2.   ;; Define the function, declare local variables
  3.   (if ;; If the following returns a non-nil value
  4.       ;; i.e. if the block exists in the drawing
  5.       (setq ent (tblobjname "block" blk))
  6.     ;; get the BLOCK entity
  7.     (while (setq ent (entnext ent))
  8.       ;; Step through the entities in the block definition
  9.       (setq lst (cons ent lst))
  10.       ;; Construct a list of the block components
  11.     )
  12.     ;; end WHILE
  13.   )
  14.   ;; end IF
  15.   (reverse lst)
  16.   ;; Return the list
  17. )
  18. ;; end DEFUN
已领礼包: 9341个
发表于 2017-4-29 18:40:02 | 显示全部楼层
感谢 Lisphk 分享程序!!!!
已领礼包: 20个
发表于 2017-4-30 22:43:54 | 显示全部楼层
也可以用VL函数获得
  1. (defun getblkents (blkname / ents e item)
  2.   (and
  3.     (setq e (tblobjname "block" blkname))
  4.     (vlax-for item
  5.               (vlax-ename->vla-object (cdr (assoc 330 (entget e))))
  6.       (setq ents (cons (vlax-vla-object->ename item) ents))
  7.     )
  8.   )
  9.   (reverse ents)
  10. )
GMT+8, 2026-11-5 21:22 , Processed in 1.712222 second(s), 32 queries , Gzip On.
